Question about Frigidaire FEQ1442ES Electric Dryer
I HAVE A FRIGIDAIRE LEQ640SQ ELECTRIC DRYER
THE DRYER WILL ONLY RUN FOR 3 - 5 SECONDS AND THEN TURN OFF
THE POWER IS WIRED CORRECTLY AND LENT TRAP IS CLEAN. IT DOES THIS ON ALL SETTING AND TEMPS.
  • 958 Answers
You may have a problem with the motor. this is the only device that would turn off the whole machine for 3-5 seconds.
there is this contact switch that would be held close by the motor once the motor is running normally until you reach the end of cycle.
but if there is problem with the motor, it has this over current device that would turn it off.
once off, the contact that it was holding to keep the unit running would open up and stop the unit from running.
tnx 4 using fixya,
drcool
Posted on Oct 19, 2008
Frigidaire frqe7000lw vibrating grinding
did you leave your lent filter out a couple of times? Sock or lent wad may be caught up in the fan that forces air through the dryer.
APPLIANCE 911
Oct 13, 2015 | Frigidaire FRQE7000LW Electric 7.0 cu ft...
Dryer only drys for 16 or 26 seconds
Sounds like a high limit is tripping. Maybe blowing, or vacuuming out your vent line that leads outside. You may have built up lent inside of it.
Nov 10, 2013 | Frigidaire GLEQ2152ES Electric Dryer
My kenmore dryer wont click on, it will light up and click but nothing happen's I cleaned out the lent trap and the lent funnel and it still wont click on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 19, 2011 | Dryers
My dryer is working, but it's not heating
pull the vent line off the back of dryer and see if it helps,also the duct that the lint filter slides into could be loaded with lint,when was the last time you cleaned out the dryer?sounds like from what you said when you had the top off it worked better because you had better air movement with the top off.go out side and check the vent,if it's a long run from the back of the dryer to the outside vent i use a leaf blower to blow out the vent line,you also need to vac out the inside of dryer where the motor is,if you have a shop vac blow off the motor and blow through the inside vent to clean out the heating duct and vac out the back of the drum,you should take it apart and clean it out once a year so the dryer will run correctly
Mar 27, 2010 | Frigidaire GLER341A Electric Dryer
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
Dryer doesn't dry
YES, most defintely. This typically causes the dryer to overheat and eventually blows the thermal cut-out or heating element.
SYMPTOMS:
Dryer runs, but does not heat - possible bad heating element or thermal cut-out.
Dryer does not run at all - possible bad door switch, blown thermal fuse, timer or drive motor.
Does your dryer exhibit any of these symptoms? Please post back and let me know.
Feb 14, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
142 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
