Question about Sony RDR-VX420 DVD Recorder/VCR
Message appearing 'The Disc can neither be played nor recorded'
I was recording a short programme onto a disc that already had things on it. When I pressed the Stop button the machine appeared to freeze and I had to turn the Recorder off at the switch and turn back on again. when i reloaded the disc, the message ' the disc can neither be played nor recorded' appeared on the screen and the message 'Disc Err' appeared on the Recorder. Does this mean that everything recorded on this disc has now been lost?
  • Gabigabi Nov 15, 2008
    I've got almost the same problem here. I've recorded some stuff off tv on a disc which has already some recordings. I had never a problem playing it so far until the last recording. But I didn't notice an error after that recording. Only the next day, when I wanted to turn the recorder on, it wouldn't accept the disc any more (the disc can neither be played nor recorded".
    Please help. Thanks in advance.
    Gabi
SOURCE: Discs I have recorded I get the disc can neither be played nor recorder, and it erases what I have already and already watched.
I have the same unit. Similar problem but mine does not erase the disc. It says disc error on almost all dvd that are store bought and kicks them out. Will play almost all of the ones I recorded on it and finalized. I must let a disc in it at all times or door will not open. Lots of bad stuff on the net about this unit. It is a lemon! Mine is out of warranty and sony wants $175 to fix. Saw some blogs where it was serviced 3 times and still not right. Buy a new one before investing in the unit you have as there are many gremlins in it! Sorry I cannot offer specific help but this is where I am at!!
Posted on Mar 11, 2008
SOURCE: Lite On LVW-5045 DVD Recorder - won't record onto disc
Liteon lvw 5045 problem action failed.please consult our customer service for recovery. (error code: 0x810D0004)
Posted on May 10, 2008
MediaMan85
  • 163 Answers
SOURCE: sony dvd recorder gx210
Without much more info the only thing I can think of is the lens is not homing correctly. If you are comfortable opening the unit, check to make sure the lens can move freely (from center to outside of disc). It's OK to gently move the lens with the unit unplugged.
MM85
Posted on Jul 25, 2008
SOURCE: I have purchased a Teac HDR2500T video recorder. I
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Posted on Sep 06, 2009
rulds2008
  • 3866 Answers
SOURCE: Can't get rid of dirty disc error message at 1 min
Ok you might need to have it cleaned professionaly worse comes to worse have the lens replaced, something ether got on the lens or the laser is not reading or writing correctly. Can it be fixed? Sure depning on the problem inside I could not tall you 100 p[ercent as I have not looked at the unit.
You might want to take a gander inside and see if the lends is not dirty.
Thanks an please rember to leave postive ratings and feedback.
Posted on Apr 12, 2010
I was wondering if you could help us with our DVD recorder. Its a Toshiba DVD Recorder Model: D-R18DTKB and up until recently has been in good working order. A while back I bought some Sony+RW...
Hi Tony
Although I am a member of this site I came across your post while searching Google for answers to the same issues as you are having.
From what you say and what I have tried I can only put fault with the DVD recorder itself and probably the LASER.
This thing just seems to hate reading recorded media of almost any format including those which it's stickered front panel boasts about. It also doesn't leave you with many other options as there is no USB port either.
I dont use the unit to record or the Freeview facility and never have as we have Sky+ and no TV ariel.
I bought it for the varied formats of video it says it can play but out of 6 different formats that I recorded onto DVD with my PC (and I am an advanced user and work in I.T) it only played back one and badly which was a mpeg-1.
I put the same 6 disks into my sons (apparantly DVD only) player bought from ASDA for £15 and it played 4 of them perfectly as good as the originals!
Logically this would suggest this model is a Lemon. I just hope your not a £130 light lemon as I am!
Oct 27, 2010 | Televison & Video
I need a manual Sharp DVRW550U DVD Recorder / VCR Combo.. when i record into the dvd it say that i cannot recorde into this dvd i already try so many diferent one and it say the same thing.. when i think...
I have three possibilities for you. One obvious answer would be that you are trying to record onto either a CD-R rather than a DVD-R, but I'm assuming that's not your problem. The second would be that you are trying to record onto a dvd that your recorder doesn't support (i.e. DVD-RW and your recorder only supports DVD-R). The final possibility is that the disc is a "dud." I have had this problem before and just had to try another disc. Good luck and let me know how it turns out, will you? Der Strom
Apr 02, 2010 | Sharp DV-RW340U DVD Recorder/VCR
My DVD recorder doesn;t record. When I go to replay there is nothing on the Recorded list. (The message PSO is showing on the front of the recorder.Is this coneected?)
Ok recording is impossible.
1.this unit may not record programs that contain copy protection signal.
2.Check that there is nothing on the disc to start off with.
3.check that the disc is CPRM compatible.copy onc programmes can only be copied onto the disc which is CPRM compatible.
4.check if the the disc is protected or finalised.Undo the protection or the finalisation.
5.DVD-RW usually once formatted in another unit cannot be recorded in your unit unless formatted.
6.Check all connections are properly made.
Oct 18, 2009 | Televison & Video
Dvd recorder can't read disc it previously read
Take the Disc out and put it aside. You must clean the Laser Eye, and clean dust and other matter from inside your recorder. Clean Eye with rubbibg alcohol and q-tip. A regular CD/DVD cleaner disc will not work. After cleaning, reinsert your Disc and Finalize it.
Jan 02, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
Sony dvd recorder gx210
MM85
Jul 25, 2008 | Sony RDRGX210S DVD Recorder
Samsung dvd recorder
Make sure you have finalised the disk, otherwise it won't play back on other players. Also there are two standards that you can use to record onto disks, video mode or VR mode. Video mode was the original standard but it wouldn't let you edit or add anything to the recording afterwards but it is more compatible with other players. VR mode allows you to edit the recording but is less compatible for playback on other players.
Mar 28, 2008 | Televison & Video
Recording DVD's on Samsung DVD-VR320 Recorder
See if a shop will clean the optical assembly for you at a reasonable cost. Also, if you have the "finalization" feature turned off, this will cause a disc to show that message...accordianman
Feb 25, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
My samsung dvd-hr735 now region free wont let me record onto dvd
Could be your using the wrong disc.
type is DVD-R where - is a minus as distinct from DVD+R
Feb 09, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Philips DVDR75
Try a lens-cleaning DVD. If the problem persists, the internal drive will probably have to be replaced.
Nov 29, 2007 | Philips Recorder DVD-R72
Sony RDR-VX420 DVD Recorder/VCR Logo
144 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
