Question about Sony KDS-R60XBR2 Television
Green overall tint
I have a KDS-R60XBR2. Its over a year old. I recently replaced the lamp (SONY XL-5300) with one provided by the seller. The screen was getting dark and the warning on the screen said that I should replace the lamp. I did. After a few weeks the screen darkness is back and now I get an overall Green tint (bad on the faces). I tried changing the tint to red, but thats not much help, still has an overall green cast.
I read through the Sony book and it suggests that I replace the lamp, again. Thats a bit high priced as solutions go. I read here that possibly a connection is loose, So where do I get access into the location of the BB connector? I'm willing to open up the back of the set but don't want to compromise the front surface mirrors if I have to get near the optical path. Any suggestions on opening up the set?
  • Anonymous Apr 16, 2009
    same problem! I hear that a repair man has a specific tool that corrects it in under ten minutes...costs 200 bucks with out warranty though...
  • Cdavid1959 Apr 19, 2009
    picture has a greenish tint and no adjustments help
  • 320 Answers
There is an extended warranty on the optical block which is causing your problem. Contact Sony directly at 800-222-SONY to arrange to have a technician look at the TV and have the optical block replaced. Sony is covering parts and labor for this repair. For more information visit the Sony website
Posted on Oct 19, 2008
I also had a strong green cast with this set. The color was most pronounced in shadows. This can be fixed by going to and ordering the training manual (not the service manual). The last several pages of of the pdf describe how to use the remote to get the set into service mode. Go to the fourth category and then into the wb (white balance) area. I ended up adjusting the green BIAS (not green GAIN) from the initial setting of 128 to 45 (or so). A few other very minor adjustments by eye and the picture is better than new. Total cost about $15.
Posted on May 17, 2009
  • jean Oct 02, 2012
    I cant find the training manual on this website. Has anyone else been able to locate it?
Power error 6 times - 11V is low. - No picture/No sound
From my past experience, yes. Not sure about the 11v being low. My kdf 45 acted that way when the main lamp went out. Found a replacement on Amazon for around $45 and now good to go! So far about a year and a half. Have had to replace about 4 for friends and family so far with same symptoms. All worked great!
Dec 11, 2013 | Sony Kds-r60xbr2 60" Xbr Rear Projection...
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
Aug 04, 2012 | Sony KDS-R60XBR2 Television
It now has a green tint -- will replacing the lamp solve that?
I have the same problem. I'm pretty sure the lamp will not take the green tint away, for the green comes from a problem with the optical block.
Jan 20, 2011 | Sony XL-5100 Projector Lamp for Grand WEGA...
Sony wega KSD-R60XBR1 green screen that can not be adjusted no matter what input is used or adjustment through onscreen tv options. how do i knw if it is the color wheel, light engine, or just a bulb
It is light engine problem in your Sony KDS-R60XBR2 lcd rear projection tv.
This tv does not have any color wheel because of its light engine technology.
Lamp is just light source that provides bright white light to light engine and its working properly.
Light engine will be replaced to fix green screen problem.
If you tv model is other than above mentioned, let me know to revise this answer.
Hope these info will help you.
Nov 17, 2010 | Sony KDS-R60XBR2 Television
Picture color is off after circuit breaker tripped. Only blues and greens. Model SONY KDS - R60XBR2. Does the lamp do this when it needs replacing or could something else have blown when the breaker...
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 26, 2010 | Sony KDS-R60XBR2 Television
Green tint on screen
2006 Model Year SXRD Televisions:
Models: KDS-50A2000, KDS-55A2000, KDS-60A2000, KDS-R60XBR2, KDS-R70XBR2
As part of the Sony commitment to quality, Sony is announcing that it is extending the limited warranty (parts and labour) in Canada on the optical block of 2006 model SXRD televisions (models listed above) until June 30, 2010 , regardless of purchase date. This extended warranty does not apply to replaceable projection lamp and other parts that may be used in the televisions.
Sony is also announcing that for any owner of these model SXRD televisions who paid out-of-pocket expenses on or before December 31, 2008 for an estimate or repair service to replace the optical block, Sony will reimburse the customer by mail for the cost of the optical block and the labour expense to replace it, subject to certain conditions. To receive reimbursement, please follow completely the directions on the claim form for reimbursement attached HERE; all claims must be postmarked by January 31, 2009. See the claim form for complete terms and conditions.
In addition, for any customer who later experiences this issue on one of the affected models, Sony will cover the cost of the optical block repair (parts and labour) at no charge through June 30, 2010.
For customers currently under a 3rd party extended warranty or service contract, please contact your third party service provider directly. This offer is available only to end-user consumers who purchased their affected television at retail in Canada and is not transferable. The offer is not available to providers, obligors, underwriters, or administrators of performance service plans, buyer protection plans, or other warranty or extended warranty programs. This offer is not part of the Sony limited warranty or Sony Care extended warranty plan.
For further details please contact Sony Canada's Customer Information Center 1-877-899-7669
All other terms of the Sony limited warranty or Sony Care extended warranty plan, as applicable, continue to apply.
Aug 24, 2009 | Sony KDS-50A2000 50" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52 times
Just replace its Lamp and procedure is written in user manual of KDS-R50XBR1
F93087600 XL-5100 LAMP BLOCK
Lamp is available in Sony Accessories and price is $250
Always buy Sony original lamp for good picture in TV and avoid aftermarket / cheap lamps that can cause damage of TV circuits.
Click Sony Support to download Instruction Manual copy, if you want it.
Apr 22, 2009 | Sony Video Cameras
Sony Rear Projection LCD
Whats the model number of your Sony and I will be better equipped to answer your question. Please reply to this same post.
Aug 07, 2008 | Sony KDS-R60XBR2 Television
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
Sony KDS-R60XBR2 Television Logo
1,407 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
