Question about Zenith IQC50H94W 50" Rear Projection Television
No Pic or Sound
Turned on my set that had just been working fine and there is no picture or sound. Slight Electrical odor when turned on. Also a "chirping sound about once a second. LED DP37 blinks in unison with the chirping sound. What broke??
    President:
  • 3,130 Answers
It sounds like a defect in the horizontal drive or HI voltage circuit. Could be the Horizontal output transistor , and /or the flyback transformer, a short in the scan derived power supply on the output of the flyback transformer. If your not aware of the HI VOLTAGE issues and have soldering experience you should seek a pro to assist ya in this repair. If you do have the experience, get a schematic and start with the hi voltage circuit. Good Luck
Posted on Jun 18, 2006
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
May 13, 2017 | Sony Televison & Video
Sanyo dp50747
sounds like a mainboard problem
Jan 31, 2013 | Sanyo DP50747 50 in. Plasma TV
Sound no pic. after on for 20min then turned off back on and pic. now it will not get pic just sound
Your TVs CRT socket is faulty. CRT socket is one that connect the base of the picture tube, and can be located on the base card of the tv. It is soldered directly to base card and can be replaced. Unplug the base card from the picture tube neck [Caution: never damage the neck of the picture tube. Only slight pressure should be applied], desolder it out and replace it with a similar type.
Oct 16, 2010 | Norcent Technologies2703 27" TV
I have no picture. Sound & Signal are working
It seems back light inverter board is not producing voltages to lit the back light inside lcd panel to show the picture on lcd screen.
Please replace back light inverter board to get tv fixed. Local tech will help you if you are not familiar with tv repair.
Thanks.
Apr 03, 2010 | LG 42LB4D 42 in. LCD HDTV
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
It was working fine then no picture dark sceen sound work fine
More information is required. Your backlight is lit (screen not dark) but I need to know what you have connected to the TV (your sources) and how they are connected. Does the menu/OSD (on screen display) work?
Oct 19, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
No pic No sound
your bulb is connected to all the audio
the bulb blew out and you need to have it replace local cuircut city has a repair man on call for this
Feb 16, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
TV working, then suddenly no picture, no sound
could be flyback transformer cracked need replaced 48.00 for part or board replacement usually done at about $200.00 , part number is 9-2022
Nov 24, 2007 | Zenith A25B33W 25" TV
No pic No sound
I would call PTS at 18008447871 and find out how much a new deflection board cost, because by the time you find out what is wrong and start replacing things you will be out more money. Not including the smell that means probably the flyback was burning or arching.
Sep 19, 2007 | Televison & Video
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Zenith IQC50H94W 50" Rear Projection Television Logo
82 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
