Error code SE on LG washing machine means what?
I've got an LG washing machine WD(M)-80230FB.
The machine is not working and the display is flashing SE.
But when I look in the Owner's Manual in the Troubleshooting Guide, there is every letter under the sun, but no SE!
What does it all mean!
To top it off, I'm goin on me hols tomorrow, in dirty troosers.
Help!
Much appreciated,
b I have the same probleme on LG WD-1090FB
  • 1 more comment
  • disabel Nov 03, 2008
    This solution solves the problem.
    Thank you
  • Anonymous Mar 22, 2014
    Hi ,my LG washing machine was working well for 20 months.Only few days back it got stuck at the spin point.How to solve this problem??
    Hi ,my LG washing machine was working well for 20 months.Only few days back it got stuck at the spin point.How to solve this problem??..
    Problem Solver:
  • 16 Answers
SE is a sensor problem as per LG support. I will post a follow up after I have recieved the technician in 2 days
Posted on Nov 03, 2008
I can repair these speed sesnsors
Posted on Jun 20, 2010
2 Suggested Answers
geemarie
  • 876 Answers
SOURCE: Error code SE on LG washing machine means what?
It probably means System Error. Have you tried a simple reset. Pull the machine away from the wall carefully, make sure you do not have wet hands or feet, etc and unplug it from the wall. Leave it unplugged for 20 minutes. (Also check to see if it is plugged into an outlet with a little red button on it? is the button pushed in? It should be? ) After the wait, plug the washer back in and see what you have. I hope this helps.
Posted on Aug 15, 2008
I need a troubleshooting manual for an LG intellowasher 7kg wd-1274FHB which is displaying an SE error code.
LG error code SE LG washing machines displaying error code SE are indicating a "motor fault" although the technical information also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and not too helpful, especially for a DIY repairer so you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you interpret that as buying and fitting a new motor, they are very expensive. You need to at least know how to test a motor for faults and check its connections and carbon brushes (if fitted) if you want to try and diagnose the cause
Nov 23, 2016 | LG Washing Machines
Hi I've got Washing Machine LG WD-8023FB front load, and SE or 5E alarm is on and machine is not working. What is that alarm for?
the alarm is indicating that the machine is not working that u should restart it or better still u check the mabual for p[roper operation
Jun 24, 2011 | LG Washing Machines
My lg intello wd 8074fhb washer will be in the middle of wash cycle and an error message comes up se ..Can you tell me what this error message means..
LG's 'SE' means 'sensor error'. Sorry but you will need a repair visit I fear ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 12, 2011 | Washing Machines
Hi there My frontloader washing machine display
LG washing machines indicating error code CL may have the child lock activated. Try holding down the temperature and eco/rapid options together to turn off child lock.
Mar 08, 2011 | LG WD-1280FHD Front Load Washer
LG WD-14401TB SE error code
the motor position sensor or the hall sensor part number is
6501KW2002A
May 05, 2017 | LG Washing Machines
Error "SE" on LG WD-14381FBB
That is a system error code. Try to unplug the machine for 20 minutes to reset the program module.
Jul 31, 2009 | LG WM-2277HW Front Load Washer
SE ERROR ON THE WD-12235FB
Error SE is a sensor problem as per LG support.
you need to change the senser of your machine...
Good Luck!!
Thanks for using FixYa!
Sep 08, 2008 | LG WD-1280FHD Front Load Washer
LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Aug 02, 2008 | LG WD-1280FHD Front Load Washer
May 22, 2008 | LG Washing Machines
Washing Machines Logo
3,347 people viewed this question
Top Washing Machines Experts
