Question about Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
Dell inspiron 6000 randomly starts
I got a dell inspiron 6000 laptop and noticed after a while that it turns on after i shut it off just about every time
    Novelist:
  • 67 Answers
Hi svenman18,
Well I'm assuming that you're talking about resuming from standby and not starting the computer from the OFF state. Because if its starting from the off state without you pressing the power button then most likely it could be the BIOS settings of the laptop or worse a mechanical problem with the power switch. But it is likely a program installed which has automatic updates enabled, or some other function that checks the status periodically.
A good example would be your network card, which could be set to check for a connection automatically and has authorization to bring the machine out of standby, or software like antivirus programs one on top of my head is Grisoft AVG free antivirus, which periodically checks for updates.
The first one to check is the LAN connection or if you're using wireless the WLAN connection, this is a good start since there is only a few to check out and it could be a quick fix.
1.) Right-click on MY COMPUTER then select PROPERTIES
2.) You should have SYSTEM PROPERTIES, then look for the HARDWARE tab then click on the button for DEVICE MANAGER
3.) It should open another window, look for the category named "Network Adapters" click the plus sign and it should show the items under that
4.) Then right-click on your LAN or WLAN NIC and select PROPERTIES
5.) It should show the device property, you should now go to the POWER MANAGEMENT tab.
Check to see if the option "Allow this device to wake the computer" is checked, if it is just uncheck it. Click on OK afterwards.
You should do this for each of your NIC's if you have multiple one's listed under Network Adapters category. Now the next step is checking to see the settings of your applications and see when it checks for updates, You may have to check a few settings in different places and change one of them. Now if you have a lot of programs installed and you have to check each of them then its very tedious. But you can always focus on the obvious first like the antivirus or spyware applications, or any of your programs that you recently installed before this problem happened.
You can also try disabling some of the applications running on startup, you can do this by choosing SELECTIVE STARTUP mode and on each boot enabling some programs, until it starts doing it again, thus identifying the offending item.To do this:
1.) Go to START, then click on RUN, type there MSCONFIG and press enter
2.) The SYSTEM CONFIGURATION window will open then you need to goto the STARTUP tab then click on DISABLE ALL then click on APPLY and the OK
3.) A box will popup asking you to restart your computer to make the changes effective, after the reboot, those start items won't run anymore.
If the problem doesn't occur after doing this, repeat the steps, but instead of disabling them, click on the box beside the items you want enabled so that it is filed with check mark. Now if you still can't find anything, then it is also possible for a virus or a spyware to wake the computer to send information. Then you should run the scan using your antivirus and anti-spyware application.
Finally, the last thing I can think off is that your BIOS is set to wake your computer up, just like a alarm clock. If that is the case though the computer should wake up at a set time. But in your case, you said the computer randomly wakes up, which makes this not applicable. But just the same, I suggest you check this one out. For DELL systems pressing F2 upon turning on makes you go to the BIOS screen. Now you may have to look for that setting, since the BIOS is different from PC to PC, so I can't tell you where to look for it. You may consult your PC manual or call Dell Technical Support for further help.
I hope these suggestions help you.
Peace! :)
Posted on Oct 19, 2008
  • Dell Master
  • 998 Answers
Is the laptop doing this when you select “Turn Off Computer” from the “Start” button? If so, tap the <F12> key while powering on your laptop. This will bring you to a “Boot Selection Menu”. At that menu, power off the laptop by pushing the power button and see if you still have the problem. If the laptop remains off, you probably have an issue with you Operating software (i.e.… Windows XP etc...). If the laptop turns on by itself from “Boot Selection Menu”, you probably have a bad power switch control panel or motherbrd problem.
Hope this helps.
Your responses are intended to improve the level of service provided. Please rate this solution.
Thank You.
Where can I download an owner's manual?
Inspiron 6000 Service Manual - Product Support ' Dell US
www.dell.com/support/home/us/en/19/.../inspiron-6000/manuals
DellManuals & documentation for your Inspiron 6000. Last Revised: 7/8/2013. Manuals.Inspiron 6000 Owner's Manual PDF (1724 KB). More Languages. Deutsch ...
DELL 6000 OWNER'S MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Dell Manuals > Laptop > 6000
View and Download Dell 6000 owner's manual online. ... Dell owner's manual notebook pc inspiron 6400, e1505 (186 pages) ... NOTE: Corporate, government, and education customers can also use the customized Dell Premier Support ...
Jan 01, 2016 | Dell Inspiron 6000 Notebook
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
Randomly shuts down. Dell Inspiron 1000 with battery removed it will usually get past login and stay up for a while all hibernation options have been turned off.
check that it is not heated up Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Aug 31, 2010 | Dell Inspiron 1000 Notebook
My Dell Inspiron 6000 laptop turns itself off after 2 secs
Try using the Recovery CD or reinstall Windows using the Windows installation CD.
Sep 14, 2009 | Dell Computers & Internet
Dell Inspiron 6000 screen goes black / hibernates / turns off
well go to your power setting by clicking on the battery by the clock and then say power options to change those setting such as Hibernating sleep ect... you can also get to this by going to you control panel then power options hope this helps
Jul 28, 2009 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron 6000 PC Notebook, No Wifi Radio Signal
Open Intel Proset Wireless or Dell wireless utility from start>all programs. Make sure the the checkbox for 'enable radio' is checked.
Jan 01, 2009 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
97 people viewed this question
Alun Cox
