Question about HP OfficeJet D135 All-In-One InkJet Printer
D135 and D145xi says Paper jam but there is none
I have 2 of the expensive units and both show same error. I picked up the D145xi used to try and fix the D135. If I swap the auto doc feeder from one to the other I get same result. Home office use with about 2000 pages used in total. HP support has been no help. I actually had next day replacement and used it twice (they send refurbs) and then stupidly let it lapse accidentally just before the most recent failure. I have cleaned and inspected every inch and see no jam anywhere. The fax receiving still works and I can print but no feeding into the ADF and no copy from direct on glass.
Is there a micro-switch that reports the error that can be replaced or cleaned? I did like the unit
I went and purchased a C6180 AIO and a C6280. The 6280 does not fax but both use same carts and print fast. The others are boat anchors as far as I am concerned. Epson is no better as I didn't use it for 2-3 weeks and the heads fried up and cannot be fixed. JUNK JUNK JUNK, it's all throw-away technology at a high price.
    Scholar:
  • 77 Answers
Hi ,
First thing if its an ongoing issue you have the right to call hp and make them replace the machine even though the warrenty lapsed as it happened while you were facing an ongoing issue. they do not make these machines anymore so i am surprised that you got refurbs of this. ask them to give you an upgrade.
also if a replacement is made it extends the warrenty by 3 months.
call them up and be firm is my advice.
Now i would recommend you buying a laserjet multifunctuion machine. those babies are a bit expensive but are value for money when it comes to print per page value as well as ease of use and maintanence. take my word you will love it.
Messing around with inkjets would just get you more aggrevated: they are only useful for small office or home uses with minimum useage.
I hope you get a replacement from hp. Hit me again if you need anything.
keshey
Posted on Oct 19, 2008
Hp 9050n paper jam 13.32
check the censor 1, pick up 2,in fixing these should the spring tentioned
Feb 18, 2013 | HEWLETT-PACKARD HEWLETT PACKARD : HP 8-bin...
My HP5200 13.20.00 Paper Jam
sounds like your fuser sensor or the fuser is bad
Jul 28, 2017 | HP LaserJet 5200 Printer
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
Jan 07, 2013 | HP LaserJet 9050 Printer
Doc feeder jam error on HP laserjet M1522nf continuesly also due to that i am unable to scan and also its showing that "Device is busy try again later"
Open adf cover, remove adf pick up unit, two sensor located in it 1. paper leading edge sensor, located upper portion of the unit.2. paper out sensor located back side of the adf pick up unit. Carefully open this unit your will easily find out the sensor location..
Sep 13, 2011 | HP LaserJet M1522nf Multifunction Printer...
Canon IR3530 jamming
Hi, lets go from begining:
1) Remove rollers from lower cass, and put them on first cass. Use fresh paper too. - Does it helps? try abaut 50 copies.If helps replace rollers.
FB6-3405 x1, FC6-6661 X1, FC6-7083 X1
2) when you open right lower door and right door you will be able to see axis with two small rollers.Clean it verry well, use alcohol.
3) On lower right door there must be metal plate for pressure on delivery roller, if there is no plate, put in each corner some tape or filc 2-3mm thick, wich will add pressure on plastic paper cover wich guides paper on delivery roller.
4) Does your jamed paper have any anomalities on itself, like: look like accordian, small wrinkles,...
If yes, check separation plate on fixing unit, pressure of rollers ( between fixing film and press. roller - NIP CHECK ).
5) Beaneath drum you will see small plastic sensor flapper - is he worn out? This is paper registration sensor, if he get in first position before the paper pass him you will get jam code.
Note:
Try to flip paper in cassete, up side down, and try then. If then works, the problem is in moisture on paper.
Hope that helped
Jun 29, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Error 6A00 code showing. Tried to use printer, this code was showing on display panel. Tried turning off and resetting. checked for any paper jams...none. Checked ink cartridges and there doesn't seem to...
Hi there
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Epson u220b printer
service for that unit - call the manufacturers tech line and they'll give u service center nfo - it it's still under 2 years - repair will be free of charge
Apr 08, 2008 | Epson TM-U220 Matrix Printer
Hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Feb 12, 2008 | HP LaserJet 4250dtn Printer
HP OfficeJet D135 All-In-One InkJet Printer Logo
59 people viewed this question
Ben Johnson
