Question about Denon AVR-1706 Receiver
No Power Hi - I have bought a brand new AVR 1706 and not sure if the system is working properly or not - so before I return it , appreciate if someone could clarify -- with nothing (no input/output ) connected to the receiver, what should the standby lights (around the On/Standby) switch be doing.. when I switch the system, and press the ON button ..the RED light comes on..when I press the RED button , a GREEN light (which is normal)comes on ..the only problem is that GREEN light flashes 3-4 times and then the changes to RED again ie the system returns to STANDBY mode. IS that normal? The system exhibits the same behaviour with speakers (not sure of their impedence) and ipod connected. Pls pls..someone help and suggest a remedy before I hand the system back . PS I have tried re-setting the micro processor too , asper the manual - and have had no luck
  • 3 more comments
  • aaaaa dftg Jun 18, 2006
    Thanks for your comments Wizman. Just want to ensure that the speaker impedance is not the issue .. when I say the speaker switches itselfoff (with nothing connected ) ,I mean it goes from Standby to On mode and then back to Standby.
    Hi there .. the thing is that I got this receiver as a gift and hence i'm using only TWO speakers from my existing amp (not receiver) to use on this..
    when i first connected the speakers to this receiver,and no other input ource , it did ''seem'' to work i.e. i could hear some AM (radio) channels with a lot of distortion .. when I tried fiddling with the volume / AM antenna , there was cracking distortion noise that came from the amp and then its been behaving the way it is
    so , not sure if using the wrong speakers (as i am not sure of their impdedance ) could have caused the protection circuit to get activatd ..
    even if that were the case, thought with NO input / output connected , the system should work
    just to clarify - the system does get POWERED UP when I switch it on..the standby light changes from RED to GREEN .flashes a few times and then changes back to RED ..
    My Q to you is , with nothing connected , should the Standby power light remain on GREEN or would it turn back to RED ?
  • aaaaa dftg Jun 20, 2006
    Dear Techman ..one last query ..Just switched on the receiver and it seems to be behaving a bit better ie with no input/output connected , the GREEN light flashes a few times and then stays GREEN..however , there is no onscreen display i.e. there isno setup or boot sequence or anything else that comes up on the screen.Any thoughts if I can check something obvious thats stopping the screen display ?Thanks and regards
    Thanks..that rings a bell. I bought the receiver in the US and I am using it in UK using a step down converter to 110v .. Do you think it could have anything to do with that ?
    Though , when i FIRST started it up, with just speakers connected, I could hear a distirted AM (radio) transmission .
    Do you think I could have busted something ?
    The reason for this anxiety is obviously I want to avoid sending the receiver back to the US for repairs etc .
    Hope if there's something wrong with the power supply ( a blown fuse on the trasnformer or something) I would be able to fix it 'reasonably' as the US warranty does notcover me here in the UK !
    Warm regards
  • Anonymous Jun 10, 2008
    I have the same problem. If anyone finds any solution to this please send me an e-mail @ michalakis_michael@hotmail.com
    President:
  • 3,130 Answers
I mwas gonna suggest that you need the speakers attached but you stated later that it did the same thing with the speakers attached. The unit switching off after it checks its self is NOT a normal thing. TAKE IT BACK BEFORE ITS TOO LATE!! GOOD lUCK
Posted on Jun 18, 2006
  • 2 more comments
  • Larry  Dillon
    Larry Dillon Jun 18, 2006
    Well how many speakers are you connecting?? I doubt that if you used these with another reciver if theres a problem using them on this one?
  • Larry  Dillon
    Should stay green. The amp is checking itself for a short in the output section or shorted speakers. If there are no speakers connected or the speaker switch is off It should turn on and stay on the green.
  • Larry  Dillon
    Larry Dillon Jun 20, 2006
    Maybe not an output problem? Could be a power supply problem. But to fix itm your gonna need a schematic and start with the stanby supply first then gp,one by one to the switched supplies. Good Luck
  • Larry  Dillon
    Very well could be. Try contacting the manufacturer as I( dont have a schematic ,but I wish i did!! I love solving mysterys!!
    contactservice@denonnj.com
My denon avr-1706 is going into protection mode immediately after turning on. whats the problem?
You either have an overloaded output or a shorted powersupply. If you have verified that your connections are not the cause then the problem is internal and will require service from a trained technician. Switching power supplies are notorious for going bad. Two of the main components are the FETs used for switching and the PWM generator.
Feb 09, 2010 | Denon AVR-1706 Receiver
Denon avr-1706 receiver just shuts off
This sounds like the amps protector circuit has been activated due to thermal overload. switch it off for an hour or more to let it cool down, make sure your spkrs are connected properly, don't parallel. Try using a fan on the unit to get that heat away. Get a techie friend to give the insides a once over, and clear away any dust that has built up.
hope this is of some help,
Cheers Kimbo.
Sep 12, 2009 | Denon AVR-1706 Receiver
Denon AVR-1706 Left Front and Rear speakers stopped working. Any suggestions?
go into the settings menu and do a sound test using the recievers pink noise tester to test each speaker connected, if while doing this test you still get no sound from those two speakers check connections, make sure speakers are not blown.
if speakers and connections are good then the reciever needs repair
Jul 18, 2009 | Denon AVR-1706 Receiver
Humming sound (speakers)when HK AVR is powered up.
In my case the buzz was only on front speakers. There are 3 capasitors (100uF/25V) very close to the cooling ribs of 3 regulators in the power supply. In my case the C922 was bad.
Apr 02, 2009 | Harman Kardon AVR 500 Receiver
1706 Red ring of death
Check all your speaker connections to make sure none have shorted out.
It appears the protector circuit is being activated upon startup. cut the power altogether to the unit before checking it.
Mar 26, 2009 | Denon AVR-1706 Receiver
Denon AVR 1706 reciever
it a control switch and power supply that needs to be replaced they have blown.
get in contact with me so I can help you financially...I can buy your unit for parts.
It will cost more than the unit
radricktip@gmail.com
Sep 27, 2008 | Denon AVR-1706 Receiver
Denon AV Receiver 1706
Do you still have the unit still ??
Sep 04, 2007 | Denon AVR-1706 Receiver
Remote control for Denon AVR 1706
YES YOU CAN THERE MAYBE A FEW DIFFERENCE BUT YOU WILL BE FINE TO USE IT
Jan 10, 2007 | Denon AVR-1706 Receiver
No system setup menu on screen
its related to the control AVI switch inside on the right side with the contact and 7 Ri sisters.
about 200.00 something to repair.
I can help with some money do you have the reciever still???
Jan 04, 2007 | Denon AVR-1706 Receiver
Denon AVR-1706 Receiver Logo
289 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
