Question about Kenmore Elite 45986 Front Load Washer
Will not pump water into machine to start cycle
I have had a front load washer for about a year and a half. It has decided to post a F21 code about 5 minutes into the cycle. When opening up the washer, my clothes are still dry. It is not putting water into the washer to start the cycle. I have checked all the hoses. I have cleaned out the filter. I have even taken apart the pump to see if it was clogged. Nothing!!! It sounds like it is in in the draining cycle and won't signal that it is the start of the cycle, not the end. Help!! We are very frustrated and have a family of 5's laundry piling up in our house!!
  • cronkcrew Oct 19, 2008
    is the solenoid right by the water inlet? Just want to make sure i am looking at the same thing you are talking about. No water is flowing it is just constantly wanting to drain water out. It won't let water come in. We will try that and let you know. thanks
  • cronkcrew Oct 21, 2008
    There is 2. One for the cold and one for the hot. Will they both go or just 1?? Any suggestions to see if there is power going to them? We are getting to a point of not knowing what to do!!
    thanks
  • 958 Answers
No, it is not in the draining cycle. it is in the water inlet solenoid. check if there is power to the water inlet solenoid and check also if there is water going into the unit.
if there is power to the solenoid, then check the water inlet filter, it could be clogged also.
as you remove the hose to the water inlet valve, check the crisscross plastic at the center of the inlet valve, that is the inlet valve water filter. clean it if it is dirty or clogged.
if there is no power, check the wires that goes into it. make sure that it is connected properly to the valve
F21 stands for no water flowing to the unit. it has this water flow sensor. it senses if there is water flowing tio the unit. if there is no water after 5 minutes, the alarm will flash.
tnx 4 using fixya,
drcool
Posted on Oct 19, 2008
  • francis rivero Oct 20, 2008
    yup.
    that's the one.
    tnx, and don't forget to rate the solution please.
    tnx again,
    drcool
  • francis rivero Oct 21, 2008
    you need a volt meter to test if there is power to the solenoid. put the test leads to the terminals of the solenoid and while you turn it on, watch the meter if it would indicate a voltage reading.
    if there is, then the problem is the solenoid. if there is none, then trace the controller.
    tnx again,
    drcool
Error message SUD and F21 even after unclogging the filter
Push the pause/cancel button twice to clear your message. Then run through a rinse/spin cycle. Next try a normal load without any detergent. SUDS is usually from too much detergent. If this fails, checked the hose for kinks. Check connections and if all that fails, you will probably have to replace the pump. Good Luck!
Feb 04, 2014 | Maytag MAH6700AWW Neptune Front-Load...
Whirlpool duet steam washer error f21
The F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
Nov 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet wfw9250ww will not drain F9E1 code is displayed. How do I toubleshoot this?
F9E1 or F21
  • When users observe the F9E1 or F21 error code in their Whirlpool washer's display, it indicates a drain pump system error. The drain hose should be checked to ensure that it has been installed properly and not having a blockage.
Read more: Code List for Whirlpool Washers ' eHow.com http://www.ehow.com/list_7735284_code-list-whirlpool-washers.html#ixzz1wPUs4Ry6
May 31, 2012 | Washing Machines
Never had any problems with my washer and it must be 5-8 years old. Today, I got: Error code F21. ????
he F21 error on this line of washers is the machines way of saying the water took to long to drain from the tub. This could be a problem with one of the washer partsincluding the drain pump itself, how the drain hose enters the stand pipe, or maybe even something is stuck somewhere in the drain system and is preventing the water from flowing properly. Clean out the sump pump , but remember, when you remove the screws holding it in place, whatever water thats still in the tub is gonna be in your lap, so be ready !!
Jul 15, 2011 | Kenmore HE2 Plus Front Load Washer
F21 is flashing,... what is this
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the "Sd" error will be displayed, then
4 minutes later the "F/21" error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
F21 washer drain time exceeded
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool front load washer wfw9500tc01 washed a load of sheets and then at rinse cycle it put up "sud" and a few seconds later it had a F21 code come up and now it acts like the pump is working but it...
Ok here is whats happening. 14b0f4a.jpgTheir is too much soap in the machine. The machine only uses a gallon or 2 at a time.01f5935.jpg You go adding in too much soap and it is gonna detect suds.aa3f677.jpg F21 Long drain. Possible cause: Clogged filter, clogged/failed pump, too much dang soap. c5d1358.jpg
Jun 17, 2010 | Whirlpool WFW9500TC Front Load Stacked...
My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
3. Check the electrical connections at the pump and make sure the pump is running.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer flashing sud then f21 ????????
The "SUD" error is in direct relationship the other error code. "F21" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If something is preventing water from pumping through the drain pump, you will often get a "SUD" error as air is developed in the pump. Make sure you double check all the drain lines as well.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F21 Drain Problem with empty washer
Please see what I (royale) have done with my problem.
May 06, 2007 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
78 people viewed this question
Sal De
fordexpert
Robert Rankin
