Question about Kodak EasyShare C613 Digital Camera
Batteries why does my digital camara dain the batteries so fast?
  • Anonymous Nov 29, 2008
    I HAVE PARCHESE CAMARA BUT YOUR LOCAL DEALARES NOT SUPPORT 4 BATTERS FULLY LIKAGE AND CHARGER WAS DAMMAGE SO PL CHANGE BATTERY AND CHARGER PL INFORM YOUR LOCAL DEALERS ARRCEE ELETRONICS NERUL NAVI MUMBAI
    Scholar:
  • 74 Answers
Depending on your digital camera, certain ones do require more power to run than others. If you think yours is especially subject to draining batteries too soon, try doing an internet search for your model and include "battery drain" in your search words as well. If you can't find others with your particular problem, you may have a defective camera. The other possibility is not using a large enough capacity battery for extended use. Contrary to popular belief, if you are using rechargeable batteries, the standard high capacity AA batteries such as 2800mah will not last as long while sitting in the camera as those around 2100mAh when the camera is off. This has to do with a parameter called internal resistance. The 2800's will last longer if being used right away. Newer formulations such as the Sanyo Eneloop batteries are rated around 2000mAh and will last for months if left sitting in the camera when off.
You may want to consider using lithium type batteries if you don't use rechargeables. They are more expensive but last longer in high drain situations.
Also, check to see what the Sleep Mode or Auto Power Off setting is. If this is set to a long period of time, this will drain your batteries trying to power the camera while it is idle between shots.
Posted on Oct 19, 2008
  • 414 Answers
Most digital camera's drain batteries quickly due to the power required to operate them. You need to carry spares if you are going to use them a lot. You can consider using rechargeable batteries if your useage justifies this i.e how quickly would you recover the cost of buying the charger against the cost of replacement batteries. Otherwise is just something to live with.
For my camara the lens won't go back in and it tells me to reset the camara but I'm not sure how to reset the camara
Most digital devices can be restet by removing the battery and then powering it back on; but read the manual as that may cause you to lose your pictures depending on the device you have.
Jan 04, 2011 | Canon PowerShot A530 Digital Camera
My video cam doesn't power up. I have charged the battery for 8+ hours and the camara doesn't power up. The camara is new.
Hi friend,
You should check your battery charge is ok or not. then switch on our video camara. id it is not work ..you need to contact hardware ..
Dec 20, 2009 | Vivitar ViviCam 8025 Digital Camera
Can not turn the camara on
Digital cameras drain lots of power for a short period. The best batteries for digital camera are rechargable types. It is either you are using normal alkaline batteries which are easily drained or your rechrgable batteries are not properly charged. Try solving either of these two problems.
Sep 01, 2009 | Nikon COOLPIX L100 Digital Camera
Camara Kodak M1063 not charging
BATTERY MAY BE SHOT. FIRST MAKE SURE
ALL CONNECTIONS ARE TIGHT AND CLEAN.
IF THIS DOES NOT WORK, U WILL NEED A NEW BATTERY
Jun 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
T831 polaroid camara
mi camara no salen las letras esta trabada
Oct 15, 2008 | Polaroid i832 Digital Camera
Camara can't be turned on normally
I have to take out batteries and put them back a few time to turn on my camara in display or viewfinder mode. At first i doubt my battery's problem and replaced with new batteries, it was the same
Jul 18, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
Where do I shop for Acessories for this camara
Where can I get a charger for this camara in great britian?
Jun 16, 2008 | Vivitar ViviCam 6330s Digital Camera
My camera doesn't come on
Are you using Lithium batteries?
ALL Kodak cameras have huge problems with alkaline batteries.
Hope this helps.
Jan 17, 2008 | Kodak EasyShare One Digital Camera
Help need to fix camara for work
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. you need professional service to fix it.
Sep 07, 2007 | HP Photosmart M22 Digital Camera
CAMARA SOFTWARE PROBLEM
Does your battery work with regular AA alkaline batteries ? They have higher voltage than NiMH rechargeable. I'm having a similar problem, just discovered today that my camera works fine with AA alkaline batteries.
Sep 19, 2006 | Samsung Digimax A7 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
120 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
