Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
MY MACHINE SHOWS E 1 WHEN I SWITCH ON AND KEEPS BEEPING
    President:
  • Whirlpool Master
  • 2,651 Answers
Assuming you have a dryer ,you have a bad thermistor assy locatred behind the lower access panel part number 3976615.
Posted on Oct 27, 2008
I have a fisher and paykel fridge freezer - the problem being once fridge is opened it keeps beeping and on the front panel it shows a spanner flashing
sounds like the door opening switch must stick. find the switch, should be visible near the hinge area of the fridge and spray some wd-40 into the housing. that might work!
Jul 03, 2016 | Fisher and Paykel Refrigerators
We have a Fisher and Paykel washing machine model MW509NZ. it keeps going into error with Leds 3, 5, 7 and 8 illuminated and a beeping noise. What is the problem please.
That is fault code 43
Here is the info for 43
43. (00101011) Phase 1 to 6 - OOB Switch Fault
The Motor Controller module has found that the signal returning from the out of
balance switch indicates that the switch is permanently on or the harness to it is
disconnected.
Primary Source: Mechanical.
Action:
1) Check that the out of balance switch is free to move.
2) Check that no harnesses are blocking switch movement.
3) Check that the switch operates correctly when activated. Replace the switch
if suspect.
4) If the out of balance micro switch shows signs of corrosion, replace the
switch and switch harness, and fit a condensation kit to the console area if
not incorporated in the top deck.
5) Check the level of the machine and also the bias spring.
Secondary Source: Wiring.
Action:
Check the harness to the switch is connected correctly. The terminals should be
connected to the normally closed position. If the harness terminals show signs of
corrosion, then fit a new harness.
Aug 06, 2012 | Fisher and Paykel Washing Machines
I have a singer futura it keeps stopping and beeping also shows the #19 red light every few stitches I have rethreaded everything checked for any bunched up threds in the machine/bobin yet the proble
You can download the manual here
If the thread is properly routed and so is the bobbin thread, there may be some issues with the bobbin assembly. Try cleaning and oiling the system per the manual then re-threading both the top and bottom threads via manual instuctions. if no change then there may be an issue with the thread tension sensor
Nov 02, 2011 | Singer CE150 Futura SewingandEmbroidery...
Fisher & paykel - SPIN light keeps flashing and machine beeps
could be a faulty off load switch
running off balance
machine not level
depends how old the machine is then
if none of those
worn machine motor or internals
might the the circuit board
Apr 16, 2017 | Fisher Paykel EcoSmart GWL15
Installed and it shows code 1 and code 7
We frequently see this error due to a failure on the control board. If so, we may be able to repair it for you at www.fixyourboard.com.
Jul 10, 2009 | Amana Kitchen Ranges
Fisher&Paykel Smart Drive 051 keeps beeping/not draining
Hi, I have the same problem and for my wahsing machine it is block pump, so I turn the machine on and advance it to spin and turn the pump fan to help clear the block, the pump locate at the buttom of the basket of the machine...
Mar 31, 2009 | Fisher Washing Machines
Keeps beeping and shows F3 but keypad not working
Ya what the ????
Not shure what to tell you, first I would see if leaving unplug for a day would solve your problem, to me sound like main board is defective, also try by opening the door a closing it a couple of time, just in cass a switch is jam open.
Regards
bob
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Fax machine beeping - Samsung SF5100
YOUR PROBLEM IS NOT VERY CLEAR,PLEASE TELL WHETHER--- A. DO YOU GET DIAL TONE ON THE MACHINE? B.WHEN THE MACHINE GETS INCOMING RING -IT IS SET TO ANSWER ON HOW MANY RINGS ? C. SWITCH OFF THE DRPD MODE. D,CLEAR THE MEMORY OF THE MACHINE TO FACTORY DEAFULT BY--SWITCHING ON THE MACHINE WHILE HOLDING THE STOP BUTTON AND THEN COOSING YOUR COUNTRY WHEN PROMPTED. SHOULD TAKE CARE OF THE PROBLEM... HAPPY FAXING OMNIPRESENT
Sep 25, 2007 | Office Equipment & Supplies
Faulty door which keeps beeping
The door could be closed physically but the not electricity because a defective lid switch that should be replaced. Good luck!
Nov 01, 2006 | Hotpoint WMA76 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal De
