Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
No agitation i have a top load washer (roper). the bottom agitates but the top part won't spin to **** the clothes down under. the top part of the spindle i can spin by hand
  • pdubois Oct 21, 2008
    I've got the same problem, figured out the dogs without much problem except it doesn't look like the plastic disk holding the dogs comes out very easy. There appear to be 4 snap-teeth holding the disk in and they appear to be melted in place during assembly.
    How did you 'let the dogs out' if you'll pardon a pun.
I have a Whirlpool Utlimate Care II LSQ8520JQ0. For those having a problem separating the upper and lower agitator halves, here's how I solved it after about 2 hrs of aggravation.
Called Sears and Whirlpool with no help (didn't have tech manual...go figure).
I saw the same post with the problem with melted hooks (I called them tabs) ontop of the dog housing being melted. You can differentiate the melted tabs from the dog housing as the dog housing is usually clear plastic (after wiping all the crud off) and the tabs are white as they are part of the agitator. There will be four white tabs on top of the dog housing. They look both smashed and melted. I took a flat head screw driver and and hammer and chipped off the white melted tabs visible on top. I inevitably also chipped some of the dog housing but only marginally. Once chipped off you'll see the tabs are actually rectangular in shape. At this point I EASILY pulled the top and lower halves apart. Those retangular tabs are the molded part of the agitator housing extending down past the dog housing. You're home free at this point.
It's the melted tabs on top of the dog housing that keeps you from separating the halves. What a pain but finally figured it out.
Posted on Feb 16, 2009
    Genius:
  • 1,122 Answers
POP THE TOP OFF THE AGITATER REMOVE THE 7/16 BOLT,PULL TOP OF AGITAER OFF,YOU WILL SEE 4 GEARS THAT TURN THE AGITATER CALLED DOGS,REPLACE AND REINSTALL IN REVERSE,YOU CAN GET THE DOGS AT YOU LOCAL APPLIACE PARTS STORE,LET ME KNOW HOW YOU DO-MIKE
Posted on Oct 19, 2008
  • MIKE major Oct 20, 2008
    why did you give me a thanks for trying when i give you the fixya repair on your roper???????mike
  • MIKE major Oct 24, 2008
    your a jerkoff-mike
How to remove the top part of the agitator of a roper model ras8445kq0
Often agitator tops do spin somewhat freely, for safety reasons. Most of the work gets done at the bottom, anyway. Unless your clothes are getting tied in knots, I wouldn't worry about it.
But if you want to look, they're usually not that hard to remove. I can't picture yours off the top of my head, but look for a cap/cover/cup on top that can be removed by hand, and there might be a bolt underneath that. There's usually a lot of friction in addition to the bolt holding it in place, so you might use an old towel slipped under the agitator and cinched to give you more leverage/grip.
Good luck.
Jun 12, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper washer agitator won't spin after kids loaded
It sounds like a someone has broke the lid switch to the washer. Below I have attached a picture, Item number 9 would be the part you seek. P# 3949247 Under the control panel you will find a harness that contains 3 wires coming out of the cabinet housing. The colors should be tan, white and green. If you jump the white and tan you unit should run and think the lid switch is working. Safety way is to unplug the unit to by-pass the switch and plug it back in and select spin only. This is only to test, you need a lid switch for safety. You should replace it ASAP if this test works for you.
Jul 26, 2011 | Roper RAX4232KQ Top Load Washer
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Apr 15, 2009 | Amana ALW480DA Top Load Washer
Kenmore 90 series agitation problem
suppose to not spin unitl the lid is closed( safety reasons) the reason for the "weak agitation " is a bad set of agitator dogs. by removing the center fabric softener cup, you can get to and unscrew the center shaft bolt7/16. after removing the bolt, the agitaor will remove and the agitator dogs canbe replaced. part number 80040.youll need to split the agitator top and bottom to insall them . they simply slide into place.
Feb 14, 2009 | Whirlpool LSB6200PQ Top Load Washer
Agitator Noise of Roper RTW4305VQ
yes this noise is normal.its the dog ears ratcheting in the agitator
Jan 19, 2009 | Roper RAS8244KQ Top Load Washer
Washing machine doesn't spin spindel
whirpool part# 80040 agitator dogs need replacing remove center cap remove bolt in agitator pull top section up ..may need to hold bottom down and pull up sharply on top section to separate
Nov 06, 2008 | Roper RAS6233KQ Top Load Washer
Agitator not spining properly to pull clothes down into water
remove agitator cap remove boplastic cover underneath remove bolt remove upper portion of agitator replace agitator dogs part # 80040
Jun 06, 2008 | Roper RAB2121KW Top Load Washer
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Agitator won't agitate
Replace what is called the dogs in the agitator (part number 80040? i think)
Oct 29, 2007 | Roper RAS8244KQ Top Load Washer
Roper Washer
The gears in top are stripped out need replacing, take cap off agitator and take out bolt pull agitator out ..pull top part agitator off and replace gears
Here is what the gears look like for the top part of the agitator
top part of agitator
bottom
Oct 17, 2007 | Tecnik TKL9260 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
243 people viewed this question
Dan Webster
Dan Webster
Sal De
