Question about Philips HTS-6500/37 System
Philips HTS-5510 subwoofer
My 18 month old daughter has 'posted' various items in the hole in the middle of the subwoofer and I am trying to find out how to open it up to rescue them. I cannot see any screw hols anywhere - any ideas?
5 Suggested Answers
night71
  • 328 Answers
SOURCE: dis-assembling subwoofer
Unless you are good with wiring and can accept having the front cover broken, then you can do it yourself. The speaker protector can be gently pried off but will probably break if not done perfectly. If you get the front cover off, there should be 4 screws holding the speaker. Remove them and then you can see inside. Take note of how the resisters are attached. You may need to solder if they are separated. If you are confident handling this job, go for it, if not, take it to your local repair shop.
Posted on Oct 29, 2007
SOURCE: Unlock Philips HTS-3565
Hi
TURN ON THE PLAYER
PRESS OPEN/CLOSE TO OPEN THE TRAY
WITH THE TRAY OPEN, PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL BE DISPLAYED.
PRESS "0" TO UNLOCK ALL
PRESS "OK"
Posted on Oct 06, 2008
SOURCE: Region Unlock code for Philips HTS 3152
Power on the system
Eject the disk tray
Press Stop for around 2-3 seconds
Type in 7,3,4,4,6,6,0
You should get a message saying your player is now Region 0.
Posted on Oct 20, 2008
easyq
  • 144 Answers
SOURCE: Philips Home Theatre System - no sound or power light on sub woof
reset the device to factory settings, it is written in your manual how to do this. If that doesnot work, unplug the powersocket for about 30minutes, it will cause an internal reset which might solve it.
Edgar
Posted on Jan 29, 2009
Repair Philips HTS 3450
What exactly is the issue? no deep bass? pffft instead of woof?! low volume?
Info needed,
Sep 12, 2017 | Philips HTS3450 System
HTS-20 power subwoofer - was changing fuse and my daughter kneeled on the power board that holds the fuse and the power cord connects. She snapped it in two and I can not find the part to repair. Do you...
Out of production. Contact parts@harman.com to see if replacements are still available. If not, Ebay is your best bet to source either the replacement part or an entire sub assembly.
Jan 18, 2011 | Infinity HTS-20 System
My subwoofer doesn't seem loud enough. I have it set to 80%. Is there other settings that might solve this problem?
Bas response is highly dependent on room boundaries, speaker placement and relative listening position.
Page 13
"Place the subwoofer at the corner of the
room. Otherwise, keep it at least one
meter away from the TV."
http://www.retrevo.com/support/Philips-HTS3555-Home-Theater-Systems-manual/id/2869dj188/t/2/
You might experiment with moving the sub around.
Jan 16, 2011 | Philips HTS-3555 System
Edgar
Jan 23, 2009 | Philips HTS3450 System
Fuse keeps blowing in the subwoofer on my Philips hts-3450
Replace the capacitors with ones of the correct v. Download latest manual from Philips website to verify if the capacity value is not a typing error.
Jan 03, 2009 | Philips HTS3450 System
When Turned on the Screen says ''Locked''
Please post the model of your TV. 0711 is a default code to access the blocking menu items on some Phillips TVs. have you tried changing the channel. maybe it's just the one channel is blocked. More likely the TV may be in a blocked mode. If you have the manual there should be instructions to reset the blocked mode. There are manuals online. Use Google or any other search and type in your model number and "manual."
Nov 25, 2008 | Philips Televison & Video
HTS 6500/37 sub woofer
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
Good Luck
Jul 25, 2008 | Philips HTS-6500/37 System
Philips HTS 6500 not reading my DVD's
I bought this item in Nov. of '07 and it worked great...for about 3 months then the dreaded no disc message appeared and has ruined my life. Howvever after not using this DVD player for a month or so i had decided to tinker with it to try and get it to work and it appears i have found a solution that is working for me so far. After being fed up with Philips and trying their "solutions" because as we all know the U.S. sells DVD's with the wrong region code (ha funny Philips people) i began trying to make this stupid peice of garbage work in any way. What i came up with is this: 1.) insert your DVD and wait to see what happens. When you get the no disc readings this is what you do. 2) Eject the dvd but do not touch it 3). While the dvd is sitting in the slot press and hold down the play button on the remote control and continue to hold it down 4) it may take awhile but give it a chance, and hopefully the DVD will "resume play" and start anew. If holding the play button down does nothing then try holding it and releasing it in intervals until something happens. If nothing ever happens then i guess you SOL. I know this is not an desired fix to the problem but so far it has worked for me. I noticed this because the stupid thing will would read a cd and this got me thinking. This way is kind of a jump start to get the dvd going....hope this helps someone
Feb 20, 2008 | Philips HTS-6500/37 System
UNKNOWn disc type
Me too - I've had a DVR3305/05 for just over a year and yesterday after using a lens cleaning disc it refuses to play anything !!! My advise is to stay away from Philips !!!
Nov 13, 2007 | Philips DVDR3380/05 DVD Recorder
Philips HTS-6500/37 System Logo
239 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
