Question about Vivitar V-2200GX Tripod
Vivatar V3000 tripod leg locks
My V3000 leg locks are cracking.....does anyone know of a repair source??
It should be cheaper to repair than purchase another tripod of same quality.
Thanks
  • N4TIS Apr 02, 2009
    Lower leg lock broken on a Vivtar V3000.
3 Suggested Answers
jessee007
  • 310 Answers
SOURCE: Vivitar V3000 Tripod
I might be wrong but it sounds like your wing nut screw or bolt is missing...look for a empty hole
Posted on Jan 01, 2008
  • 24 Answers
SOURCE: Vivatar Tripod V3000 Camera Attachment Adapter for Nikon D80
Try www.tripodquickrelease.com They have that exact model listed and the plate sells for $16.99
Posted on Jan 30, 2009
Manfrotto 3051 Leg Section Slips After Locking - How To Disassemble
www.bogentripodparts.com you may need a new leg lock, you have to loosen it enough and the leg should come out. Send us some pictures at email@spartanphotocenter.com and we will probably be able to set you up with something.
Aug 07, 2012 | Photography
Locking tripod leg
Sorry, the mechanism and how it is put together should be repaired my Manfrotto. It has a one yar warranty when you bought it, and if you went to the Manfrotto website and registered it then the warranty is 3 years.
Jun 09, 2010 | Manfrotto 458B Neotec Pro Photo Tripod...
I need two lower locking device for 2 legs on a V3000.
because of the age and the fact that Vivitar hasn't made that tripod in years, you will have to take the parts from an identical model.
Feb 25, 2010 | Vivitar V-2200GX Tripod
Leg slips will not lock
Although I'm not familiar with your particular make and model it sounds like a common problem which affects many other tripods. If the legs clamp with a lever action then if you closely examine each clamp as you activate the lever I expect that you'll find a small crack opens up in the clamp assembly.
It's a faulty design as the clamps simply aren't strong enough for the load and eventually crack due to fatigue. Some manufacturers supply replacement leg clamps but they also fail and fitting them usually costs more than the tripod is worth.
Next time, consider buying a tripod which has rotating collars to lock the legs with. They're not as quick to operate as lever action (a.k.a. "quick release") clamps, but they don't take much longer and last far longer. Rotating collar clamps are only suitable for tubular legs, and to be as rigid as extruded profile legs there's usually an increased weight penalty unless you spend far more on carbon fibre versions.
Personally, I tend to buy cheap but perfectly good non brand name lightweight tripods which I can get for £10 including a carry bag and handle and expect to have to replace them when broken: usually about once a year. It's a lot cheaper than spending over £300 on a good one and means I can afford to have a spare one in the car.
ALDI (in the UK and Europe) sell a £10 tripod which comes with a handle, carry bag, pan/tilt head,quick release leg clamps, geared centre column plus two quick release mounting plates and has a bag hook at the bottom of the centre column; it even has a no quibble three year guarantee. It's not a smooth or as well built as many, but can't be beaten at the price.
Aug 06, 2009 | Vinten 3770-3 Tripod
Plastic locks Vivitar V900 tripod are breaking.
the plastic locks on our vivitor 980 tripod legs are broken now can i replace them. jan
Mar 17, 2009 | Photography
I have a Coastar VTR-95RA tripod. Three flip locks cracked
Coastar has been out of business for at least 15 years, I do not know of anyone that has those parts since Coastar used shut down and went away. Unfortunately that tripod is no longer usable, unless you can find another with something else broken aned scavage the parts you need. Be careful to mathc the model numbers exactly as there were several different models starting with VTR-9... and they may not all be interchangeable.
Jan 10, 2009 | Photography
Jan 09, 2009 | Vivitar V-2200GX Tripod
I did not have any luck in locating the leg locking assembly for my Vivitar V3000. Instead, I plastic welded both that were broken on mine. So far, so good!
Dec 14, 2007 | Vivitar V-2200GX Tripod
Vivitar V-2200GX Tripod Logo
104 people viewed this question
Top Vivitar Photography Experts
JP Services
JP Services
JOHN TOPLISS
Are you a Vivitar Photography Expert? Answer questions, earn points and help others
