Question about RCA G27303HP 27" TV
Remote not working correctly
Remote up or down buttons make channel jump from 3 to 70. From 70 thru 76 work OK. Can get all channels by entering channel number. How can I get it back to going up or down 1 channel at a time? I just had Time Warner Cable connected here yesterday ( with a cable box). And the cable box quit working too.
    President:
  • 3,130 Answers
It all depends on what and how the cable box is connected . Do you have an outside or inside antenna connected? If you have a cable box , why would you want to go to another station on your tv? Does the cable box have an rf output that connects to the tv through he antenna input on the back of the set? If so the tv should stay on a station to recive the stations thru the cable box. Didnt the cable tech explain how to use the system?? If you dont understand how to use the cable you should, for sure call the companey, and see if they can explain how they hooked up your sysytem as theres many many ways to do this. If you have the owners manual what im about to explain is in there too. On the tv remote theres a button called menu, press it once. Use the up and down arrows to scroon down and highlight the setup . press the ok or enter buttonpress the right language,then search for channels. When this is over then exit out of the menu, and try switching channels. If you still dont have any channels you gonna have to find out whats connected to your rf input as channels wont come in if theres not the right source connected. GOOD LUCK
Posted on Jun 18, 2006
Unable to enter channel number to change channels....To change channels, I have to go thru each channel with the arrow button...
You might want to check your remote battery.
It is possible that:
1. The battery is bad, correct it by simply replacing it with a new one.
2. If the battery is okay, check the battery connectors or terminals in the remote. If it is rusted, try get a sharp object and clean it before reconnecting the battery
3. If none of the above solutions correct your problem, then you may want to get a new remote control
I hope this helps
Mar 04, 2017 | Televison & Video
Toshiba 27A33. I can't find the manual channel button. Only the on/off button and volume buttons...
assumming your remote has a keypad with a bunch of numbers 1,2,3, etc those are the channels you press the combination of the channel number you want and press enter...sscrolling up and down thru the channels is probablymore what you want, and that should be located by a set of signs wghich has horizontal or vertical arrows right nex to each other...
Sep 09, 2014 | Toshiba 27A33 27" TV
Hi, i have 14 "
As I see it, your problem has something to do with your remote. I bet you have pressed the "auto search" button of your remote that's why your TV keeps on searching channels automatically from channel 76 down. Here's what you've got to do:
1. Get your remote control
2. Turn on your TV.
3. Press the "auto search" button to stop your TV from automatically searching channels.
4. In case it works, I'd advise you to look for channels manually using the number buttons or the "previous" or "next" buttons.
5. If it doesn't work still, contact your technician or your service provider about it. They are of great help for you!
I hope it helps. Thanks a lot.
Jul 23, 2011 | Televison & Video
I am having trouble getting my RCA Universal remote to work with my Sanyo 1080i tv... I need to change the aspect ratio...
you can do this without a remote if you have a menu button on the tv you can fix it from there. if no menu button the press the channel up and down buttons at the same time and the menu will appear. if you can not find the tv code for the remote(IF its a universal remote) then you dont need the code you just follow the steps to enter the code But dont enter a code just keep pressing the channel up button on the remote until it turns the channel on the tv when it does STOP hit the enter/ok or similar button on the remote a your remote will work like new on your tv.Hope this helps you out or atleast gives you an idea.Best of luck to you!!!! Good day
Jan 02, 2011 | Sanyo DS31520 31" TV
Need intructions how to program remote control on vip722k second receiver
Press and hold down the SETUP button located on the remote. Wait until the INDICATOR light turns on. It will blink once the button is pushed, however once you see the indicator light stay one, release the button. Click the button to the DEVICE you wish to program. If it is a TV, then click the TV button. If it is the cable box, then click CBL button. After doing so, the indicator should still stay on. Press the DOWN CHANNEL button several times until you see the RECEIVER yo wish to program respond. Example: If it is a TV, then you will notice the CHANNEL change once the remote locates the correct settings for that receiver. If you see the receiver respond and you are pushing the down channel button but nothing is working, it means you passed the internal settings of the remote to the receiver. Try pushing the CHANNEL UP button slowly. It may be able to relocate the the proper settings. Once you see the channel change again, press ENTER to program the remote. If this fails, retry the same steps. In some cases you may miss the correct internal settings.
Nov 23, 2010 | DISH Network IR Remote Control
Sharp TV-Remote not working correctly
You will need to complete a channel scan from the tvs menu. I assume you have basic cable and that your cable company is still providing analog channels for you to be able to pick up any transmission on this telvision with the digital changeover and all.
May 05, 2010 | Sharp 27C-240 27" TV
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
Charter MOXI Remote doesn't work with Sony Bravia 42'' Flat Screen
Hold down the moxi and ok button until the remote flashes twice,then enter 9910. The remote will then blink twice again.Then go back and fourth pressing the mute button and the up arrow key(the one above the ok button)this will go thru all the codes,when your tv finally mutes,press ok that means you found the correct code.Hope this helps
Mar 26, 2009 | Sony Televison & Video
RCA 27" home theatre, parantal controls
You need a remote a $7 GE universal will work good.
Resetting Your Password
Press VOL+
on the remote and the
CHANNEL + on the front of the TV at
the same time. Enter New Pwd.
will
appear on the screen. (You must be in the
Enter Password screen when attempting
this.)
Press the number buttons to enter a
four-digit code.
The code will appear on
the screen as you enter it.
Press OK to save the code.
Press MENU repeatedly
to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
control.
May 04, 2008 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
87 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
