Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model# 110.28803890
Washing machine continue to fill up until it runs over. No matter the level setting small, medium, or large load it fills up and overfills the machine until water runs on floor. Is there a sensor or relay for fill level>
  • 142 Answers
Hello. Yes there is a fill level pressure switch. It is pressure activated by the pressure of water rising in a tube as the water rises in the tub.It's easy to find and easy to replace. Look for the tube and follow it to the switch. Parts for Kenmore are available at 1-800-516-9625 or at http:\
Good luck.
Posted on Oct 19, 2008
Continous water filling
HI, the water level switch is damaged on this unit. you will need to replace this switch. this will fix your level issue.
May 27, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Washer will overfill on small load and large
If this happens only on small load cycle , then it can be a faulty timer board.
however check also the water level switch, when there is overfilling this part is always the first suspect.
May 21, 2009 | Kenmore Elite 21082
Kenmore 80 series washing machine-top load
You will need to replace the pressure switch, Take back off console to get to the switch, there are 3 wires brown, purple and pink, also a hose that attaches to the switch needs to be removed. Switch will cost about 30. dollars
Feb 20, 2009 | Dishwashers
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series overflowed!!!
The most common cause for this is the water mixing valve plunger sticking. the fix is to replace the mixing valve. Not so common is a defective water level pressure switch. Same fix, replace the switch. Really rare is a small leak in the tube from the tub to the pressure switch.
Feb 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
893 people viewed this question
Sal De
 Brian Main
Brian Main
