Question about SanDisk Sansa e250 MP3 Player
Trouble shoot my sansa
I have sansa 2gb mp3 player when i on the player i see only sana express then noithing is coming pls help me to slove the problem
  • Anonymous Oct 22, 2008
    I have the same problem. It worked for a few minutes today but now it will not turn on. Also mine does not seem to have a battery or if it does I don't know where it is
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
Hi please helpe me? my sansa disk it forget progerams? what update? i need sanas disk thanks for you
go to website connect to computer and get firmware(software in mp3) updated. SanDisk Sansa Clip Mp3 has guided instructions!!
Nov 06, 2010 | SanDisk Sansa Clip MP3 Player
My sansa 2gb mp3 player has got software corrupted
my sana 2gb mp3 player keep asking to synchronise
Sep 20, 2009 | SanDisk Sansa Clip MP3 Player
Sansa express 2GB not working, cant update too..
Try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Mar 02, 2009 | SanDisk Sansa MP3 Player
Micro sd probelem
Well, the most memory from a micro sd card the Sansa mp3 player can take is 2gb, because anything more will freeze up the player because it was not designed to read that much memory. So if you have a 1gb or a 2gb memory card, then you can use them.
Mar 01, 2009 | SanDisk Sansa MP3 Player
Need driver
There was no driver software on the enclosed cd.I downloaded the software thru a google search.That put my sansa mp3 in good working order.Thanks .
Salscimemi
Jan 22, 2009 | SanDisk Sansa m240 MP3 Player
Sansa express 1 gb
There is a power button on the side of the player
The user manual is available from Sandisk's website:
http://www.sandisk.com/Assets/File/downloads/user-guides/express-userguide-en.pdf
-Tha Mp3 Doctor
Dec 08, 2008 | SanDisk Sansa e250 MP3 Player
2GB SANSA Express
You may need to get either a memory stick to go in the available spot, or if you do not already have one and do not want to spend any money, get a paper clip and carefully stick it in the slot and it should come automatically.
Oct 28, 2008 | SanDisk Sansa MP3 Player
SanDisk Sansa Express (2 MB) MP3 Player QUIT WORKING
i tell you connect to the computer your device
and right click on your device and format it
Jun 09, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
