Question about Whirlpool RF365 Electric Kitchen Range
Whirlpool R365 Large Burners won't work
The two large burners on my stove are unreliable. I have cleaned off the ends but that does not seem to work. One burner was working fine and then it just stopped in the middle of cooking. I have made sure that they are plugged in tightly, too. The stove is 16 years old. Does it make sense to replace the two large burners or could it be a voltage problem? Any help would be much appreciated. Thanks.
  • Anonymous Apr 12, 2009
    The large burners don't work anymore. Before they stopped working, we lost control of the ability to control the temperature. They would only operate on high. We have tried replacing the coils, which didn't make a difference and we checked the fuse box. Additionally, the lights indicating that the burners are on will not go off, even when the burners are turned off. We have to shut off via the fuse box in order to get the lights to go off. No problem with the oven - so far
    Scholar:
  • 112 Answers
The problem could likely be in the sockets that the elements plug in to. Over time, they lose tension and deteriorate. The replacement sockets are relatively cheap and easy to replace. If the connection ends of the elements are still in good shape, there is really no reason to replace the element.
Posted on Oct 19, 2008
Soot produced by propane heating stove
If it is still producing soot two problems blocked burners burning yellow causes soot , or blocked injectors, or pressure to burners is wrong needs seting to correct pressure
Feb 07, 2013 | Heating & Cooling
Hello. We have a Whirlpool Accubake range and we heard a pop and saw a spark under one of our 8" burners. What ever happened tripped the circut. After resetting the circut, the rest of the oven and...
I had a problem with my Whirlpool range. It would not regulate temperature properly on the two large 8" burners. I found the problem was the "infinite switch". The infinite switch regulates temperature of the electric stove elements.
I found this video (see youtube link below) informative and it solved my problem. I found the correct infinite switch on Amazon (my infinite switch was this $21.00 one: https://www.amazon.com/gp/product/B004XLEJ7M/ref=oh_aui_search_detailpage?ie=UTF8&psc=1). The fix to replace 2 infinite switches (both 8" burner switches) took me 1 hour, including cleaning the floor under the stove (nasty!). All was well afterward.
https://www.youtube.com/watch?v=F4gCWNdu2io
Apr 14, 2017 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
I have a Kenmore Gas range. The major stove top no longer gets really hot and we are having trouble boiling large pots of water. It used to be able to boil a large pot of water easily. I would like to...
This could be a problem with the gas regulator, gas supply pressure or the burners need to be cleaned. Here are the cleaning instructions for the burners. If you are still having problems with the burners I would recommend having the gas pressure & regulator checked.
Jan 16, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a Whirlpool electric range RF263LXTQ2- 2 yrs old-it gets so hot that the large burner pans are both charred black. Had it looked at about a year ago and couldn't find any problem-top and front of...
Since you are having problems with multiple elements the problem is probably the circuit board that controls them. This can be ordered and replaced. Be sure to unplug the stove before getting into the circuit board though.
Mar 13, 2017 | Whirlpool RF263LXTQ Range
Whirlpool burner doesn't work
yes this is called the receptacle you can order this part directly from marcone appliance parts or allbrands appliance parts and they will ship it directly to your door hope this helps
Jul 08, 2010 | Kitchen Ranges
GE range two large burners do not work. The two small burners work OK. One of the large burners has an obvious break in the calrod. Could it have blown a fuse or circuit breaker inside the stove that...
Burners went bad, Replace them. You may also have to replace where they plug into. Come problem with electric stoves. Easy fix! You can purchase at lowes, homedepot, or any appl repair parts store.
Aug 22, 2009 | GE JBP30 Electric Kitchen Range
Large electric burners not working on lowest "LO" setting
Unplug the range and remove the problem elements.
With a flashlight, look inside the element receptacle for burned or disfigured terminals.
If they are damaged they can be replaced.
If the element terminals are OK you have defective switches.
Mar 18, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
Jan 19, 2008 | Kitchen Ranges
Whirlpool RF365 Electric Kitchen Range Logo
386 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
