Question about Rio Cali Sport MP3 Player
Is there a size limit to the size of expansion card that the Cali will accept?
I inserted a 512 MB expansion card in the slot and when downloading a playlist, I get an error message stating that there is not enough room for the download.
  • 175 Answers
Yep you've ran out of space.
Posted on Jul 04, 2006
    Problem Solver:
  • 11 Answers
Possible that there is not enough internal memory free to support the reading from the expansion card
Posted on Jun 18, 2006
SOURCE:
RAM upgrade on Packard Bell Columbia mainboard
you can only use as much as the motherboard are made for.
May 01, 2013 | Computers & Internet
Can I add 1 gig of ram to an old Vaio PCV-RX280DS with Ubuntu Linux installed?
no, i'm sorry the maximum amount of ram the motherboard will recognize is 512 mb, it's not an OS limit it's a MOBO limit
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Mar 15, 2012 | Sony VAIO PCV-RX280DS PC Desktop
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I have a Bushnell trailscout 119900 and it wont accept any other SD card but the one that came with it. The one that came with it is only a 512 MB chip card The ones I have been trying to use are 2 GB SD...
Probably the first thing to try is formatting the card. There should be a function in the setup menus to do this. If it won't format or gives an error when you try the card may be incompatible. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. Some cameras have a capacity limit, and won't work with cards that are too large (in memory terms).
Oct 30, 2010 | Bushnell Trail Scout 11-9500c Digital...
I am trying to expand memory by inserting 2 PC3200 (DDR400) but total amont of memory size does not changed (still 512 MB) First slot (DDR1) APACER-512 MB Second slot (DDR2) LG Electronics - 1GB
Take the stick of 512 out of the motherboard and insert the 1GB stick in DIMM 1 slot and switch the machine on. If it comes on check whether it has registered it as 1GB. If it has turn the machine off and just put in the 512 stick.
If the machine won't boot up with the 1GB stick then it could be faulty or the motherboard doesn't support 400MHz (which it should).
Regards.
Oct 20, 2010 | Asrock 775VM800 Motherboard
Hi... Can you help me in the software of my pc the Video Controller (VGA Compatible) It was gone when I was reformat the PC. Motherboard Manufacturer: Company Name Micro-Star International Motherboard...
Field Value North Bridge Properties North Bridge SiS 661FX Revision 11 Memory Timings CAS Latency (CL) 2.5T RAS To CAS Delay (tRCD) 3T RAS Precharge (tRP) 3T RAS Active Time (tRAS) 5T Memory Slots DRAM Slot #1 256 MB (DDR SDRAM) DRAM Slot #2 512 MB (DDR SDRAM) Integrated Graphics Controller Graphics Controller Type SiS 330 Mirage Graphics Controller Status Enabled Graphics Frame Buffer Size 32 MB AGP Controller AGP Version 3.05 AGP Status Enabled AGP Device SiS 330 Mirage Integrated AGP Aperture Size 64 MB Supported AGP Speeds 1x, 2x, 4x, 8x Current AGP Speed 8x Fast-Write Not Supported Side Band Addressing Supported, Enabled Chipset Manufacturer Company Name Silicon Integrated Systems Corporation
Jul 16, 2010 | Microsoft Windows XP Professional SP2
I wanted to upgrade the memory on my pavilion zt1130 notebook from 256mb so I purchased to 512mb memory cards and replace the resident memroy under the keyboard. It runs faster but as soon as I put the...
According to Hp website your computer will handle two 512 Mb RAM chips. Make sure they are PC133. If computer will not boot with both inserted properly, one of them is bad. Put one in slot 1 and none in slot 2 and see if it boots. Then switch the chips put the extra chip in slot 1 and none in slot 2. See if it boots. This way you can troubleshoot a possible bad chip.
Aug 15, 2009 | Office Equipment & Supplies
Just need to know how to change the ram in my Sony Vaio PCG-v505ap
visit vaio manual in
ftp://ftp.vaio-link.com/pub/Manuals/Notebooks/
You can do this in two ways: opening your notebook and taking a look on the memory modules already installed (we will explain more about this later) or running a program like Everest (available on our download section). We ran Everest (going to Motherboard, Chipset, Memory Slots) on our notebook and found that it was using two 256 MB DDR-SDRAM PC2700 (“DDR333”) modules, for a total of 512 MB.
imageview.php?image=1680
click to enlarge
Figure 1: Checking your current memory configuration with Everest.
If your notebook has an empty memory slot, just go to the computer store and buy a new SO-DIMM module with the same technology (SDRAM or DDR-SDRAM) and speed of any capacity you want – of course you need to know the capacity limit of your notebook. You cannot install a 1 GB module in a notebook that only accepts modules up to 512 MB, for example. Our notebook – a Sony Vaio PCG-V505ECP – accepts modules up to 1 GB, for a total of 2 GB RAM, since it has two memory slots.
For example, if your notebook has one 256 MB module and an empty memory slot, if you buy and install another 256 MB module, it will have 512 MB RAM. If you buy and install a 512 MB module, your notebook will have 768 MB.
If your notebook already has two memory modules, you will need to remove one of the installed modules in order to install the new one. If the two modules have the same capacity, it doesn’t matter which one you will take away, but if they have different capacities, remove the one with smaller capacity. The new RAM capacity of your notebook will be of the capacity of the remaining module plus the capacity of the new module.
In our case, our notebook has two 256 MB modules. So we will remove one of these modules and install a new one on its place. We bought a 1 GB-module, so after installing it our notebook will have 1,280 MB RAM installed (memory math is tricky, since 1 GB equals to 1,024 MB not 1,000; so 1,024 MB + 256 MB = 1,280 MB).
else visit
http://www.hardwaresecrets.com/article/189/1
Jul 02, 2009 | Sony VAIO PCG-V505DXP Notebook
Inspiron 2200 Memory Module not recognised
Are you sure its the correct speed/type of RAM? According to Google your laptop takes PC2700 DDR RAM, ensure you are using this in both slots to avoid problems. If you have it fully inserted into the slot and nothing happens when you swtich it on then the laptop doesnt like that type of RAM and you'll need to change it.
May 17, 2009 | Dell Inspiron 2200 Notebook
I want to upgrade my HP BA 600 Mother Board`s RAM Capacity
Most likely your MB is too old for this upgrade although there is a chance you could flash your bios (reprogram your computer's brain to accept the new memory providing hp has a flash for it).
here is a link for the latest bios flash for your computer, use at your own risk.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=32895&swItem=vc3903en&prodNameId=20305&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0
good luck.
Thank you,
agadycom
Nov 27, 2008 | HP Computers & Internet
Rio Cali Sport MP3 Player Logo
171 people viewed this question
Top Rio Audio Players & Recorders Experts
Marvin
Marvin
Joseph Hoffmann
Andrew Taylor
Andrew Taylor
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
