Question about Motorola Mobility V551
Phone will not power on
The silver casing on the front of my phone is broken and seemed to cause no problem with the normal functions. I tried to turn my phone on one day and it just quit working. The lights on the keypad will come on when I hold down the power, or disconnect button, but after that NOTHING!!!! I have insurance on the phone, but I need to get my numbers saved to my sim card!!!!! The phone will do nothing except light the keypad when turned on, the keypad lights will not come on when i press a number. No lights go off when I close the phone either. Please help. I don't want to lose all of my numbers and if I send it in and use my insurance they're gone for good!!! Any advise would be greatly appreciated. Thanks, Charlene
Replace the "Flex Cable". Motorolla phones have a common problem with their "flex cable" going bad in their phones after a certain period of time. I had the same problem on my V551. Keypad would light on, sound coming intermittently after pressing keys but the screen would not light up. After replacing the flex cable, everything was back to normal. Go to your local flea market and look for a store that sells and repairs cell phones. Either ask them to replace it for you or just buy a used flex cable from them. I had mine repaired for $30 including the used part.
Posted on Jan 26, 2007
  • 175 Answers
First try and check your battery and see if the voltage is still ok, if your voltage reads below 3v then its your battery, you need to rejuvenate it to its original voltage. Try a friends battery if its the same and see if your phone turns on. Good Luck
Posted on Jul 03, 2006
  • 513 Answers
Did you store all you memories in the phone memory and not on the SIM? If you're not sure take the SIM out and put it in another phone. A lab that specializes in cell phones could probably rescue the memory, but it won't be covered by the insurance. You could ask them to limit the work to just rescuing the memory, and have the rest of the job done by sending it in on the insurance, but it might be that in order for them to get to the memory, they will have to repair it anyway. Can't you contact your provider and try to make sure that they rescue you memory as part of the repair? it's not that unreasonable... Good luck
Posted on Jun 20, 2006
What causes rear wheels not to engage whether in 2 or 4 whhel drive? Front ones only turn when in 4x4.
If the shaft is powering out to rear end then internal on rear possibly broken differential. If no power from case to rear then broken in case.
May 31, 2015 | Cars & Trucks
Have an indicator fault - checked bulb and this seems fine
Hi, Anonymous before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced you OEM lights with LED lights you are going to need a load equalizer. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Turn signals not working where all to check
Turn signals stopped working
Turn Signals NOT working
http://www.r6-forum.com/forums/73-south-west/154896-help-turn-signals-not-working.html
diagnosing and repairing turn signal problems
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 04, 2015 | Yamaha Motorcycles
No function signal light
Hi Chris, before diagnosing any turn signal issue make sure the bulb is good and the light fuse has continuity with a test light. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity. For more information about your issue, please visit the websites below. Good luck and have a nice day. http://88.198.249.35/d/Pulsar-150-Workshop-Manual.pdf
Mar 26, 2014 | 2011 Bajaj Pulsar 150
Front right signal and back right stop light not
Hi Anonymous, before diagnosing any turn signal issue make sure the bulb is good and the light fuse has continuity. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity. For more information about your issue, please visit the websites below. Good luck and have a nice day. service manuals
Oct 18, 2013 | 2007 AMERICAN IronHorse Texas Chopper
My nokia c5-03 is fell down now 4 black lines occurs in my display wt is d solution sir.
Broken front panel
Take a deep breath and see if your iPhone will turn on and operate normally. In most cases, the iPhone is still functional but now a cosmetic disaster. Unfortunately, the iPhone 4S' front glass and LCD are fused together and must be replaced as one piece.
Broken rear panel
Apple did not grace the rear panel of the iPhone 4S with the same high-strength glass as the front, so fractures are much easier to come by on the backside. If your rear panel is smashed, you must replace it with a new one. Before attempting this repair, though, make sure you have the correct screwdriver.
God bless you
Jun 01, 2013 | Cell Phones
Nokia e90 display
Broken front panel
Broken rear panel
God bless you
Transfer case jumps out of gear
sounds like a servo or sensor problem more than a transfer case. try removing all electrical plugs to t case run it through the gears then replace one by one to see if there is a problem there.
Oct 27, 2012 | 2001 Isuzu Rodeo
I have a ps3 and have no picture or sound put i do have power light and i can hear it working please help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Try a video reset.
1:Turn the system to off/standby, where only the red light is on.
2:Then hold your finger on the front power button, it will turn on beep twice then shut back off, release finger.
3:Then turn back on normally.
Dec 28, 2009 | Sony Playstation 3 (PS3) Console
Nokia 6030b with broken screen
u better buy a new LCD for ur cellphone. saving data when you can not see the what is writen in the screen will cause more problem.
Nov 25, 2008 | Nokia 6030 Cellular Phone
Monitor revives only after cycling the power many times
Unscrew 4 screws on the back side. Place the monitor with the front up and open it along the upper seam. Turn it again and lift the back cover. Shift the inner case "up" and take the button holding plate out - it is being held only by a tape. Inspect it and clean it. You might have to replace the condensers and/or switches on it.
This might solve the problem, but there may be other causes as well.
Aug 03, 2006 | Dell UltraSharp 1905FP 19" LCD Monitor
Motorola Mobility V551 Logo
73 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
