Question about Sony 27IN TV Stand Designed for Model KV-27FS120
Sanyo TV 29 Inchs
The Tv sound ok, only i can see whitish screen with horizontal line from side to side. any suggestion to what is the fault or cause, or how to fix it
    President:
  • 3,130 Answers
Sounds like you lost your video. Causes could be a vodeo switching IC, a PIP module if the set has PIP Or a fault in the video jungle IC. To fix this problem I would highly recomend you take the set to a trained service person, as there are safety issues to deal with , as these sets hold alot of hi voltage even after the sets unplugged. Better safe then sorry. Good Luck
Posted on Jun 19, 2006
Sanyo TV model T27547 has horizontal lines across the top of the screen in front of what is being showed on tv. Is the tv worth trying to fix the picture is still very good.
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 02, 2017 | Sanyo Televison & Video
Sanyo dp50747 plasma tv is only showing in the middle of screen no video blue square showing horizontal 20 inches wide.The outside of square is blue solid both sides inside the square fuzzy lines red,...
It is line fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 17, 2014 | Sanyo Televison & Video
Sanyo tv has a horizontal line running across screen
Sep 23, 2014 | Sanyo Televison & Video
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
TV screen has a thin horizontal line in center
this will only help until the next time it is out of alignment but if you slap the side of your tv about where the line is it should straighten out but there is no telling how long it will stay straight......My sons tv was doing that and i had a tv when i was young that did it that is what my mom told me to do and what i told my son to do and it works.... the problem is an alignment or conection problem from dust most likely.
Jul 11, 2012 | Sanyo Televison & Video
A thin white line horizontally in middle of screen At first could wiggle the cable conection on back of tv and it would go back to full screen now it won't
it sounds like you have horizontal colapse a very complect repair try hitting the tv if the screen comes up full picture then its a dry joint if not there is an ic or power fault toss it
Jun 18, 2010 | Sanyo DS25390 TV
TV BLACK SCREEN WITH THE POWER ON.
It needs repair.
If the line is vertical, then something is damaged on its horizontal circuit section on the mainboard.
If the line is horizontal, the vertical circuit section is damaged.
have it repaired to a qualified service center or person!
avoid switching it to avoid further damage on other parts!
May 28, 2009 | Philips 32RF82S TV
Gray screen with horizontal lines accross it
sounds like you may have a bad ic it probley is a surface mount on the bottom of the board it could couse this problem would need to take to a shop to repair. The ic probley is numbered ic101 on board.
Mar 01, 2009 | Sanyo DS32224 TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Standby light flashing
This is possibly a sign that there is a fault condition. Short circuit line output transistor
Jan 23, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
309 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
