Question about Sharp R-1460 Microwave Oven
Limited space for over the range microwave
I need to find an over the range microwave that requires a maximum 15" height for the mounting bracket. All other dimensions are standard. I am replacing a Sharp R-1460. Any help out there?
Thanks,
Murph
  • rtkan Feb 08, 2009
    have you found a solution? i have the same problem. thanks
  • Sharp Master
  • 9,098 Answers
You can call Sharp and ask them what current models if any will be drop-in replacements,either using the same mounting hardware or at least the same space.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Posted on Oct 19, 2008
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
How do you take-out frigidaire over-the-range microwave
If this oven is hung from a cabinet, then there should be two, or more, large screws holding it to the cabinet. There is probably a bracket on the rear wall as well.
When I take one of these down, I find a cardboard box that's just smaller than the space between the oven and the range. Then, when I loosen the screws, it comes to rest nicely on the box. Most ovens pivot down from the rear mounting bracket.
Jun 26, 2014 | Frigidaire FMV156EM Microwave Oven
Jvm230wl I want to replace my over the range GE JVM230WL model but I'm not sure the exact dimensions. It appears to be a snug fit in the bracket so the measurements need to be manufacture specific. Also,...
GE Customer Service is here. They may be able to tell you if there is a "drop-in" replacement available for your model.
Otherwise, you'll have to take down the old bracket then mount another model in the space.
Jan 15, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Can you provide guidance on how to install this microwave? Trying to decide if I should pay $120 for the store to install.
Installation of an over the range microwave is not a very difficult task as long as electrical work to provide power is not needed. If no outlet exists then an electrician will be required.
Tools that may be needed for the installation include a cordless drill, drill bit, measuring tape, masking tape, stud finder, razor knife, pencil.
A template is commonly provided for mounting hole locations that need to be drilled in the cabinet. These holes are the top mounts.
An additional template for the wall bracket is normally supplied as well. Here you will need the stud finder, it is important to locate the studs and mount the wall bracket to them.
The wall bracket serves as the bottom mount and aids in the final mounting of the microwave.
Depending on the oven's size and weight a helper may be needed to complete the installation.
Remember to be safe first and seek advice/help with any step you are unsure about.
Good luck.
Jun 27, 2010 | Whirlpool WMH1162XVS Microwave Oven
#mmv4203dw installation, the old one is out
The new microwave oven dimensions are 29 7/8" wide, with a depth of 15 1/2" and a height of 16 15/16". These measurements are listed on page 3 of your installation manual. If you do not have an installation manual, you can go to managemylife.com and type in the model number you provided under the "Manuals" link. The owner's and installation manuals are both listed in .pdf (Adobe) format that you can download or print for FREE.
So...to answer your initial question, "Yes", this model microwave oven will fit in the space that your old one previously occupied.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 27, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
Over The Range Microwave new models too tall need under 15 in hig
cut the cabinet off. a cabinet maker can do it and you can tell if they ar good
Jul 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Looking for Installation Instructions for microwave.
Yes to all of your questions. There is a mounting bracket which is specific to this model.
here are the installation instructions http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-InstallationInstructions.pdf
here is the owner manual
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-Manual.pdf
here is the witing diagram
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-WiringDiagram.pdf
and here is the parts manual
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-PartsManual.pdf
Download these manuals and you will have all of the info available on this microwave. Check to see what is missing and then get what you need by clicking on this page and the where to buy line
http://www.frigidaire.com/customersupport.aspx
enjoy your new microwave.
May 23, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
One stud in the middle for an OTR Microwave Install?
i had the same trouble, yes i used a solid bolt to hold the microwave bracket in the stud then used the biggest toggle bolts that will fit, also the cabinet will not have to be changed. it works fine, if you had a vent a hood dont forget to hook up the exhaust vent. i figure your old exhaust vent is in the cabinet like mine was
Dec 31, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
I replied to your other post on this, but I'll just paste the solution here and get myself 2 FixYa ratings! *grin*
Oct 19, 2008 | Microwave Ovens
Microwave Ovens Logo
830 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
