Question about Dell 924 All-in-One InkJet Printer
Communication error We have had the printer for about 2 years. Now it will not communicate with the computer. We have checked all the connections. We tried to uninstall and install again. It states they will not communicate with each other.
  • juliebgreer Oct 20, 2008
    Thanks will try!
    Thanks will try!
    Genius:
  • 1,605 Answers
Uninstall the software.
procedure must be follow. otherwise it will not work.
first. turn off the printer. unplugged fromt the wall.
1). install the software with printer disconnected.
2). turnoff the printer and connect the cable to the computer.
3). turn on the printer.
if you are using USB. makse sure the USB is working.
Posted on Oct 20, 2008
Error Code: E197 0000 in cannon 2900 printer
Printer engine communication error
Erroneous communication between the DC controller PCB and image processor PCB was detected.
- Check the connectors of the DC controller PCB and image processor PCB.
Replace the DC controller PCB for normal connection. - Replace the image processor PCB.
E197 0000 Laser Driver PCB communication error
Description :
Description Error in communication with the Laser Driver PCB (communication data failure)
Causes :
Solutions :
Remedy
1. Check the Laser Scanner Unit connector.
2. Replace the Laser Scanner Unit.
3. Replace the DC Controller PCB (PCB1).
Nov 16, 2017 | Cannon Office Equipment & Supplies
My Canon zerox machin ir 2870. my machin dosnot open Error code is E000733-0001
Dear
(E 733-0001)(There is an error in the communication with the printer-
There is a DDI-P communication error.)
Pl. do.
1. Check the connection with the
printer.
2. Check the power supply of the
printer (to see if initialization takes
place at startup).
3. Replace the DC controller or the
main board.
Thanks.
Feb 26, 2015 | Canon Office Equipment & Supplies
After years of using the same setup I get a communication error on my Epson r290.
Sounds like you have multiple drivers. On the MAC, go to the printer set up window in system preferences and select the r290, then go to the "-" minus icon at the bottom to dump the r290 from the list. Restart the computer with the r290 connected and see if the system recognizes it again in the preferences window. Hit the + icon to add it. Hope this helps.
Sep 04, 2014 | Epson Stylus R290 InkJet Printer
Not communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Dec 22, 2011 | Lexmark X1240 All-In-One InkJet Printer
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Printer does not Communicate (connect) following Microsoft SP3
    I figured out the solution. Download the printer driver here http://downloads.lexmark.com/static/229-1-0-486.html#
    Jan 28, 2009 | Lexmark Z600 InkJet Printer
    Communication problem printer lexmark2600
    With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
    To fix a fouled install:
    (1) Uninstall the Lexmark drivers in Add Remove Programs
    (2) Shutdown the computer
    (3) Disconnect the printer from the USB port
    (4) Restart the computer
    (5) Run the Driver Installation software
    (6) Cancel ALL attempts by windows to auto install the printer
    (7) When the software asks for the printer connect it and continue
    Jan 12, 2009 | Lexmark X4530 InkJet Printer
    Unable to establish two-way communication error
    What kind of cable is being used to communicate?
    Nov 24, 2008 | Lexmark X2500 All-In-One Printer
    Epson 595 COMMUNICATION ERROR message
    HI
    Check the USB cable if connected properly from the backl of printer and from back of computer. check under device manager under universal serial bus controller connection problem.
    Hope this helps
    Nov 15, 2008 | Epson RX595 Photo All-In-One Printer
    1)right click the my computer icon
    2)click properties and then click hardware n go to device manager.
    3)uninstall all usb ports and then scan for hardware changes
    4)ur pc will detect your printer and ask for printer drivers
    5)re load drivers and your pc will communicate with your printer
    6)for reloding install the cd follow the instructions on the screen and click next
    7)restart when the printer is loded.connect the wires and cords properly.
    Nov 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
    Dell 924 All-in-One InkJet Printer Logo
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
