FixYa.com
Tags:
La Crosse K2-100 Wrist Watch
Incorrect altitude changes
posted by stud on Jun 18, 2006
First, I am aware of the changes in barometric pressure affecting the altitude readout. That's how the altitude is calculated in these watches. However, after a year of satisfactory use with very accurate altitude reading (I usually calibrate the altitude measurement at a trailhead or when I'm at a summit) this watch no longer works. I get an altitude change of around 200 feet or so for a real altitude change of around 400'. I may get a change of 1/2 the actual change in elevation. Very frustrating. I was going to trash it but I couldn't understand why the altitude readings are so far off when the barametric pressure readings are accurate? And they are VERY accurate! I've changed the battery - no difference. Also, the graph no longer functions for altitude. I guess you get what you pay for but I feel let down by this watch. Any help?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 14, 2007
Not Rated (0)
Noggin
Rank:Guru Guru
Rating: 87%, 1463 votes
Here is the link to the user manual for this watch if you need it;
http://www.lacrossetechnology.com/k2100/...
page 12 gives you all the contact details for lacrosse.
I couldnt find the info online to be sure, but some of these watches do have a separate pressure sensor for altitude and barometric pressure, and sometimes the path to one could get blocked or it could become faulty.
I would contact la crosse and find a dealer to get the watch serviced, you could probably do it yourself but you need to get replacement seals from them anyway (these are important).
ask them to check if the sensor is clogged, it happens sometimes.
Hope this helps :)
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Watches problems?
Watches
i440
Watches
I have a battery operated
I have a battery operated wrist... Answer This...
Watches
Need to make an expansion
Need to make an expansion watch... Answer This...
broken wrist band
where can i get a replacement... Answer This...
broken writ band
my watch's black rubber wrist... Answer This...
Repair Service
Find Watch Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
