Question about Samsung SMH7178STD Microwave Oven
Samsung SMH7177STE/BE I have had a Samsung Microwave for about 1 1/2 years. The door obviously has been (for lack of another term) leaking---it has a smoked filled area and usually goes away or drys after a time. It is now staying that way. What can I do to clean it and then correct the problem? (Samsung SMH7177STE/BE) Also my Samsung Number is not listed below thanks,
  • Samsung Master
  • 8,973 Answers
Is the hood vent exhaust fan running, and do you feel good air flow?
If not, please reply back.
If the oven is not venting properly, moisture can build up inside the cavity and door panels. This will cause a condensation or steam buildup that looks like smoke.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
As you're disassembling, be on the lookout for cracks. Once you clean it, if you've found any cracks, you can order Samsung parts here.
Posted on Oct 19, 2008
Looking for info on kitchenaid microwave
Your microwave oven is an old timer in terms of appliance years. It may turn ou that replacement is the only practical solution.
Nov 21, 2013 | KitchenAid Microwave Ovens
I have a samsung smh7177ste/be microwave that will not heat. Every thing seems to be working as normal
The problem is one of three things, the magnetron "common issue" or the high voltage capacitor and diode can be a factor, the above mentioned work together to heat food. Depending on the nature of the repair, parts and labor can run as high as a new microwave oven.
Mar 02, 2011 | Samsung SMH7178STD Microwave Oven
I have a Samsung SMH7177STE/BE I accidently hit the start button in stead of the timer for 30 min. When I went back into the kitchen the microwave was turned off. Thought maybe my outside curcit blew. I...
It may have tripped a high limit switch and less likely but possible it blew the fuse. A fuse blows due to an increase in amperage or a short. There is the possibility it melted components such as the door switches or a wire due to heating the cavity. Door switches pop fuses when shorted or the door doesn't engage them properly.
As most microwaves other than Panasonics contain capacitors you must be very cautious even when unplugged to avoid shock. 2100-4000 volt capacitor on the high side.
So where to begin is unplug the unit. Attach a wire to something grounded to bare metal on the machine. Open it. Look for burnt wires or components without touching anything. Discharge the capacitor using an insulated screw driver or tool (short the leads). Test the fuse using ohms Check the high limits (black disks the size of a penny) by testing across them using ohms. If the fuse is blown check out the door switches, some are closed with the door shut and others are the opposite. So test each switch in both door positions. Test the light wires to ground. Should read open. Test ohms on the whipper motor and fan and to ground as well. Reads measurable over the motor leads and open to ground. Test the capacitor using uF and compare to rating on the capacitor (be sure its discharged). Disconnect the magnetron. Test each lead to ground. It should be open. Its highly unlikely its the transformer or a computer board so i wont go into detail about testing those components.
Jan 20, 2011 | Samsung SMH7178STD Microwave Oven
I have a Samsung microwave model SMH7177STE/BE. Will only heat a few minutes before and shut off, now there is no heat. I am a licensed elect. but no experience with microwaves and having difficulty...
Its tripping a high limit most likely. Be careful there is 2100 to 4000 volt high side with a capacitor if its not an inverter. The standard components consist of noise board, fuse, touch panel and power controller, high limits, door switches, whipper motor, fan, transformer, capacitor, transformer, magnetron, diode, plate rotator.
Discharge cap (for safety and further testing).. Test fuse; if fuse tests blown test door switches first. Test limits. Check amp draw with slow blow fuse; open door to stop unit and again discharge capacitor. Test resistance to ground on whipper, fan, magnetron, light. Test resistance lead to lead (measurable on motors/coils/magnetron). Test capacitor in ferrads, compare to spec on print. Check diode forward and reverse. Test output voltage from power control board to transformer. Test transformer coils.
Best of luck and play safe; dont test voltage output from the transformer, voltage at capacitor or magnetron.
Aug 03, 2010 | Samsung Microwave Ovens
Over head fan not working
Since FixYa is not currently notifying us Experts when Clarification Requests are answered, you will need to post a NEW help request.
I
n your new post, please include your brand name and the full model number from the tag in or on the unit, your symptoms, as well as the answers to these questions:
- have the cooktop lights recently failed?
Oct 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turns off after 1-2 seconds
It turned out to be the three door attachments that weren't lined up. It has been fixed. We almost bought a new one because Samsung referred us to a service that would have charged way too much to be worth it even thought the machine is only 3 or so years old. Luckily, we looked further. A local independent appliance fixer came to the house and took care of it within a few hours of my call! Yea!
May 29, 2008 | Samsung SMH7174BC Microwave Oven
Samsung microwave
Leaking of current , the door isolation current are leak need to replace non conductor material
Dec 27, 2007 | Samsung MW1030WA Microwave Oven
Fan vent door not working
First of all, if it's less than a year old, it will be under warranty and you should contact Samsung to cover the service. You can try the number in your manual or try samsung.com
There is a drive motor that opens and closes the vent fan door. It or an associated switch may have failed.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number (SMH7178STD) at http://www.wehaveparts.com
Nov 15, 2007 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
595 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Gerry Harvey
Gerry Harvey
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
