Question about Kenmore Elite 45986 Front Load Washer
Kenmore front load he washer
The power shut off during cycle and will not unlock the door. Trying to restart the washer results in nothing. Any suggestions?
  • rar10sr Oct 20, 2008
    the door will not open. The machine tripped the breaker during cycle. It appears that a garment got caught in the door. Powering down does not release it. The locked light is not on. The model # is H567A4A0A(3B).
    We were able to get it run another cycle, but it just stopped at the spin cycle.
  • francis rivero May 11, 2010
    was there any error codes?
  • 958 Answers
Try to unplug the unit and open the door manually by pulling a plastic ring attached to the door lock.
you can access the ring if you open the top cover of the unit and feel the ring where the door lock is and pull it down.
if you were able to open the door, you can check the clothes and remove the one that was jammed on the door. then test the unit for normal operation.
tnx 4 using fixya,
Posted on Oct 21, 2008
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service
Jan 28, 2016 | GE Washing Machines
I have a Kenmore elite HE3T front load. It gets down to 6 min then stops and flashes between 06 and F, what can i do?
Kenmore 110 4996 Use And Care Manual Troubleshooting
  1. "F" Variables [other than FH and F02] (=Electrical Problem)
  2. Select STOP twice to cancel the cycle.
  3. Select DRAIN & SPIN if there is excessive water in the washer.
  4. Unplug the machine for thirty seconds to reset the Central Control Unit
  5. Re-select cycle and press START.
Feb 27, 2015 | Kenmore Elite 45986 Front Load Washer
Water is leaking during the wash cycle. Nothing shut in the door. Been happening with the fuller loads.
try wiping or cleaning off the bottom part of the door,i've seen pieces of hair on the door and water leaks down the pieces of hair through the door,if that's clean then check for a hole in the rubber boot seal,most likely there's a hole in it
Feb 21, 2011 | Kenmore HE2 Plus Front Load Washer
Washing machine will not turn on it shut off
Have you tried unplugging the unit and waiting for a minute and then plug it back in. The load might have been off balance and caused that condition. Once it has been reset you might be able top end the cycle.
Dec 07, 2017 | Kenmore HE2 Plus Front Load Washer
HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite smart wash quiet pak 9 Front Load Washer
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
Stuck in cycle
unplug the unit. wait 30 secs. and repluge, youll have to restart cycle. but should work DO NOT add more soap
Mar 18, 2008 | Kenmore Elite 45986 Front Load Washer
Front loading frigidare washing machine
Check breaker only one breaker are function recock it the two breaker try to start it .
Jan 07, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
64 people viewed this question
Sal De
 Brian Main
Brian Main
