Question about Frigidaire FGB24S5A Gas Single Oven
What does the F1 alert mean?
I get a recurring F1 beep even after I press "cancel" I worked with the oven for about 2 hours trying various combos of opening the oven, pressing cancel and trying to perform various functions (light, clean, bake, broil, etc.) to no avail. I got it to stop for about an hour at one point, but it started right back up again. It also seems that every now and then the oven light will come on all by itself during one fo these alerts
  • dortrose Nov 17, 2008
    We set the oven to self-clean, just went to check on it, it was beeping incessantly and flashing 'F1 ERR'. Cannot cancel, touchpad is non-responsive.
  • 750 Answers
Hello jiverson,
Welcome,
You said, your get a recurring F1 beep even after I press "cancel" I worked with the oven for about 2 hours trying various combos of opening the oven, pressing cancel and trying to perform various functions (light, clean, bake, broil, etc.) to no avail. I got it to stop for about an hour at one point, but it started right back up again. It also seems that every now and then the oven light will come on all by itself during one fo these alerts
Please send me your complete model number including the single diget at the end of the model number.
For example: FGB24S5AW1
Then I can be sure!!!!!!!!!!!
Waiting your response. I'll check for it through out the day!
And get back to you as fats as possible so you can take care of it Monday!
Huuum
In some ovens It could be failure of your, EOC (Electronic Oven Control) failure
Posted on Oct 19, 2008
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
Jenn Air double oven keeps beeping
HI,
The problem is with the faulty relay board or wire harness harness.
There are no home remedies for this problem.The only solution is to get it repaired.
Sep 17, 2008 | Jenn-Air Electric Double Oven
What does the F1 mean
Hi, the F1 error code means a problem with the System Watchdog Circuit..
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Nov 16, 2010 | Dacor ECS127 Epicure Electric Single Oven
The oven beeps and has a error F1
Hello,F1 means Stuck touch pad.
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled,replace the oven control(also called clock or ERC),touch pad,or both.
Thanks
Jun 01, 2010 | GE JTP20 Electric Single Oven
What does code F1 mean?
HI. This is a basic communication issue that will concern, either the control board, or touch/Key pad assembly. Normally, this will produce a stuck key, which will cause one of the power relays to become suspended.
Determine if The problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting the key pad Ribbon Cable from control(main), and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
NOTE_ Some models incorporate the touch/Key pad into the ERC as a single assembly(Whole device), in which case this test is not necessary. Simply replace the ERC (Clock).
Jan 04, 2010 | Kenmore 41389 Electric Double Oven
Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Error code F1
I had the same problem and found this post:
http://fixitnow.com/wp/2006/03/11/maytag-amana-jenn-air-and-magic-chef-range-f1-codes/
The oven had been cleaned earlier in the day and the touch pad ribbon connector was shorting. I cleaned it with rubbing alchohol and blow dried the whole board for good measure. Hooked everything back up and haven't had a problem since.
Jun 08, 2008 | Jenn-Air JJW8230D Electric Double Oven
Frigidaire FGB24S5A Gas Single Oven Logo
204 people viewed this question
Top Frigidaire Ovens Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
