Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Smoke gets in my eyes!
Hi! Smoke is coming out the top and bottom but the tv still works! Great pic, great sound....heard a pop when we turned it on and abolut 10 seconds later smoke is coming out. Is it toast or can it be fixed??
  • mamab53 Oct 19, 2008
    Thanks so much! My husband just wants to buy a new one, but I was thinking it may be as simple as a loose wire connection and don't want to spend that money.
  • 135 Answers
It can be from the backlight inverter arching to metal, the backlight connectors going to the inverter charring, or something more board related. Those I've seen required replacement of the panel because balancer is part of the panel and not a replacement part.
Posted on Nov 10, 2008
  • 320 Answers
It can probably be repaired but it will have to be examined by a qualified Sony tech. I would not use it until you have it checked as continued use may result in additional parts being damaged.
Posted on Oct 19, 2008
  • Any Guy
    Any Guy Oct 19, 2008
    It is probably NOT just a loose wire, but I still think it would be cheaper to repair the set rather than buying a new one. Beware of shops advertising "free estimates" on TV repairs; in my experience you get what you pay for. This is just a "guess", but I would expect the repair cost would be in the $200-$400 range. Understand that that was a guess with no actual knowledge of your exact problem, so I don't know how accurate it is. Good luck!
Honda fourtrax 350
Hi, if there is smoke 10-20 minutes that is fine, probably just residual oil from the top engine work.
if the smoke is a hour coming off the engine because of external oil leak, sounds like head gasket is leaking. If you continue to run the machine like this, make sure to always check oil levels and add oil when low. As long as your smoke is not coming out the tail pipe which would mean you are burning oil and would need to be fixed.
side note: Its always good to have a Haynes manual for any machine you own, they have great troubleshooting tips.
Honda ATV Repair Manuals Do It Youself DIY Manual to Repair Honda...
Sep 06, 2014 | ATVs
Panasonic VIERA Flat Panel Televisions. Won't turn on. Made one popping sound. Now smoking.
I would say that's pretty much had it ,if there's smoke coming from the back something has burnt out
I would take it to a TV specialist to see if it can be repaired
Feb 03, 2018 | Panasonic VIERA Televison & Video
if its smoking thats a shorted system..if you feel safe with fixing it do so otherwise get rid of that deathtrap..
Dec 25, 2013 | 1992 Mitsubishi Diamante
check to see if there is a circuit breaker on the wire path from your batteries. Could have blown the motor but You would see some smoke more than likely, and smell it burning. What you described with the popping sounds like an electrical short where the wires just burned up but again you'd smell it and maybe see smoke. The switch may be bad also check it with a meter to see it its making contact and see if voltage is coming up to and exiting the switch.
Aug 06, 2013 | Dual Club Car Lester Power Drive Charger...
I heard a pop and then I seen smoke coming from the top. The picture started to fade out slowly then went out completely. It still turns on and the volume still works, but I still have no picture.
First, if you had smoke----turn it off and UNPLUG IT.
Do not risk a fire in this situation.
Depending on brand and model it may or may not be worth repairing--someone with expertise needs to open it and look to see what and where the smoke came from.
A good idea when you post here is to give the brand and model number of your set--reply here with a comment and I will advise you.
Apr 13, 2011 | Televison & Video
Engine light is on smoke test revealed vacuum leak at back of eng
Vacuum boot comes off of the intake manifold at rear of engine, passenger side. Super hard to get to. you cannot see it. You have to do it by feel. After a startup backfire, mine popped off. My mechanic couldn't find it, but a smoke test of the vacuum system confirmed it was coming out between firewall, and intake. It took me @ an hour to find it. Pushed it back on and it works great.
Jan 15, 2010 | 2004 Ford F150
Problems while charging a battery
hi you got a short on that circiut if it has nothing to do with you charging the battery you need to find out what this wire controls and strip the wire back to see where it stops melting and replace and replace what is causing the short [electric motors are favourite for shorting ] but be warned if a cars wiring starts to set on fire you will never in your life see anything like it you will have seconds rather than minites to get clear the smoke is unbearable if it sounds serious it is if the vechicles in good nick and you want to keep it my advice is sort as soon as best of luck paul
Aug 04, 2008 | 1998 Jeep Cherokee
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
114 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
