Question about Zanussi FJS1225W Front Load Washer
Replace washing machine bearings
How do I replace drum bearings in a Zanussi FL1085 washing machine please?
  • richwd Oct 19, 2008
    The suggested rout to an exploded view via model or part number search did not work. Also, even if the search had been successful, provision of just an exploded view is likely to be of insufficient help.
    Genius:
  • 1,550 Answers
You can get from the link below
Drum bearings
Posted on Oct 19, 2008
  • Zanussi Master
  • 19,396 Answers
    Guru:
  • 558 Answers
Could you please give me the complete model no. so I can give you some pics for replacing the Drum bearing.
And make me clear if you are talking about Transmission or Gear box.
  • 1 more comment
  • Puneet Jain
    Puneet Jain Oct 19, 2008
    Please download the manual for further instruction for your Machine which will help you out in finding the correct part replacement:
    Zanussi Washer
    Its in PDF.
    Let me know if you need further help.
  • Puneet Jain
    Puneet Jain Oct 20, 2008
    Have you check for the manual I had provided , if already have the manual, then skip it.
    You can find a good view from the website Repair clinic and all parts also available.
    Regards,
    Ellin
  • Puneet Jain
    You can have a simpler graphichal view for the Front Load washer:
    Repair Clinic Front Load
    Scholar:
  • 44 Answers
It is a very involved process with the tank having to be extracted form chassis. There is really no step by step instructions for this, but most reports say it is not economical to do this yourself. There may even be restrictions in your zip code. You should hire a technition to do this and the job takes about 2 hours.
I hope I was able to fixya problem and I wish you the best with this.
Replacing drum bearing on a ZANUSSI FJS 874 front loader ?
This is not a simple job, it can be fine but requires the complete disassembly of the machine to change the bearings, there are 2 bearings and a seal that require replacement, I can assist in guiding if you wish to do so, it takes around 3 hours total to strip and rebuild.
Jun 16, 2016 | Zanussi Washing Machines
Model no.zwf1432 w
If you don't have it, try this on line http://laundry.manualsonline.com/manuals/mfg/zanussi/zwf_1432_w.html?p=1
Apr 13, 2015 | Zanussi Washing Machines
Zanussi fl1085
Usually if you wait 3-5 minutes, the door will unlock.Also try put the know near the end of the cycle, and it may drain, and release the door.
Jan 08, 2012 | Zanussi Washing Machines
Replacing drum bearings, how to remove?
They come complete on spider assembly on some models..Check utube video. Or espares.co.uk for parts cost 1st...
Oct 07, 2009 | Washing Machines
Washing machine noisy when on a spin
  • If a washing machine is very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Aug 28, 2009 | Zanussi ZWF1430W Front Load Washer
    Zanussi IZ12 bearings gone & plastic fragments in drum
    Probably all parts inside drum is ok.Heating element is the only damageable item and a sensor.Changing bearings you must separate the drum, all screws in middle of drum must out and then bearing and zimmerring can be changed.Jan
    Feb 15, 2009 | Zanussi IZ12 Front Load Washer
    Zanussi washing machine drum will not go round at all
    Tracy
    The bearing may have siezed or you have something jammed between the drum and outercasing
    Mar 23, 2008 | Washing Machines
    Zanussi aquacycle 1200
    May be the Bearings.Open door and try moving drum, hold at top of drum and pull foreword and back if drum loose main bearings gon. Replace bearings.
    Slim Jim
    Oct 28, 2007 | Zanussi FJS1225W Front Load Washer
    Zanussi FJS1225W Front Load Washer Logo
    517 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
