Question about Estate TEDX640JQ Electric Dryer
ROPER DRYER REX3615EWI
ROPER DRYER KEEPS TRIPPING CIRCUIT BREAKER. I HAVE REPLACED THE HEATER ELEMENT, THE THERMAL CUT OFF AND THE HI LIMIT AND I HAVE TESTED EVERYTHING ELSE BUT THE MOTOR. GOT ANYADVICE IT WOULD BE APPRECIATED THANK YOU.
  • rbplumbing Mar 30, 2009
    I have the same problem. The dryer runs for a little while before it blows the breaker then will run but with no heat.
    Problem Solver:
  • 8 Answers
Hey billybob40s,
Does the dryer trip the circuit as soon as you push the start button or does it take a while to trip??
Posted on Nov 29, 2008
Bosch AE-9.5 keeps tripping the reset
All resets and breakers trip with high heat.
Do you mean the tankless unit is tripping the 40 amp circuit breaker?
Or the thermal cut-out, located on unit, is tripping?
Is this a new installation?
Or was the tankless working before and stop working?
Copy following link to check wiring.
AE 9.5 requires 40 amp breaker and 6 gauge wire.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
If the unit is tripping the thermal cut, -out, then product manual says to call Bosch or service technician.
Call Bosch 866-330-2729
http://waterheatertimer.org/pdf/Bosch-Powerstar-AE3.4-7.2-9.5.pdf
Thermal cut-out can trip if water flow is too low.
Try changing power selector screw from Hi to Lo so only 1 element is ON. See diagram page 6 of manual.
Adjust the 'outlet service valve:' The manual recommends that a ball valve be installed between hot outlet and faucet. Adjust the valve so more water flows to faucet.
Remove aerator, clean aerator, don't use low flow restrictions or low flow shower heads, replace leaky faucet cartridge on single-handle faucet.
Aug 29, 2012 | Bosch AE-9.5 PowerStar 1.5 GPM...
I have a roper rex5634kq1 the heater shorted and i replaced it but the thermo cut out is stopping it from getting 230 volts is the thermo cut out normally closed or normally open this one had no...
normally closed on any thermal cutout this is to make the circuit to operate the dryer till it overheats,then the thermal opens to shut off current to the heating element for safety
Sep 10, 2011 | Roper RES7646KQ Electric Dryer
Does the Kenmore Series 700 dryer use circuit breakers or a thermal fuse to shutoff the heating element?
All Kenmore Electric Dryers use a thermal cut-off or thermal cut-out, hi-limit thermostat, and a cycling thermostat apart from the motor centrifugal switch as parts of the heating circuit. The thermal cut-off/thermal cut-out and the hi-limit thermostat are located on the heater duct/element duct while the cycling thermostat is located on the blower housing.
The thermal cut-off/cut-out serves as a safety measure and blows open should the dryer overheats or should the hi-limit thermostat fails to cut off power to the heating element. Check the continuity of the thermal cut-off/cut-out and if open, replace it including the hi-limit thermostat.
Aug 22, 2011 | Dryers
My roper dryer REXEW1 runs the cycle but it dosen't heat. how di I fix it?
This is usually caused by a blown thermal cut-off located on the top of the heater housing. It blows and cut power to the heating element when the high-limit thermostat fails. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Roper REX3614KW Electric Dryer
The dryer turns on, and tumbles. Yet it no longer get hot. I was thinking heating coil. But was told it could be a smaller part.
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The first thing to look at is the thermal cut-off which cuts power to the heating element when it blows due to the failure of the high-limit thermostat both located on the heater housing. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Roper electric dryer will not heat after replacing heating element and thermal fuse. what's wrong.
It doesn't necessarily mean the heating element is busted when the dryer stops heating and the thermal fuse is not part of the heating circuit, it is part of the motor circuit. The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions. Indicate the exact model number of the dryer should you need further assistance.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 12, 2011 | Dryers
Model RES7745PQ0 works great but no heat... what is most likely the problem... also I checked my breaker so that's not it...? HELP\r\nBest Regards
The problem is likely in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
The
thermal cut-off (cut-out) and high-limit thermostat are sold as a kit with part number 279816 and costs about $30.
In case the dryer still doesn't heat up with the
thermal cut-off (cut-out) and high-limit thermostat bypassed, bypass the cycling thermostat then replace it if the dryer heats up. Check the heating element for broken coils if the dryer still doesn't heat up with the three components mentioned above bypassed.
Jan 19, 2011 | Roper Dryers
Roper dryer Mod# REL 4636BW Worked fine this morning, does nothing this evening. Breaker not tripped.
If the model number is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
3. Hi-Limit Thermostat
4. Internal Bias Thermostat
5. Thermal Fuse
You can access your heating circuits by UNPLUGGING the dryer and removing the rear panel.
As viewed from the rear of the dryer, your Heating Element will be located on the RIGHT hand side inside a heater box. The Thermal Cut-Out will be located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
The Internal Bias Thermostat and Thermal Fuse are two small components mounted on the Blower Fan housing on the lower LEFT hand side.
You can refer to the following parts illustration for assistance:
http://pcappliancerepair.com/model-display.php
The components are listed as follows:
Heating Element (Item 17)
Thermal Cut-Out (Item 7)
Hi-Limit Thermostat (Item 15)
Internal-Bias Thermostat (Item 6)
Thermal Fuse (Item 8)
If you need assistance on how to troubleshoot a dryer, you can refer to this link:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
The MOST common causes of a dryer that will not turn on is:
1. Blown Thermal Fuse
2. Missing all , or part, of your input voltage at the wall receptacle - double check your source voltage at the receptacle and/or your circuit breakers.
3. Bad power cord. Check the terminal block on the back of the dryer with the cord plugged in. If the voltage is good at the receptacle, but missing a the terminal block, you may have a bad power cord.
Read through all the information provided and let me know if you have any questions, or need further assistance. I hope you find this information helpful.
NOTE: Take all resistance readings with the dryer UNPLUGGED and the component under test isolated (meaning disconnect any wire leads to ensure the accuracy of your readings).
Apr 08, 2010 | Dryers
Dryer stopped now won't start
1. Heating Element
2. Thermal Cut-Out
5. Thermal Fuse
Thermal Cut-Out (Item 6)
Internal-Bias Thermostat (Item 24)
Thermal Fuse (Item 23)
The MOST common causes of a drer that will not turn on is:
Apr 02, 2010 | Roper REX4634KQ Electric Dryer
No heat
Check the home electrical fuse panel or reset the breaker (even if it looks like it's not tripped).
Feb 18, 2009 | Kenmore 63942 Dryer
Estate TEDX640JQ Electric Dryer Logo
110 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
