Question about Gold Medal 2121 Econo Popcorn Maker
Replacement Kettle assembly for Gold Medal 2121 Econo-pop 14
I have an Gold Medal 2121 Econo-pop 14 for which I am trying locate a kettle assembly. Any information as to where I could find one would be appreciated.
  • Anonymous Jan 16, 2009
    I have an old (20 years) econo popcorm machine. There is an electric al cord that is bably damaged and needs to be replaceed. Do you have these in supply?
    Master:
  • 363 Answers
If you want to know more things about RSGold can go to this website www.rsgoldfast.com
Our service is the most professional and most secure and convenient
Posted on Nov 16, 2016
Gold medal products co.
800-543-0862
10700 medallion dr
cincinnati,oh 45214
www.gmpopcorn.com
Posted on Feb 03, 2009
Adjusting the thermostat for best temperature
There is a adjusting screw on the thermostat. So your not guessing you should heat it on a. Bench with a amp meter on the line . Then check temp and adjust from there. The factory thermostats are. Preset . If you installed the correct one adjustment should not be necessary? Is the element tight on the bottom?
Jul 30, 2016 | Gold Medal Products Gold Medal 2388 8 oz...
Why is it taking a long time to start popping, not popping completely, and leaving excess oil?
Sounds like the kettle isn't getting hot enough. The thermostat is usually at fault in this situation which can be determined by checking the amp draw on the kettle. the common complaint is the kette is too hot and burning but what really is going on is it's not hot enough so the seed won't pop. Because of the heat that is there it will loose it's moisture, dry out and burn instead. You will end up with lots of old maids . Really stale corn seed will act the same way because all the moisture in it is gone and thats what is needed to pop it.
Feb 14, 2016 | Gold Medal 2121 Econo Popcorn Maker
Why is my gold medal popcorn model # 2552 machine not heating to pop popcorn anymore?
A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
http://www.gmpopcorn.com/domestic-dealers.cfm
Oct 01, 2014 | Gold Medal Kitchen Appliances - Others
I need to find a replacement kettle for the 2014 gay 90s whiz bang popper
Any Gold Medal dealer will be able to find one. There are 3 different styles depending on the age of the popper.
It is always cheaper to repair Gold Medal kettles, replacements are very expensive. That model they run $750-$1100.
Contact Gold Medal to find your local dealer for service. 1-800-543-0862
Feb 04, 2014 | Kitchen Appliances - Others
How do you clean
There is a kettle cleaner available from the factory.
Jan 24, 2014 | Gold Medal Products Gold Medal Econo...
I have an econopop 14 and the stirrer gears jump erratickly and dont turn the stirrer when popcorn is put into the pot . everything seems to turn free . What would you suggest doing ?
This is a really old question, but.
Check to verify that the needle bearing is not missing. I is a small round part above the gear on the agitator shaft. Also see how worn the crossbar bushing is. There should only be a minimum of loose play in the shaft moving it side to side.
Make sure the lid assembly is not installed backwards on the kettle casting. The lip part of the kettle is the front or left side, and the cord should come out of the bottom towards the doors/operator side.
Jul 27, 2012 | Gold Medal 2121 Econo Popcorn Maker
I need a replacement motor for my popcorn machine. Motor # 3724up-180. Where might i find one?
Hi and welcome to FixYa, I am Kelly
Not sure where you got your part number from as it appears to cross to the 14 oz kettle assembly.
The motor PN 47038 is for the model 2121 and it is $69.75 + shipping
Go to this page: http://www.gmpopcorn.com/store/Details.cfm?ProdID=89&category=5 and enter your model number or start here: http://www.gmpopcorn.com
Motor picture:
http://www.gmpopcorn.com/store/cw3/assets/product_expanded/47038.jpg
Thanks for choosing FixYa,
Kelly
May 05, 2011 | Gold Medal 2121 Econo Popcorn Maker
8 oz kettle does not heat would like to price replacement kettle
try this link
http://www.vendingmachinesworldwide.com/gold-medal-2014-***-90s-whiz-bang-popcorn-machine-kettle-receptacle-replacement-part-gm49330.aspx
hope this helps
if its not the part you require email them ,
there really good
VendingMachinesWorldwide.com, Worldwide Markets, LLC
2630 Ladue Cove
Fort Wayne, IN 46804
Email us for all inquiries
customerservice@vendingmachinesworldwide.com
hope this helps , if it does please vote
Nov 09, 2009 | Gold Medal 2131 Antique Gay 90s Pinto Pop...
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Sep 01, 2009 | Gold Medal Kitchen Appliances - Others
Gold Medal 2121 Econo Popcorn Maker Logo
1,384 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Oloyede Monsuru
Ted Maxwell
Coss
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
