Question about Microsoft Xbox 360 Console
XBOX 360 - E74 WITH ONE RED LIGHT
CAN YOU HELP AND PLEASE DON'T SAY CONTACT MICROSOFT. one red light,error code E74
  • Microsoft Master
  • 6,487 Answers
Try doing this steps:
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
* Turn the console off.
* Unplug all the power and AV cables from the console.
* Unplug the power cord from the wall socket.
* Firmly reconnect all the cables.
* Turn on the console.
If these steps do not resolve the behavior turn the console off remove the hard drive, and then turn on the console. If the error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Posted on Oct 19, 2008
  • Microsoft Master
  • 19,396 Answers
Try first unplugging power cable to reset the unit.
  • Ginko
    Ginko Oct 19, 2008
    |From service manual : E74: AV cable error
    It means there may be a problem with the AV cable, try using
    a different AV cable, and test the connection.
    As said, try also unplugging the console from power for five minutes.
    E74 can also be a problem with the internal
    AV encoder chip, in this case Microsoft offers replacement for first three years, sometimes even more, but you do not want me to tell you to contact Microsoft!
  • Ginko
    Ginko Oct 19, 2008
    Also I forgot to mention, if the fault is the internal
    AV encoder chip, then you will need to replace the motherboard, as the audio video encoder is built in the motherboard.
    As I told you, check video cable, try unplugging power to reset, if it does not work, well .... you dont wanna be told to contact them, but in that case contact Microsoft.
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
One red light and E74
You see the lower-right quadrant of the Ring of Light flash red on the front of your Xbox 360 console. You also receive the following error message in multiple languages on your television screen or display: E74. System Error. Contact Xbox Customer Support.
You will see the following indicator on the front panel of your Xbox 360 console, which will repeatedly flash on and off:
If one red light is flashing and you see a different error message or code than the one listed above, or you don’t see an error message or code, your console may be experiencing a different issue. If this is the case, please refer to the “References/Links” section at the bottom of this article. CAUSE This behavior occurs when the Xbox 360 console experiences a hardware failure.... loadTOCNode(1, 'cause'); This behavior occurs when the Xbox 360 console experiences a hardware failure. THINGS TO TRY Here are some steps that you can use to try to resolve the issue. Turn off the c... loadTOCNode(1, 'whattotry'); Here are some steps that you can use to try to resolve the issue.
  1. Turn off the console, disconnect all the cables, and then reconnect all the cables. Turn the console back on.
  2. Turn off the console, and then disconnect any accessories that are connected. For example, disconnect any Xbox 360 controllers, Xbox 360 Memory Units, and the Xbox 360 Hard Drive. With the accessories disconnected, restart the console to see whether the problem still occurs. This can help you determine whether the console or an accessory is experiencing the problem. If you determine that an accessory is consistently causing the error, try borrowing another accessory of the same type and testing again using that accessory.
  3. If you continue to experience this problem, contact Xbox Customer Service.
    Note If the agent cannot help you resolve this issue, you may have to return the console to Microsoft for repair.
Additional support loadTOCNode(2, 'moreinformation'); If the steps in the previous section did not resolve your issue, your console may have to be repaired. For more information about how to start the online repair process, please visit one of the following Web Page links: United States customers - Online console repair (http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx? redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx? step=repair) Outside the United States - Online console repair (http://www.xbox.com/support/) Note: Online console repair service is currently not available in all countries and regions.For more information about how to contact Xbox Customer Support directly, please visit the following Microsoft Web site: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Mar 27, 2009 | Microsoft Xbox 360 Console
Xbox 360 e74 error
Having the e-74 code is when the video chip on the 360 over heats and becomes un soldered your best bet is to turn the 360 on with a towel over it and wait for 3 red lights the call microsoft and tell them the 3 lights issue dont mention the 1 light or it will cost you dearly around 150$
Mar 17, 2009 | Microsoft Xbox 360 Console
1 red light
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jan 04, 2009 | Microsoft Xbox 360 Console
One red flashing light e74 rror code
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known
to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected
directly to the AV cable) in rare cases it is the GPU.
If you just got it take it back, if you have had it for a little while you need to call microsoft and send it off for repair
Aug 21, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Xbox 360 1 red light
If everytime you turn on your XBOX 360 and it displays this message it could mean a hardware failure :
E74 Means : There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement
I would advise you call customer support
They are very helpfull and if your XBOX 360 is under warranty they will offer a pre-paid postal service to pick your XBOX 360 up , and will diagnose the problem .
If your based in the uk , the number is : 0800 587 1102
I hope this helps everyone
X
Jul 31, 2008 | Microsoft Xbox 360 Console
The cause of E-74 with one red light Error might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red light Error) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours.
Dec 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
246 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
