Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
Lexicon Lambda, MIDI out not working
I have a Lexicon Lambda thorugh which I can record the MIDI in coming out from my drum-machine (Korg DDD-1), but I cannot play it back to the drum-machine. Routing the MIDI out through my MIDI-Sport 2x2 works fine, but not MIDI out at the Lambda. I've tried everything, disconnected and reconnected, with and without the MIDISport connected at the same time. I have the latest driver 2.5, and I use Reaper 2.53.
Thanx
// MVHMF
SOURCE: lexicon lambda
push the monitor button to go mono instead of stereo.
Posted on Nov 29, 2007
SOURCE: My Lexicon Lambda is not working
Go to your devices tab click on the ASIO driver Lambda and when you get that message click reset and try again it should work.
Posted on Apr 11, 2008
SOURCE: lambda lexicon sound problems: is vista the cause?
I have had the same problems with the lambda driver ...they just posted a new installer on the lexicon website which fixed me up...try it.
Posted on Jul 26, 2008
SOURCE: Lexicon Lambda on Mac
Hi, I just bought one today and am using a condenser mic through the lamdba. I booted up apple logic - plugged in the device and it found it as a usb audio device. You need to use the headphone jack on the lamdba. good luck
Posted on Jun 14, 2009
rob151
  • 54 Answers
SOURCE: Lexicon Lambda not detected
the usb could be the problem. when you plug it in does your comp make a noise if not it is the usb if it does than the drivers are not in sometimes its a program problem try going to start-mycomputer-(cd/dvd drive right click on it and click explore. find the file labled drivers and install them first than install the program hope this helps.
Posted on Jun 29, 2009
I have an Omega/Lambda/Lexicon and the vocals seemed to be delayed with the timing established by the instruments. Any ideas of what to do?
Without the configuration you are using we have little to go on. How is the system wired? Are you saying when you run instruments AND mics into this then record they do not play back together? If the instruments are MIDI types and you play back along with the vocals I would expect the MIDI instruments to be delayed a little as it takes time to transmit the note info at 31.25Kb... It takes about 1/3000 second for EACH MIDI character and note messages take three of those for a total of about 1 ms. One millisecond IS noticeable by the ear... and if you have several instruments it may take several milliseconds to service all the instruments. If you are recording ANALOG instruments the delay should be imperceptible.
Apr 26, 2011 | Lexicon Lambda 4x2x2 USB Audio Interface
Lexicom Lambda is not working! New user
right click my computer goto properties-harware-device manager then right click the lambda click update driver browse it with ur cd driver...hope this help
Jan 21, 2008 | Lexicon Lambda Usb Desktop Recording...
I'm looking to get the pre-set patterns to play on my Korg DDD-5
A demo on YouTube shows the owner pressing one of the buttons on the left side to select possibly a bank as well as the start.. I could NOT find a manual online to download.
Jan 09, 2010 | Korg Ma30
My Lambda lexicon will not record in stereo. can any one help
I'm having the same problem with mine. I realize you made this post 1 1/2 years ago, but have you found a solution in the mean time? Thanks!
Nov 07, 2009 | Lexicon Lambda Usb Desktop Recording...
Lexicon Omega will not play any sound on Windows XP
one of several install steps (the steps seem to vary depending on which manual you can find) mention checking your sound device setup in control panel. ON one machine I installed the sound devices were not affeted. On a 2nd PC they were changed from drivers installed with PC to the Lambda driver
Win XP settings->control panel->Sounds and Audio Devices then select Audio tab. Make sure the three areas are set up to use your PC's default drivers and not lambda's.
You may need to verify this again when reconnecting the Lambda USB cable. Sort of new but ran into this "issue" as well.
Found info in Lambda Studio Software Installation Guide I downloaded, step B following driver install.
Nov 21, 2008 | Lexicon Lambda Usb Desktop Recording...
Sometimes power comes on and sometimes it does not.
Are you running Vista? Lexicon is working on some firmware and software updates to fix the problem. The only workaround is to unplug and replug your USB cable when it stops working. As long as you are actually using the Lambda, it should work.
Oct 30, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon lambda no sound during playback
AFTER you open a new poject go to "Devices" then "Device Setup" click on "VST Audio System" then on he right side where it says "ASIO DRIVER" make the selection say "Lambda ASIO" then click OK
Jun 05, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
165 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
aftab Nawaz
aftab Nawaz
Alun Cox
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
