Question about Honeywell Heating & Cooling
Need to bypass therostat for residential furnace
    Scholar:
  • 121 Answers
To bypass a t-stat for heat connect te red, green, and white wire together
Posted on Oct 19, 2008
Our furnace will not turn on, we have propane and 12volt to the furnace
Need 24 volts to make anything work on a residential furnace. May need to replace the transformer.
Apr 27, 2016 | Heating & Cooling
How do I bypass my Honeywell D896 vent dampner?
The furnace was probably originally equiped with a damper bypass plug that was removed to install the vent damper. Of course some were hardwired in as an accessory. But look inside the furnace vestibule or in the homeowner instruction envelop and see if the original installed tossed the plug in there during installation. That would be GREAT !!!!
Without the wiring diagram of the furnace AND the vent damper, I cannot give you specific input on the wiring. But the damper has to have 24v to operate it and there has to be a switch circuit for making and breaking the gas valve control circuit.
You may have to call a service company to get your issue safely resolved.
Dec 29, 2014 | Honeywell Heating & Cooling
Furnace will not turn on from remote or furnace
Is it a residential furnace with a thermostat on a wall some where? Are you sure its power is on?
Nov 13, 2013 | Duraflame Heating & Cooling
How do you install circuit board in atwood furnace 8525? do I need to disassemble most of the furnace to do this?
I am not familiar with the model number. I have worked on all types of equipment and have never seen a system that required major dis-assembly to replace a board. What does it look like from the outside? Up flow furnace, through the wall with a split condenser, horivontal residential? Tell me what you can and l"ll probably be able to tell you exactly where and how. Thanks for trying Fixya.
Sep 11, 2013 | Heating & Cooling
On my therostat it show and talks about the R wire and the Rc wire. What is the differet?
If you would have a two transformer system..... The power wire from the furnace transformer would hook up on R and the power wire from the Air Conditioner transformer would hook up to Rc....
BUT most systems now only have one transformer...... So if you are using this thermostat you will need to put a jumper wire from R to Rc. So the Air Conditioner will work. Furnace is the source of the transformer. R/Rc,W,Y, C, on the Thermostat will Hook up to R,W, Y,C on the furnace and Two wire from the Air Conditioner would hook up on Y and C on the furnace.....Good Luck.
Apr 02, 2011 | Heating & Cooling
Gas Furnace - residential -found furnace off - pilot light off -
check ur venting first make sure its not plugged
Jan 01, 2010 | Heating & Cooling
How do you change oil gun in furnace to natural gaswe want to go to natual gas and don't know how to change the gun over
You will need to call a professional to size the right orifice, inducer, and primary air intake for your application. If it is a residential unit you probably won't have much luck finding a conversion. Your best solution is replacing it with a gas furnace.
Oct 04, 2009 | Heating & Cooling
My honey well thermostat keep clicking and I can't program it
If you have a programmable thermostat and it is a couple of years old you will probably have to install a new one. What kind of thermostat do you have? You can turn power off to furnace and then take thermostat off wall and take wires marked r & w and connect them together your heat should come on when you turn power back on. If not you could have blown the 5 amp fuse inside furnace. I would check the fuse inside of furnace. If you take panels off front of furnace you should find a controll board inside that runs furnace.If you have anymore question just reply back to me
Jan 07, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
61 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
