Question about Sharp Aquos PZ-50HV2U 50 in. Plasma Television
Sharp Plasma PZ-50HV2E
I have a PZ-50HV2E and it turns off on its own. Sometimes it runs for the whole weekend with no problem. Other times it will turn off after exactly 15 minutes. If I try to immediately turn it back on it will not come on. If I turn off everything, unplug from power socket and wait 30 minutes. I can turn it on and it will then turn off in exactly 8 minutes. Same procedure, then the time is reduced to around 3 minutes. The strage thing is I get an E1 (Check Correct Cabling) on the screen before it shuts down. But I have checked cables a 1000 times but no change. Any advice? Not looking forward to boxing up a 50" to sedn to the repair shop.
  • Anonymous Apr 26, 2009
    I have the same problem with my Sharp PX-50HV2U. I was told that it needs a new switch. Anyone know if that will sove this problem? Hate to spend $$$ on a new switch if that will not correct this.
  • 208 Answers
SOURCE: Sharp aquos lcd screen goes blank
The problem is most likely the the screws are loose on the inverter boards. The screws must be tighted as they provide the ground to the inverter bds. The inverter boards are undet the shields on both sides of the unit after pulling the back cover. One way to make sure that you are losing back lights and not video is when your picture goes black, shine a flash light on the screen at an angle and will see the video is still there. This mean the back lights are out. If you do not see the video it may be another problem
Posted on Feb 05, 2008
  • 4 Answers
SOURCE: Sharp Aquos turns itself off
My LC37D6U had this problem, thought that I was going **** at first, came to find out that there was a firmware issue with the system. I got ahold of the updates for my particular system and just applied them. ** issues turning on and off now, just the sound going dead after 18 months.
Posted on Mar 09, 2008
  • 8457 Answers
SOURCE: power light blinking green and cannot turn off or display anythin
power inverter board is dead.
need a new one.
Posted on Sep 14, 2009
SOURCE: sharp 46 aquos model LC46E77UN tv turned off power
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
Posted on Jun 04, 2010
micromatikal
  • 2777 Answers
SOURCE: Sharp Aquos LC42D62U with blank black screen, good
Unfortunately not really, it is the video board of the LCD that has failed, it is a major repair to say the least. You can check with a local repair shop to estimate the repair, but it will be spendy :(. I'm so sorry about the bad news there, but that's definitely what it is. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
Thanks Tim
Posted on Oct 03, 2010
Pz 50hv2
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/ Error code details to many brand TVs are given.
Jan 08, 2014 | Televison & Video
How to repair the psu board?
It has no repair. Must be replaced as card basis.
Aug 19, 2012 | Sharp Aquos PZ-50HV2U 50 in. Plasma...
Green light comes on for 3 or 4 secs, then yiu hear power off and it returns to standby
Hello
Power regulator board inside it has damaged. In most cases, this board is irreparable due to unavailablity of components. Replace the board as card basis. Especially plasma TV boards are very complicated in circuit nature, and cannot be repaire without getting proper components. No substitutions will go on with these power supplies. So replace the power supply board with same type and number. You can get it from Authorised Service Center for Sharp at your town. OK.
Jun 23, 2011 | Sharp Aquos PZ-43HV2U 43 in. Plasma...
E01
This is directly from the manual
Page E-66
E 01 = System cable connection
System cables are not properly connected. Check that all system cables are connected properly.
See page 12.
http://sharp-indonesia.com/manual/Plasma%20Display%20Panel%20%28PDP%29/PZ-50HV2,%20PZ-43HV2,%20PZ-MR2M,%20PZ-MR2X/pz50hv2x_au.pdf
Mar 02, 2011 | Sharp Aquos PZ-43HV2U 43 in. Plasma...
My Phillips plasma when turned on, turns itself off straight away. Any ideas? All the repair places are closed over the weekend. Now does not turn on at all.
Tries tv unplug,replug tv back about an hour later.By letting tv resetting itself back to the factory setting.Now the tv should be working again.If still have the same problems.The power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Try website like Ebay.com to guy a whole refurbish power supply board for the replacement.
Jan 07, 2011 | Philips 42PF9966 42 in. HD-Ready Plasma...
Light flashes green than a code E06 and E01 comes on than tv off
E01 is relay contacts failure on psu board in media box
Parksy HK
Now someone find E06
Nov 22, 2008 | Sharp Aquos PZ-43HV2U 43 in. Plasma...
No power
It could be a fuse and be aware the fuse is on the power supply. It most likely is a failed power supply.
Jan 04, 2008 | Sharp Aquos LC-PD50U 50 in. Plasma...
Sharp Aquos PZ-50HV2U 50 in. Plasma Television Logo
93 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
