Problem with Combination Televisions
Codes for 20" Digistar model tk2055d tv remote
4 Solutions
Have a Digistar tk2055d 20" tv. can not find codes for remote so i can use my universal remote.
Combination Televisions Logo
1,553 people viewed this problem
  • 5 people found this problem to be helpful.
  • 2 people are following this problem.
More Insights on Fixboard
4 Solutions
This solution has been voted best by the Fixya Commnunity
THE BEST SOLUTION IS THE SIMPLEST ONE.
I suffered for 1 month shopping around for an universal remote control that has a code for the Digistar tv brand. It was in vain.
So just turn to the simplest way ..the programming with code search (on the guide of the universal remote control- which has not the code for digistar brand) In the paper it tell you exactly what to do. I bought a 3 device universal remote control.
On mine it showed five easy steps to follow and the remote finds itself the code and programs it .You do not put any code ever, the remote just simply WORKS perfectly. I have solved this problem just 5 minutes ago..Oh ...I forget..On the universal remote control instruction it said that you might have to press the ON/OFF button up to 200 times , so i thought "I never tried this one, better then waist days and months will no solution. I nedded to do it only for 30 times or so beffore the TV turned OFF, and than I pressed the ok button on my remote (probably to save it- or who cares-as long as you follow the instructions). Then I could turn back on the Tv and P{LAy with the remote without putting any code as the remote it programmed for the Digiistar brand..I'm so HAPPY...Try it and spread the "new"...It is Ironic ..it was there all the time...we look in more complicated zones and do not see the solution sitting under our nose:((:)))
GOOD LUCK!
Tv digistar 2005 securite embarquer
Code 0167 worked for me
Try looking for Prima codes in the code book. That may solve your problem. Prima makes Digistar...
Add your solution
Full Name
Top Combination Televisions Experts
Sasi
  • Solutions: 17077
  • Level: 3
  • Achievements: 8
Chi Chu
  • Solutions: 8428
  • Level: 3
  • Achievements: 3
Larry Dillon
  • Solutions: 3130
  • Level: 3
  • Achievements: 1
Expert Badge
Are you a Combination Television Expert?
Answer questions and help others.
Users Who Viewed This Problem Also Viewed:
See More Combination Televisions Related Problems
Unsolved Problems:
Loading... Loading...
