Question about Pentax Optio 60 Digital Camera
Pentax optio 60
I can turn my camera on but the shutter does not open and then I get lenses error. The camera will automatically power off. What do I do to fix this problem?
  • 215 Answers
Your shutter is driven by a small motor attached to the lens assmbly. It could be that which has died or more likely you have a sticky shutter. A small knock or a drop of soda can stop them from opening. Try switching on and very gently with a cotton bud see if you can help open the shutters. Whatever you do don't force them and force them out of shape. You may have to do this a few times to get in sync with the power up sequence but if you can get both shutters to open fully you should be in business. If they keep sticking I've seen one guy glue them open. Personally I'd rather fix them so they do their job.
Posted on Jul 12, 2006
To repair the obturator the lens its a fixed lense how to open and fix it?
To open the mechanism you need firts to take out the front group lens (sometimes loosing 3 screws placed around the front ring).
After you take the front gropu out there is a nut that holds all the shutter unit attached to the camera. Turn it to the left to placed it out and then take the mechanism off. Be sure the are no other parts connected between shutter and camera before pull it out.
Oct 13, 2013 | Mamiya Vintage Auto-lux 35 Camera W/ Sekor...
When you turn the camera on the lense opens and the camera shuts off with the lense still open. I turn on again and the lense closes and then shuts off.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 30, 2011 | Pentax Optio 60 Digital Camera
Can't take any photo with my Canon S3IS any more. The view finder and the screen is black when I try to take some photo but I am able to see all photo that is already on my memory card in the view finder...
Look into the lense while setting the shutter speed at a half second or so (slow enough for you to see the shutter open and close) and click the shutter release... you should see the shutter open and close. If you don't see this, then you may have a 'sticky shutter' resulting from lubricant seeping into the shutter/aperature mechanism and preventing the shutter from functioning as it should.(Common problem reported with the S2 and S3 cameras... and probably the S1 as well)
I have gotten my S3IS to take pictures by turning on the power, then opening the battery compartment door and reclosing it repeatedly until the shutter opens (from the power surge) and an image appears on the LCD.
After confirming the sticky shutter was indeed the problem, I pursued a more permanent fix.
Jan 30, 2011 | Canon PowerShot S3 IS Digital Camera
Pentax optio E75 lense will not go in, camera says lense error
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101;'
Dec 12, 2010 | Pentax Optio 60 Digital Camera
When i turn on my camera the lense extends but you can not see thru neither the lense or the remote screen. please help
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 15, 2010 | Canon PowerShot S2 IS Digital Camera
Lens protection error
its probably that you batterie is old and weak. the charger has more power. the camera use the maximum power absortion, when you turn on.
to first prove with a new batterie, or better if you have a friend that have the same camera , prove with here batterie, to see if the problem is in the batterie. if i have understand you, the camera turn on only with the adapter.. make this prove. if you want i will still help you.
Jun 03, 2010 | Cameras
Lens error
then its the problem of lens....i suggest you to get sony cyber shot i am using my camera for 4 years still not even 1 problem occured.
Aug 09, 2009 | Pentax Optio 60 Digital Camera
Pentax Optio 60 Digital Camera Logo
128 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
