Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
603 will not stop running liteas blinking!
Both drawers will not stop running red lites continues blinking powered off shut water off no results can any body help?
  • 136 Answers
Try resetting it, unplug for 1 hour and then plug back in, another thing is check your manual or go to their web address
Posted on Oct 30, 2008
Top drawer stops, will restart if I push start
Sounds like a micro switch problem to me, telling the dishwasher that the drawer is open when it is not actually open.
Dec 26, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Dishdrawer door comes ajar
It is also likely the drawer has come off the gliding rail at the right.
You will have to pull the drawer out from the housing and check. Not sure if you have a standalone unit or integrated with the kitchen cupboard. The instructions to pull drawer out are available in the installation manual. Select the correct model from this site .
Dec 08, 2013 | Fisher and Paykel 24 in. DS-603 Built-in...
Red and orage lights are on - continuous beeping
It would be helpful if you are able to record the lights that are blinking.
Most likely the flood switch at the base of the diswasher under the bottom drawer has tripped. There is water leakage caused either by a broken hose or broken drawer lid seal.
The easiest way to confirm is to turn the power off at the power socket and shut off the water inlet tap. Pull open the bottom drawer and use towels to dry off the base. Use a hair dryer to fully dry the base. The flood switch is located on a small circuit board in the middle of the base. Wait for a couple of hours and then turn the power and water inlet back on. See if the beeps stop.
Dec 18, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bottom drawer does not stay shut
open door and look under countertop to see if your bolts are tight to hold your dishwasher in place?
Apr 09, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
DS-603 lights keep blinking, won't stay turned on.
Hi. I am unable to help you fix your problem, however I have just had this problem with my dishwasher exactly the same model. I was wondering if you have fixed this problem yet and if you have how.
May 26, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Dishwasher "F1 and a small wrench symbol" blinks continuously
The unit has a leak causing floor sensor activated.
1- Unplug power cord.
2- Pull oull half way the drawer so an access from the bottom left could be obtained.
3- Use Paper towel or small towel to dry out the water on the bottom housing.
4- Wait for 48 hour so the sensor can be dry out.
Plug in the power cord. The unit will act as normal.
Your problem is solved.
However you can't operate since you know you have a leak problem. Let me know how it in progress and you decide to call service to fix it or I can guide you to fix it. Good luck.
Apr 05, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher Paykel double drawer dishwasher DS6031
you have an overflow leak problem....shut off circuit breaker or pull fuse....let it dry out for up to 4 days; hopefully overnight; peak under dryer and feel metal drip pan and if wet you might be able to dry with a hair dryer...WHY? the lid did not seal when you put cycle on...the lid lowers and you had something..typically too bid glasses on second shelf that was above the seal lip of the tub...stack correctly after this and no worries...
Sep 21, 2008 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & paykel double dish drwer
The code is a water leak problem.That is the warning
May 15, 2008 | Fisher and Paykel 23 in. DD603H SS...
I have a DD603 bought used, put in the upgrade kit. But now it goes into pause several times during a load. It happens on both drawers very very anoying.
Oct 30, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
