Question about Kenmore Dryers
Wont heat up
Dryer wont fire up kenmore mod # 97576200
Heating element is bad.
Posted on Oct 19, 2008
Kenmore 100.85081400 no heat
check the thermal fuse on the blower housing if its open some units wont heat,also check the heating element if heated electrically,or the ignitor on gas fired units,by the number you provided i believe you meant its a 110.85081400 instead of the 100.85081400 (and is electrically heated) you provided which is produced by whirlpool for sears (kenmore) also there is a control board located inside behind the control panel that may be a culprit,but check the first two things i suggested at the top
Jul 23, 2012 | Kenmore Elite HE4 Electric Dryer
Dryer will not fire and if it does only burns for a minute or two Kenmore Mod. # 110c72622101
when you say fire, is it the coil lighting up, or actual gas burner fire? if its just the element from the ignitor glowing your going to need to replace the gas valve coils, they aren't releasing the gas, if its actually lighting, then your going to have a thermostat problem, thats the little disc's at the rear of that machine that regulate when the dryer is to open or close the heat ,, heres how you check them once the machine is unplugged Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. be sure and unclip the wires and note where each one goes prior to testing
Jul 09, 2011 | Kenmore Dryers
Have a Kenmore Elite dryer and the heating coils will not light I have 240 volts coming into the coils however tthey still wont light is it the themostates that are bad
you can bypass the thermal fuse, to see if it is bad. The fuse is a fire prevention safety feature so once it is determined bad disconnect the wires and replace before using.
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 27, 2010 | Kenmore Dryers
I have a Kenmore 70 Series Model/Stock NO 97576200 75762. The dryer will not start but when plugged in the inside light turns on. When i close the dryer door, the light stays on and nothing happens. My...
your correcto a mundo-thats what it is,the switch is a single-pole double throw and the contacts are welded together and wont switch when you shut the dryer door to run the unit
Oct 16, 2010 | Dryers
NO HEAT ON KENMORE ELEC. DRYER MOD. 110.64992300
There could be a number of problems with your dryer causing it not to heat. Here is a tip that I wrote about your problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
Heatman101
Mar 10, 2010 | Kenmore 64992 Electric Dryer
Kenmore gas dryer model 110 97576200 will not heat up
WHERE IS THE LINT SCREEN ON YOUR DRYER? ON TOP OF THE DRYER? IF SO, UNPLUG DRYER. REMOVE THE PANEL IN THE BACK, HAS NINE SCREWS(1/4 NUT DRIVER). THE FUSE IS A SKINNY TWO TERMINAL DOWN NEAR THE BOTTOM. USE AN OHM METER TO CHECK. IF NO READING, THE FUSE IS BAD, REPLACE AND HOPE NOTHING ELSE LIKE THE IGNITOR IS BAD TOO. GOOD LUCK...
BOYNISMO@YAHOO.COM
Jul 07, 2009 | Kenmore 75944 Gas Dryer
Kenmore 70 series model 97576200
You have a bad thermal fuse , usually caused by lint blockage from the filter or vent hose .
Jul 06, 2009 | Kenmore 659 Electric Dryer
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Gas dryer wont heat
You may have a blockage somewhere in your exhaust line. I had to have my professionally cleaned, but it fixed the problem.
Dec 11, 2008 | Dryers
Dryer wont heat
if you already replace the heating element . it may be loose or it get damage . you can open the dryer from the back . and ck if the 220v is coming in . or the thrmstate is no goog . most likely you heater when dad again. good luck . and let me know if you need to find any parts for it .
Apr 04, 2008 | Dryers
Dryers Logo
67 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
