Question about Emerson NR305TT CD Shelf System
My Emerson NR305TT will not produce sound. Turn table works, CD Player works, FM Tuner Works, everything works except no sound comes from the unit. The on switch and volume seem to work as I hear a faint hum from the speakers when I turn the unit on. Any ideas on what the problem might be or where I can get it repaired?
  • 1,476 Answers
You have one of 3 problems:1) bad solder joints in the amplifier or preamp section 2)defective output transistors/ICs in the power amp or 3)missing or incorrect voltages to the amp section. If the unit has a headphone jack plug in a headset. If you have sound then everything is OK thru the preamp section and your problem is in the power amp. Any competent repair shop should be able to solve this one easily.
Posted on Jun 23, 2006
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
How to get the laser unit repaired/ replaced on my portable CD player?
Most likely cheaper to replace than repair. The labor cost for such a fiddly repair would be more than a new unit.
Jan 22, 2016 | Magnavox 45 Esp Jogproof Portable Cd...
How do I fix the FM tuner to pick up FM signals?
I think you might have fault in the FM tuner section. Most of these are done by a single IC, replacing that will cure the fault I suspect.
Jun 10, 2017 | Audio Players & Recorders
Everything OK, except no sound from the FM tuner.
You may have many different issues in the FM circuitry. Do any other FM stations come in?
If you are interested in having your Marantz repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
May 21, 2015 | Marantz SR6006 Home theater receiver...
I just installed one of these, and the FM radio works, but when I try to play a CD is reads and plays but no sound comes out of the speakers. I tried resetting the unit with no effect. The AV in has the...
It sounds like you are running your audio through an amplifier. If so, you are probably using the blue wire (antenna remote turn on) instead of the blue/white (amplifier remote turn on). The blue wire turns off when leaving tuner mode.
Mar 01, 2011 | JVC KD-AVX1 Car DVD Player
Marantz SR870 tuner not working
Make sure your FM antena connection is good. A receiver will not pick up an FM signal without an antena. Even a small piece of wire will work to test. If the Tuner section is bad, an external tuner can always be connected to an Aux input. Due to cost, it may not be cost effective to repair this unit.
Hope this helps.
Oct 08, 2009 | Marantz Audio Players & Recorders
No sound on coming out of speakers and theres no wires touching everything looks like it works fine
Make sure you didn't accidentally hit the mute button.
You should always test sound with a CD, testing sound via AM/FM will produce interference and almost no sound when between stations, also don't to forget to connect the antenna lead.
Check that the speakers are wired correctly.
Check that the sound controls are adjusted properly, i.e. Balance, Fade etc.
Good luck...
Feb 24, 2009 | JVC KD-G210 CD Player
Jensen head unit VM9311TS no sound from CD
Should wire HU's Power Const to Amp's Remote On. Instead you wired HU's Power Antenna to Amp's Remote On. So the stock amp got triggered only in radio mode.
Jan 24, 2008 | Jensen VM9020TS Car DVD Player
Gxm 30
Me too same problem, no audio with the XM. Do you think it has anything to do with Audio-Video out setting on the unit?
Dec 13, 2007 | Kenwood DNX7100 Car Video Player
CD 's work fine - NO Am or FM
sounds like the aerial has fallen out the back.
Dec 12, 2007 | Sony CDX-FW700 CD Player
Can't get B Speakers to work
Use the remote and switch it to be in the sub mode (top right corner of remote) It is here (in the sub mode) that you can change volume and inputs.
May 29, 2007 | Onkyo TX-DS555 Receiver
Emerson NR305TT CD Shelf System Logo
412 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
