Question about Toshiba Satellite A100-S8111TD Notebook
Help hello, I have a Toshiba A-100, my hibernate and standby icon does not work, what should i do now?
  • 41 Answers
Hard drive password can be retrieved by using the serial number of the Hard Drive itself | You need to call Toshiba support for them to retrieve the password using the serial number of the HDD which can be found in BIOS.
Posted on Oct 31, 2008
Posted on Oct 27, 2008
How to calibrate battery laptop toshiba satellite m45-s359
Calibrate laptop battery pack under the following conditions:
? When the battery status display seems inaccurate.
? When you observe a significant change in normal batteryrun time.
? When the battery pack has not been used for one monthor more.
How to Calibrate laptop battery
To Calibrate laptop battery pack, you must fully charge, fullydischarge, and then fully recharge the battery pack.
Discharging the Battery Pack Disabling Hibernation
To fully discharge the battery pack, disable Hibernation temporarily.
To disable Hibernation:
? Select the Power Meter icon on the taskbar or access Power Options > Hibernate, and clear the Enable Hibernate support check box.
    To fully discharge the battery pack:
  1. Select the Power Meter icon on the taskbar, or select Start > Control Panel > Performance and Maintenance > Power Options > Power Schemes.
  2. Write down the 3 settings in the Plugged In column and the
  3. settings in the Running on Batteries column, so you can reset them after calibration.
  4. Select the drop-down lists and set all 6 options in both columns to Never.
  5. Select the OK button.
  6. Disconnect the notebook from the external power source, but do not turn off the notebook.
  7. Run the notebook on battery power until the battery pack is fully discharged. The battery light begins to blink when the battery pack has discharged to a low-battery condition. When the battery pack is fully discharged, the power/Standby light turns off and the notebook shuts down.
Dec 13, 2010 | Toshiba Satellite M45-S359 Notebook
go to control panel,power options,
change your power settings
stop Hibernation,
" choose what to do when I hit the power button" etc....
Hibernation causes problems with startups
Don't use hibernation, use standby,sleep
or turn it off completly
should cure the problem
Apr 19, 2009 | Toshiba Satellite 1415-S173 Notebook
There is no longer an option to standby/hibernate. It used to go into hibernate when I would close the laptop lid, now nothing happens, and seems like even screen is still working. In Power Options the...
no need to driver just insert you orginal windows cd and selsct upgarad option and you after you problem is resove comitment
more help pls login my web
Mar 27, 2009 | Computers & Internet
ThinkPad T60 Desktop Not Restored After Hibernation/Standby
there is something that runs most of the interface between the user and the computer it is called explorer.exe to get the task manager open, you can try pressing CTRL+Shift+Delete another alternative is to do an OS reinstallation.
To get explorer.exe
1) press Ctrl+Alt+Delete; in unsuccessful try Ctrl+****+Delete
2) if task manager opens click on 'New Task..." (if task manager does not open, consider reinstalling your OS or simply don't go into standby/hibernate)
3) Once you get the New Task dialog box, type explorer.exe or C:/Windows/explorer.exe
Jan 01, 2009 | IBM ThinkPad T22 2647 Notebook
Enable standby and hibernation in my laptop again
You can manually re-enable the Hibernate option via command prompt using these instructions:
  1. Click the Start button.
  2. Select All Programs > Accessories
  3. Right-click on Command Prompt and select Run as administrator .
  4. At the command prompt enter
    "powercfg -h ON"
  5. Close the command prompt window.
Nov 27, 2008 | Toshiba Satellite L25-S119 Notebook
My acer computer will turn on but wont come out of hibination mode
Some laptops have issues with Windows XPs hibernation mode. To get the computer back up again you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Once you get the computer back running again you may want to disable hibernation if it seems like its going to keep happening. Go to Start, Settings Control Panel or Start, Control Panel and go to the Power Options icon. Change the hibernation section to never. You may want to try standby as an alternative. Standby saves all your running applications and documents into RAM while hibernate saves them to the hard drive. Hibernate uses less power from your battery, but it will take you considerably longer to get the computer back up. If you always plug the computer in then you may want to disable standby and hibernate since you really dint need them while plugged in.
Let me know if this works.
Aug 16, 2008 | Acer Computers & Internet
Stanby mode
Goto control panel, performance and Maintenance, Power options, Power options property, hibernate tab, enable,apply, advanced tab, select how you want to stand-by or hibernate unit, apply.
Mar 17, 2008 | Toshiba Satellite A205-S4617 Notebook
Stand by icon locked Toshiba Satellite 1115-S103
i really need more info, two things:
firstly look to see if the clip (where the screen clips onto the base when it closes) is mobile and is not jammed down from something.
secondly restart, if a image comes up in your POST (when the computer boots up) push tab and then F8 or similar (it will say just read the screen = ] ) and restart windows in safe mode.
when you have booted up in safe mode check in the display and power window and tell the computer to never go into sleep or hibernate.
like i said i need more info cause this can also be caused bu a hdd contact error, or a battery falure, so please if this does not help in the slightest just post up here more info and i will be happy to help further.
good luck.
Oct 29, 2007 | Toshiba Satellite 1115-S103 Notebook
By-pass Hibernation
Instructions: Power off the system and wait a few seconds to make sure that hard drive has spun down. Hold down the "Backspace" key while powering on system. The following message should appear: Warning: Can't restore Hibernated State. Press any key to continue. After pressing a key on the keyboard, the system will continue with the boot process and the hibernation/standby mode will be by-passed.
Sep 07, 2005 | Toshiba e740 Pocket PC
Toshiba Satellite A100-S8111TD Notebook Logo
101 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
