Question about Westinghouse LTV-27w6 27 in. LCD HDTV
No audio with HDMI hook up on my westinghouse 40 lcdtv
Installed new hdmi cable and no audio have tryed everything in the book what am i doing wrong
  • stubuck Jan 08, 2009
    I have a Sony DVD Bluray BDP-S350 hooked to the A/V Harmon/Kardon AVR445 which is hooked to the Panasonic TH-50PZ700U plasma TV. I am using a Monster HDMI cable from the DVD to the A/V and a Belkin HDMI from the A/V to the TV. The picture quality is good but there is no sound from the 5.1 Paradigm speakers, please help, my wife has already cut off funding for any more HDMI cables.
SOURCE: Westinghouse ltv 32w4 hdc 32.02 in. hdtv lcd tv / dvd combo
My 42" Westinghouse HDMI inputs just stopped working. I thought it was the TW Explorer 4250HDC issue so I got a new one from TW. Still said no signal from HDMI. So, I shut the TV down and pulled the power cord out of the back. I waited a few seconds and reconnected the pwr cord. The TV "re-booted" so to say and now the HDMI inputs work. I think TVTEK has the right idea that it is firmware/software related. In the mean time, you might want to give that a try.
Posted on Jan 04, 2008
SOURCE: HDMI audio problems with my sharp LC42D64U
the problem is that your cable box is putting out too low of a bandwidth to your tv and is cutting out completely. Since its all digital either its there or not. try switching to componant cables. Cable boxes only support up to 720p anyway so you wont sacrafice any quality.
Hope this helps
Posted on Mar 24, 2008
baccardo
  • 150 Answers
SOURCE: Westinghouse 26" tv SK-26H730S HDMI screen blinks with Dell Comp.
try using the 27 pin monitor input instead the hdmi possibly has a frequency variance
Posted on Apr 16, 2009
SOURCE: TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Posted on Apr 29, 2009
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
I just bought an westinghouse 42'' led tv and im trying to hook my surround sound and my xbo 360 to it and i keep getting an no signal message everytime and it worked on my 42'' sanyo lcd...
Sounds to me like you are trying to use a composite hookup or a generic HDMI cable. If you get the official Microsoft HDMI connector it also includes phono audio outputs and an optical audio out for 5.1 surround,
Aug 27, 2011 | Westinghouse Televison & Video
Just tried to hook my aoc 22" to high definition
I beleive you have to enable audio in the HDMI SETUP so it will send the digital audio through HDMI ports, check the cable box and the TV HDMI sound setup.
Nov 19, 2010 | AOC L22W861 22 in. LCD HDTV
Westinghouse W2613 to Macbook - "Mode not supported"
You need an HDMI driver... also sometimes a special HDMI cable is used for Apples too, I believe. Also a lot of sets must start with a resolution of 800x600 32bit. Also research if HDMI is actually possible from your video card too. Some HDMI doesn't send the audio via the cable either you must use AV audio out.
Feb 02, 2010 | Televison & Video
My Westinghouse SK-32H640G LCD TV has picture but no sound. Its hooked up with HDMI cable, I've checked audio settings and TV speakers are on, and also have tried both HDMI ports on TV please help!
Hello, these are fairly new units as they have not been out in the market for that long. With that said I would recommend checkin if the audio is good using other inputs like the Tuner, Component (yPbPr) or simply RCA cables, if there is sound than mostlikely you will need to replace the main board. I would recommend to call Westinghouse customer care at 1800-701-0680 for further assistance.
Dec 06, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have a Westinghouse model SK-26H730S. I have my pc hooked up to it with hdmi cable. I'm trying to run the sound through the tv so I can use the remote. I tried going through the 1/8 mm jack, no good. I...
Hello, when you are using HDMI you should not use any other connection to hear audio on the TV, the HDMI cable has the audio built in. What you need to do is to make sure you have some king of audion coming out of the pc and raise the volume on the TV. If you need further or more detailed troubleshooting please email me at westytech@wde.com so we can get in contact. Please rate my help on this webpage if this information has been helpful.
Nov 11, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
May 25, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse LTV-27w6 27 in. LCD HDTV Logo
749 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
