Question about Nokia 6019i
Dropped in water
Well i was at work and i wass walking along and i dropped my phone in the mop bucket so i reached in and took it out and i took it apart and dried it out and the screen was blury and then i dried it out with a blow dryer and now it works but it says searching for network and no clue what to do. will it work again or should i just get my phone back because it is just a loaner.
  • 215 Answers
What the heck is Pure Gasoline ?????? Gasoline is for running cars not drying out wet phones. PLEASE Never Ever use gasoline anywhere near electronic components. The mind boggles. BMW
Posted on Jul 07, 2006
  • 175 Answers
Clean the aerial contact with a rubber it will work.
Posted on Jul 04, 2006
    Problem Solver:
  • 10 Answers
Open the mobile phone and pls ur hands should be dry now open then the board and use a cooton swab dipped in very little (pure )gasoline and start to rub on the circuit board and let it dry ,, u have to be certain that all areas are covered and now assembnle it it will work
Posted on Jun 20, 2006
SOURCE:
What do I do if my ZTE ZMAX cell phone fell in dish water?
if it is not water proof then save up for a new phone
Jun 26, 2015 | ZTE Cell Phones
My Nintendo Dsi dropped in a mop bucket and it wont work what do i do
If the device is under warranty, or and extended warranty, you will need to contact the warranty provider to have the unit replaced. That is, if they cover such an incident. The water damage has rendered the device inoperable, unfortunately.
Jul 04, 2012 | Nintendo DSi Matte Blue Console
Kenmore 90 series top load. Water trickles in & is not coming out of the whole top area near the detergent dispenser.
Shut off the water valve(s) to the washer and remove the hoses right at the back of the washer (have a bucket handy to drain them). Clean out the strainer screens inside the hose fittings on the washer. While you have the hoses in the bucket, turn the water valve on and off to flush the hoses - if you've had a pressure drop across the strainers for some time, there may be a bit of sediment build up there waiting to clog them again.
If the hoses aren't marked, keep track of which one goes to the hot water inlet, otherwise you'll have to check the temperature of the water running through before reconnection. Another hint - you can use the water in the bucket to mop a floor if needed - why waste it?
Dec 23, 2010 | Kenmore Washing Machines
Shark steam mop will not syeam grey pruple shark steam mop
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 04, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hi, I have a Whirlpool refridge. The ice maker is making ice, yet the ice is not dropping into the ice bucket. If you put ice into the ice bucket it will correctly drop through the door. The ice seems...
Hi and welcome to FixYa. I am Kelly
Often ice maker issues are a symptom of an automatic defrosting problem OR a leaking (dripping / bypassing) ice maker water valve.
First off you should try and prove that there are no un-necessary water leakages by doing the following:
1. Turn the icemaker OFF
2. Remove the plastic line where it connects to the thru the cabinet water tube by pinching the clamp and pulling down on the plastic tube.
3. Place end of the plastic tube into a bucket for about 12 hours. At the end of 12 hours check the bucket for ANY water. If there is a noticable amount of water (more than 1 oz) the water valve is leaking water by the valve diaphram seat. The only remedy for this is to change the units water valve assy.
As far as a possible automatic defrosting problem..... soft ice cream is a symptom along with that of low ice production.
The evaporator coils get a substantial amount of ice build up on them and then the airflow in the freezer compartment is restricted resulting in a change in the freezer comprtment temp. If you do have an automatic defrosting problem you will soon notice noise from the evaporator fan as the ice build up encroaches into the fan blade path. Additionally the fresh food compartment will warm up.
The ice maker will not cycle until it reaches 16 to 15 deg F. The ice maker harvest cycle is started when the ice maker thermostat closes and advances the ice maker module.
Do the water in the bucket test and then look for signs of ice build up on the evaporator coils.
If neither of the above manifest / present then download this manual and follow the troubleshooting procedures:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Thanks for choosing FixYa.
Kelly
Sep 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My steam mop turns on but it wont steam anymore whats wrong with it?
I just had this problem after owning the mop for about a year. I let it stand for a while in a bucket of vinegar, then tried it again and it worked. I think it had gotten clogged with hard water deposits and the vinegar dissolved them. I'm buying some distilled water to use in the future with it.
Sep 16, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Droped in the mop bucket
If it's less than one year old, you can still have a warranty from Nintendo. I suggest you call them to know if they can fix it.
Jan 14, 2008 | Nintendo DS Lite Console
I can't fix it
unless there is somthing missing its probably worth getting a new one or just get rid of it.
Oct 29, 2007 | Nintendo DS Lite Console
Nokia 6019i Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
ASHRAF CA
ASHRAF CA
