2 yr old toshiba satellite laptop. Original power adapter stopped working. Replaced with a Targus I got at Walmart. Was wondering if this could cause problems. Thank you
  • kathyjean56 Oct 20, 2008
    Thank you so much. I have another question... the sound quality is getting bad. It will crackle once in a while, and "cut out". Is is possible to replace something, or could this be the motherboard? Thanks again.
    Yes, I do. I know how to un-install and re-install the drivers. I should do that?
    Master:
  • 397 Answers
As long as the output voltage from the power supply is the same as what your laptop needs your good to go, but, also check the output "amps" you need the amps rating to be the same or more on the power supply. The laptop will only draw the amps it needs so if the power supply amps rating is higher no problem, but if the power supply amps rating is lower it could cause the power supply to over heat and maybe die on you.
If you are unsure please check with someone familiar with electrical ratings.
Posted on Oct 19, 2008
  • Richard Finch Oct 20, 2008
    With the sound problem the first thing I would do is reinstall the sound card drivers.
    Do you know what hardware drivers are? would you know where to look if I asked you to check "Device Manager" in the "Control Panel"?
    Un-install and then let Windows redetect the soundcard after a reboot is where I would start. Let Windows reinstall the hardware drivers automatically, if there is no improvement then try and do a driver update and let Windows look on the internet for updated drivers.
    Let me know how you get on.
Clear cmos toshiba laptop satellite L35-S2174
Remove coin battery for 2 minutes, Computer will default to original new computer status. Make sure the 2032 coin battery is good.
Dec 26, 2012 | Toshiba Satellite L35-S2174...
Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Oct 14, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
HI there! I am using a targus universal wall power adaptor for laptops, it has an output of 19.5 V and 90 W. I was wondering if I could use this to charge my UK laptop from ADVENT. The charger for this has...
The wattage is to different, the wattage for the adapter is 90watts, and the charge for the advent is only 65w.
You can always try it, but you risk damaging your battery, or motherboard.
Jul 16, 2011 | Targus APA30US AC Laptop Charger AC...
I have a toshiba sattelite l3oo and i have a problem with my charger. when ever i plug my charger the laptop will reboot(when starting. i can't start the computer when my charger is on. and when i'm using...
I had same problem with my Sattelite L300. Motherboard has a defect in one Proadlizer film capacitor exactly on the back of CPU, the original ref. is nec-tokin 0E907 (900uF/2.5V) or similar code. I've replaced it by 4 tantalum capacitores of 470uF/2.5V each and 2 capacitores of 220uF/2.5V, all in paralell mode in same old place of nec-tokin component.
Vote for me... :)3_10_2012_6_45_55_pm.jpg
Apr 12, 2011 | Toshiba Sattelite® A105-S2051 PC Notebook
I need an A/C adapter for my P25-S5262 Satellite laptop. Online sellers keep sending me adapters with a plug that is too small for the power jack. The latest seller wants to know what the "psp number" is...
ah its because at 6 years old the
Toshiba power source and power input plug you seek
has been discontinued and not superseded
A35 19v 6.3a 120w is a rare power source
one on ebay seller USA list this unit suitable for your
Toshiba Satellite P25-S5262
http://www.ebay.com/itm/NEW-Toshiba-Satellite-P25-P15-Laptop-AC-Power-Adapter-Charger-A35-19v-6-3a-120w-/401167479005
if not correct as in picture
you need to keep a look out online for sale any
used P25-S5262 with working power source
Mar 08, 2017 | Toshiba Satellite P25-S5262 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Power problem with laptop
The problem may be in the charger now. It could have shorted out. Do you see any lights on the unit when it is plugged in? James
Dec 30, 2008 | Computers & Internet
Targus ac70u adapter; 0% available, ( plugged in, not charging )
How old is your laptop? It may just be that you need a new battery if it won't hold a charge.
Further, this charger worked previously on this laptop and with this battery? If so, you definitely might be ready for a new battery.
Dec 29, 2008 | Umax ActionBook 333T Notebook
Power Adapter problems Toshiba Satellite A105
The problem may be with the receptical where your plug the ac adapter into. This is a common problem for many. Our company can repair this problem. For a quote just google "Laptop Guy" and you will see our company listed there. Mention Fixya and you can save $25 off the repair
Thanks
Todd
Laptop Guy
Apr 20, 2008 | Toshiba Satellite A105 Notebook
Gateway laptop not working
What is the problem with the notebook?
Do you get any lights on the notebook when its plugged in?
Have you tried another power adapter?
Dec 26, 2007 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
