Question about Garmin nuvi 205 GPS Receiver
System software missing
New Garmin NUVI 205. I used the Garmin Webupdater and it removed the OS. I can not find the fix on the Garmin site. When I try to use their updater I get a "Corrupted File" Message
  • 2 more comments
  • rjbenfield Nov 08, 2008
    I have the same problem. It starts to boot with the Garmin screen and then reboots itself. It stays in this constant loop. Worked fine just the other day with no patching or anything else. It just started behaving this way. I tried connecting to my PC and was able to trick it long enough for my PC to see it but I got an error about a corrupt update. Help please!!
  • einstein1973 Dec 01, 2008
    My name is Henk, I have the same problem, could someone pls help. My email is henkvdm@lantic.net
  • rich_woot Dec 28, 2008
    I have the same problem. I ran through the setup and it was working fine. Garmin then recommended registration and update. Everything appeared to be working fine then the screen went blank and now says systems software missing. I can find no fix on Garmin's webpage and that have limited assistance hours.
  • Anonymous Mar 31, 2009
    Dear Alex,
    The link is dead, could you upload it somewhere?
    Thank you
The fix is actually pretty simple. Contact Garmin customer support they will send you the fix in an email. The file is a zip file that you unzip to your desk top then you just follow the instructions. I would recommend keeping the file on your desktop just in case it happens again. Once the system is restored then the updater works properly.
Posted on Feb 11, 2009
  • 3 Answers
Hey!
I just got an answer from Garmin Support Germany and they sent me an file which fixed the problem. Just download http://e-trex.info/fw/nuvi/2x5/nuvi205_085101000280en.rar
It contains a "Updater.exe" and a file called "085100010270.rgn".
Follow the following steps and you should have your nüvi back.
Firstly connect your broken nüvi. Then drag and drop the 085100010270.rgn on the updater.exe. Choose USB as a connection and it should put an old firmware back on your device.
I hope I was able to help you!
Alex
Posted on Dec 04, 2008
Open the webupdater and just reinstall the software,click reinstall System software missing - 0ac8987.jpg
I have a garmin nuvi 200 and a 205 about a year old, both will not turn on.
Not being able to start up is a sign that the system software or firmware of your Nuvi has become corrupt.
I can help you fix your Garmin Nuvi 200 & 205.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
Feb 25, 2010 | Garmin nuvi 200W GPS Receiver
Tip
Garmin Nuvi 265WT Webupdate Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Does your Garmin Nuvi 265WT GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Backup & Restore Nuvi 265WT Favorites here.
Download Nuvi 265WT Manuals here.
Garmin Nuvi 265WT Hard Reset here.
on Apr 19, 2010 | Garmin n?vi 265WT Car GPS Receiver
Tip
Nuvi 265W Webupdate
Garmin Nuvi 265W Webupdate
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 265W GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Download Nuvi 265W Manuals here.
Garmin Nuvi 265W Hard Reset Here.
Garmin Nuvi 265W Favorites Backup here.
on Apr 18, 2010 | Garmin Nuvi 265W GPS Receiver
I have a garmin nuvi 205 and when i power it up, the only thing i can get is a small block that says system software missing
You can restore the Nuvi 205 system software to its factory condition by running Garmin's WebUpdater service. You may also want to try a hard reset of your Nuvi.
I hope that helps.
Jan 09, 2010 | Garmin nuvi 205W GPS Receiver
When powering up nuvi 205 it says system software missing
To replace the system software of your Garmin Nuvi 205 run WebUpdater to reinstall the firmware.
I hope that helps.
Jan 09, 2010 | Garmin nuvi 205 GPS Receiver
Tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Download Nuvi 255W Manuals here.
Garmin Nuvi 255W Hard Reset Here.
Garmin Nuvi 255W Favorites Backup here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 200W Webupdate
Garmin Nuvi 200W Webupdate
I hope that helps.
Download your Garmin Nuvi 200 Series manuals here.
Download your Garmin Nuvi 205 Series manuals here.
Garmin Nuvi Hard Reset Here.
Garmin Nuvi 200W Favorites Backup here
on Apr 17, 2010 | Garmin nuvi 200W GPS Receiver
System Software Missing on Garmin Nuvi 255W
Take a look at this site, http://www.garmin.be/missing.html Download and unzip the software, plug your garmin in the USB and start the updater.exe program. It gets you started again. Later on you can use the Webupdater to get possible newer software..
It worked for me and my Zumo550
Goodluck
Auke
May 25, 2009 | Garmin nuvi 255W GPS Receiver
Tip
How to Perform a WebUpdate of the Garmin Nuvi 205 and 205W System Software
Does your Garmin Nuvi 205 or 205W get stuck or freeze at startup or when loading maps?
One trick to try when your GPS is acting up is to perform a Hard Reset.
Occasionally, your GPS may not start properly at all, and display a 'System Software Missing" message. Today's tip will describe how to restore your Nuvi GPS system software using Garmin Webupdater.
  3. Run the WebUpdater program to install it to your PC and update the system software of your GPS.
Your Garmin Nuvi should be running as good as new.
on Jan 17, 2010 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 205 GPS Receiver Logo
4,016 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
