Question about Hotpoint Washing Machines
My Hotpoint TC71 condencer drier has sheared its rear bearing post.It had been going scrape for sometime but didn't get around to looking at it until it snapped! Can get a rear bearing kit but just wondered if you could advise with the dismantle / reassemble sequence? Thanks
  • nick541 Oct 19, 2008
    I want to get a copy of the service manual but all I have found to download is the user instructions. Where can I get the dismantling guide?
    Genius:
  • 1,550 Answers
I have found a model close to your model . The link for downloading the service manual is provided below
Service manual
Posted on Oct 19, 2008
    President:
  • 2,712 Answers
You could try this:
http://www.appliancepartsworldwide.com/Store_Part.aspx?Id=501952
Its not free though..sells for US $12.95
Or here:
http://www.appliancerepair.net/dryer.htm
for $19.95
  • Swilin Sampson
    Swilin Sampson Oct 19, 2008
    Bsically follow these steps:
    • Old Style: First, remove the several screws holding the top down and then the bottom two screws Then remove the drum center bearing clip, unstring the belt, and remove the drum.
    • New Style: Remove the top panel retaining screws, pop the top, and then remove the inner front panel screws. Unstring the belt and remove the drum. Here’s what it looks like with the drum removed. There are two variations on this dryer that affect how you restring the belt. Variation 1 has a rear access panel through which you can restring the belt. Variation 2, however, does not have this rear access panel. (Thank you, GE
      ) To restring the belt on this sorry excuse for a dryer, remove the
      phillips screw inside the rear exit opening of the blower duct and
      remove the duct. Then restring the belt from the front.
    A specific HotPont/GE service manual can be found here as well:
    http://www.repairclinic.com/SmartSearch/...
    Hope that helps!
    Dont forget to ACCEPT the solution if it helped you!
    Master:
  • 538 Answers
Time, patience, and a copy of the service manual. did you get one of those yet?
  • Hotpoint Master
  • 19,396 Answers
I have replaced the belt on my Hotpoint vdt00 dryer but the belt seems to pull the drum on to the motor causing a scraping noise and its hard to turn around. their dosnt apear to be a bearing or anything...
look inside the drum is there three screws on the very back wall of drum,there is a bearing there,remove the belt,slide the drum forward and look at the back of the drum,there should be a shaft sticking out that slides into a slot that looks like a U in the back wall,that is the rear bearing that you get in a kit if you hear a loud squeaking sound that's the problem,if you sent the model number i could of told you the part number
Jan 31, 2010 | Hotpoint Dryers
Hotpoint tc71 trips ele every time I turn it on
I would suspect that the heater or thermostat./s are the cause of the prob.
Remove rear cover, and disconnect the heater and stats, and try again.
If it still trips, then you probably have got something more serious to contend with.
Please rate my solution.
thanks.
Nov 08, 2009 | Hotpoint TDC32 Electric Dryer
My hotpoint tc71 drier blows the plug fuse when switched on what is the problem please
boy the list could be very long but this dyer draws a large amount of current (amps) it should be on its own circuit nothing else on the line at least when the dryer is running you said "fuse" if it is blowing a fuse as opposed to a breaker you could try a Time Delay fuse 15 amps might help please do not put a larger fuse in (even though it fits) the wire size dictates the size of the fuse and increasing fuse size with out changing the wire size to accomodate will create a fire hazzard good luck
Oct 23, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint dryer squeaks at regular intervals
Slow squeaking or scraping noises are often from the rear bearing behind the square panel, the rear bearing sleeve is inside the middle of the heater housing and the shaft part is attached to the back of the drum by a "C" clip which needs to be removed first.
The disassembly slideshow is here:
Slideshow
Sep 26, 2009 | Hotpoint TDL15 Electric Dryer
OCCASIONAL Metallic scraping noise - New ceramic brake pads.
You could be right with the wheel bearings. But first take the wheel off and check that nothing is scraping the rotor. Look all the way around the rotor. A suggestion will be that the brake pads have worn enough that the brake pad wear indicator is starting to scrape. Pry them back a little.
Apr 09, 2009 | 1996 Buick Regal Olympic Gold
Hotpoint ultima condenser dryer TC71 is running cold
Thermostats rarely go. You could have a bad heater or even a voltage problem. Even if the dryer runs, the voltage can still be wrong, it only needs 110 volts to start the motor but must have 220 to have heat.
Apr 06, 2009 | Dryers
Drum wont move
Check the motor and the belt on the back of the unit behind the rear plate. Make sure that the belt is attached and the motor is spinning. If this helped please rate. Thank you
Feb 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint tumble dryer is making loud scraping noise like the drum is catching against one the panels
This sound is caused by the drum tilting towards the rear panel just above the heating element housing and is due to the drum spindle wearing through the bearing. (Which can lead to it shearing off) after it`s cut it `s way into the bearing support bracket. A new rear bearing kit is needed. it will come with a foam support which is stuck on to the inside of the back panel as the drum rests against this when turning. the foam support on your dryer may have perished or gone flat due to the heat from the element and that is why your hearing the scaping sound. new foam ring from the bearng kit will cure the scraping.
Sep 10, 2008 | Dryers
Hotpoint washer dryer leaking water whilst drying
driers work by running cold water down the back plate of the machine so the hot damp air condence's on to it. It works on the same principle as your bathroom mirror, because its colder than the air around it the moistier in the air condence's on to it. Most machines use a seperate inlet valve from the cold water to do this, they are proned to rub against the back of the drum.Take the top cover off the machine and check the hose's from the cold inlet onto the back of the machine you'll probably find a hole worn in it.
Oct 21, 2007 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
124 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
