Question about Philips GOGEAR SA6045 MP3 Player
4mb go gear mp3 player
When I turn on my mp3 player it reads file system error, it is brand new and is fully charged. What do I do??? =0(
  • 8,596 Answers
You can try running a Repair in the Philips Device Manager, but it will probably not work - get a replacement - either through the store or Philips. I can tell you exactly why the msg is coming up, but I've explained it so many times over the last year, i am tired of explaining so many times. just trust me. Run repair - when that fails - get it replaced.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
My brand new spi mp3 player will not turn on and it is fully charged.
Did you read the directions? If its brand new contacting the seller would be a good choice......
Nov 08, 2016 | Audio Players & Recorders
My jlab (same set) does the same thing...any fix for it?
It works only via USB to PC because that is not only the way to transfer MP3 files from your PC to the player/headphones, but one way to charge the player's battery. You can also charge the player with the USB cable by plugging it in a USB wall charger. So let it fully charge in the PC or the wall charger and then take it with you while you walk, work out, etc. There is nothing wrong with your player (maybe the fact that there is no indicator when it is charging and when it is fully charged ??).
Dec 28, 2014 | JLab Audio GO Waterproof MP3 Headphones...
I listen to the music for 1 hour. I turn the lock switch off. The next day the Go gear MP3 has completely discharged. I re charge it on the pc. The screen reads 'Fully charged'. The same thing...
There are two things possible.
1) You have defective re chargeable batteries in your GoGear.
2) There is some short circuit because of which the re chargeable cells are discharging.
Either way you should get the system changed. If you want to confirm if its the battery defect or GoGear. Charge the system fully and play music continuously. If the Go Gear plays for about 4 hours with out break---- its not the battery but the charging system.
Mar 14, 2011 | Philips GoGear SA3020/37 MP3 Player
NO ROOM LEFT ON MY Sansa M230
If you plug your mp3 player into your computer, and it shows up in 'My Computer' - try to follow these steps.
1 Right click on your mp3 player in my computer.
2 Click on Format...
3 From FIle system menu select FAT32
4 Tick the box that says Quick Format
5 Push Start
6 wait until this process completes.
7 Safely eject the device.  (http://support.microsoft.com/kb/165721)
8 Your mp3 player should now work. If it does not try to repeat the process except this time do not tick the box that says Quick Format.
Nick
Sep 01, 2009 | SanDisk Sansa m230 MP3 Player
Cant turn on 2 brand new fully charged music on
you need to upgrade your usb port go on the samsung website it will tell u how
Dec 25, 2008 | Samsung YP-U3 MP3 Player
System says fully charged when it is not
have you tried updating the firmware? Go to Samsung.com support > download center > type in the model number (yp-k5jab) click on firmware, and download the version that corresponds with your device. install the firmware updater on your computer, plug in your device. and flash the firmware. (this will erase ALL songs and settings so you will want to back those up first). After that its like brand new. Keep the updater handy, since this might crop up again.
Dec 23, 2008 | Samsung YP-K5 MP3 Player
How to remove fat error from rca mp3
try connecting it to your pc, format your mp3 player as fat32.. try if it solves the problem.. afaik FAT file system is limited to 2g..
Nov 24, 2008 | RCA JET S2002 MP3 Player
How to format raw sandisk 250 hard drive with window xp.i couldnot use this mp3 player after i used this device to transfer files from one computer to the other.after transferring the file,i deleted the...
Alright, plug the player in with your USB cable.
Open "My Computer" and find in on the list of drives and CD-Roms. It will be called something like "Audio Device" or "Removable Storage Device". Make sure you find the correctly icon for the player.
Right click the player then select the format option. You'll probably want to use a FAT32 format as it is the usual format for MP3 players and flash drives of the like. This will totally erase any files on the player, so be forewarned before you complete this.
Raw file system is basically the media in it's standard state. All the information is recorded as zero's and this is how your computer is seeing it. It is either reporting incorrectly due to bad file system error, or simple was formatted incorrectly.
Give that a try, let me know what happens. :) Hope it helps.
Sep 21, 2008 | Audio Players & Recorders
Error free 4mb of space to build music library and disney mix max won't play any songs?
The memory may be corrupt and it can't read the music files correctly. Open your My Computer icon and plug the player into your computer. You should see a new removable disk called Mix Max appear. Right click on the disk and choose Format from the pop up menu. At the Format window make sure that the File System is set to FAT32 and click Start. At the next window click OK to proceed. You'll then need to add the songs back to your player but it should correct the problem. When adding the songs to the player again make sure that you leave at least 4 megabytes of space available so it can create the library file.
Mar 10, 2008 | Disney Mix Max Digital Media Player
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Feb 21, 2008 | SanDisk Sansa m230 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
