Question about RCA F36668 36" TV
TV turns off by itself, juggling power cord causes TV to come back on
Hello, We have a RCA 36 TV that turns off by itself. If you mess with the power cord, it will turn back on sometimes when you jiggle it from the back. We know that it is still getting power, and when it runs the picture if just perfect. It's almost like a short. Please help
  • 1 more comment
  • Bill Williams Jun 19, 2006
    done
  • Anonymous Jul 06, 2008
    tv goes off & comes back on by itself
  • ccimeh Oct 20, 2008
    We've had the set for just about 2 years. On 10/18/08, it started turning itself off, the green light on the power button on the front of the set lights up, and then the it turns itself back on. We do not use the timer. Our local dealer told me to unplug it for about 10 minutes, and it should correct itself. I did it, and it has not.
Mine comes on at 7:00 by itself and goes off somtimes at 10:00 by itself.  It has even been know to change from one channel to the other.  We have no cable box, so the first thing our cable company asked was "Is it an RCA?"  We had to unplug it entirely when we went on vacation.  We do not have a recorder on it nor is the timer set for anything.  I even have dates & times this has been happening!!!
Posted on Oct 15, 2007
  • bestnana Dec 19, 2007
    Since we've changed back to regular EST the TV comes on every night at 6:00 p.m. and always on FSN. I NEVER watch FSN and have never set a timer on this TV.
    President:
  • 3,130 Answers
It could seem to be a power cord problem But when you move around the cord you are realisticly flexing the printed circuit board assy. If you know all the safety issues around the servicing a solid state tv, then Of course I will assit you, in any way I can, But you must be aware of the high voltage that these sets store , even if they Are unplugged. Its a total safety issue. If you have no experience using a multi- meter as well as the safety issue awarness, then PLEASE seek a pro to assist you with this reapir, as it will get worse in the long run and cost ya more to fix, as everytime you move around the cord and the set shuts off, then goes on , your surging the componets!. Good Luck
Posted on Jun 19, 2006
I have an RCA 36 inch tv, the color is messed up, it has a round circle and it will not change channels
If the set wasn't dropped or physically dammaged the chances of it being the picture tube is very small.
The set is probably magnetized and needs degaussing (demagnetizing).
All CRT type TV's have an internal demagnetizing circuit that is engaged when the set is first turned on after being off for the day.
If this circuit is working then you sometimes hear a "bonk" sound (about 1/2 a second long when the set is first turned on. If this circuit isn't working the set will become magnetized over time and will have to be degaussed using a degauss coil available at a TV repair shop (cost aprox. $35.00) and you should have the circuit checked at the same time. A set will also become magnetized if a large speaker (magnet) or motor is close to the TV. Be sure to vote/rate me if this helped Thanks!
Oct 23, 2009 | RCA F36650 36" TV
TV will not turn on
There is a problem with your power ic..U need to replace it...
Dont forget to rate
Sep 07, 2009 | RCA 36V430T 36" TV
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
Volume turns down by itself
Its the buttons on the tv, they need to be replaced, or replace the whole key pad on the tv. that should fix ur problem
Mar 17, 2009 | RCA F36650 36" TV
Tv tuns itself off, maybe needs bulb?
Check fuse inside tv lower panel where power cord gose in to tv maybe your problem
Mar 02, 2009 | RCA P61960 61" Rear Projection Television
RCA 36' tube tv won't turn on
possible that a fuse blew while transferring tv, most like to happen despite care in handling if tv was on for a while, kind of like moving a light bulb that is hot and suddenly filament breaks when you move the bulb slightly. Other than that I'd say it's a good time to get a new tv just in time too for the digital transition.
Feb 06, 2009 | RCA F36450 36" TV
NO COLOR IN MY RCA F36668 TV
Could be a bad TV or it could be loose TV connections feeding to the back of the TV. Any poor or loose connections in the cable leads causes a loss of signal strength to the TV.
Old cables and connection supplying TV Cable to the house or apartment can cause this problem also.
Dec 05, 2008 | RCA F36668 36" TV
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
36" RCA TV
My RCA G36788LV 36" television won't turn on
Oct 30, 2007 | RCA G36788LV 36" TV
RCA F36668 36" TV Logo
258 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
