Question about Epson Stylus C46 InkJet Printer
Epson c46 printer
Green & red lights flashing alternately,unable to use
  • 7 more comments
  • Anonymous Oct 21, 2008
    red light and green light flashing and a box appears to say parts are at the end of life, does this mean i need to buy another one or shall i try and fix it first..
  • dnpadhy Nov 02, 2008
    Red light and Green light flashing and a box appears to say parts are at the end of life,
  • davidtrish Nov 10, 2008
    I have cleaned the pads on my C46 as recommended and used the http://inkjetprinterhelp.us/epsonSSC.htm... site to reset but it has not worked. It really is blackmail by the manufacturer. We have now used three of these printers and they have to be scrapped unless someone can help.
    I have bought a DX4400 which definately works with £1 generic cartridges without a problem....so far. The new Epson S20 printer cartridges are about £18 each! Try printing 150 sheets a month and see the cost!!
  • ekpea Nov 28, 2008
    red and green lights flashing alternately and seems unable to print. Documents just sit in the queue waiting... Have lost manual so don't have any idea what to do to fix it.
  • Anonymous Dec 02, 2008
    green and red lights flash alternatively
  • dick0121 Dec 16, 2008
    Both lights flashing
  • davidtrish Feb 11, 2009
    I have had three C46 printers which have had the same problem. I tried cleaning the pads but no good. Scrap it and buy a DX4400 series which works well with cheap generic cartidges and so far does not appear to have the "Epson Blackmail" programme built in.
    Don't get the latest S20 ...cartridges are very expensive.
  • Anonymous Mar 18, 2009
    How do I disassemble my epson stylus c46 so that I can clean my inkpads
  • skec_mj May 11, 2010
    can somebody give me a download link for Epson Stylus c46 Service manual please
  • 353 Answers
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C46 Service Manual". You will often find them for sale very cheaply on E-Bay.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Posted on Feb 11, 2009
2 Suggested Answers
lorenzo_most
  • 60 Answers
SOURCE: red and green lights flashing alternately
Hi there.
Under each printers there is a pad, a spunch that holds all the wasted ink. This pad is probably full. you should locate where the ink pad is and change it or clean it. By cleaning I mean getting rid of all the ink from the spunch. After cleaning or replacing the pad you shoul run a utility to reset the protection counter. I use to have a all in one epson printer and did the same. I use SSC Service utility. it helps to reset the counter. After that, if that is the problem, your printer should work again.
Good luck
Posted on Mar 30, 2009
Have flashing lights from Green to Red with no
Sounds like a maintenace pad problem (every Epson printer has a different set of flashing lights to indicate this "Maintenacne request"- read this link: http://www.epson.com/cgi bin/Store/support/InkPadsForm.jsp
Jun 01, 2010 | Epson Stylus C46 InkJet Printer
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
The red and green light are flashing alternately and it won't print. What can I do?
Buried inside the Epson C46 is a usage counter. Mine was preset to 8300... when this was exceeded, I got the dreaded flashing lights. Go to http://www.fixyourownprinter.com/forums/printer/39038
for a full explanation (by Leonardo A. Palacios) of how to down load and use the printer reset program.
Good Luck
Paul A. Boothby
Dec 18, 2009 | Epson Stylus C46 InkJet Printer
Green light flashing and red light flashing alternatively. Ink cartridges appear to be full. No print
Cek status monitor ? Service required / end life? Use SSC utility to reset wate ink counter.Menu protention counter. Show cuurent value for checking. If value exceeded maximum, reset protection counter. Or Clear counter overflow.
Jun 30, 2009 | Epson Stylus C46 InkJet Printer
MY EPSON STYLUS C46 WONT ACCEPT THE BLACK INK WHICH IS NEW THIS IS THE SECOND ONE. THE RED LIGHT FLASHES AND THE GREEN LIGHT STAYS ON
Check status monitor? Black ink not recognized or what? If not recognized, red light just on. But flashes? It's may ink nearly out (low level ink) or printer need service. Check it. using SSC utilty to resolve. Reset protection counter and clear counter overflow.
Jun 27, 2009 | Epson Stylus C46 InkJet Printer
Epson C46 colour printer green and red lights are flashing....but
Basically your printer says that you need to replace the waste ink pads. If this happens for the first time to this printer you can just reset the counter using SSC Service Utility (http://www.ssclg.com/epson.shtml) or if it happened more than once you shoul first replace the ink pads and then reset the counter or the printer may overflow. That's it.
Jun 15, 2009 | Epson Stylus C46 InkJet Printer
Red and green lights flashing alternately
Hi there.
Good luck
Mar 30, 2009 | Epson Stylus C46 InkJet Printer
My C46 suddendly stopped working.
It is error of waste ink tank.
You can find a lot of utilities in internet to reset this situation
Mar 07, 2009 | Epson Stylus C46 InkJet Printer
Flashing lights
Dear , friend
Please replace cartridge
Jul 08, 2008 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
1,080 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
