Turn on tv andnothing works - Televison & Video
Try 2 hit a few times if still nothing then call a repair service
Posted on Oct 19, 2008
My 2000 cadillac deville wont start. I bought a new battery. New alternator and a new ground wire under the hood. My starter was tested and is good. Ive been trying to jump it off andnothing will come on
On your car the crank circuit includes a crank fuse, the theft deterrent relay, the key switch, and the PCM in addition to the starter itself.
All of these components would need to be tested to find the problem.
Feb 15, 2013 | Cadillac Cars & Trucks
What's your problem?i have ti-83 plus and some parts of the screen is fuzzy expecially when I use the 2nd command. I have been using it in class andnothing out of the usual has happened to it. I just...
If you cannot see anything on the screen, you may need to adjust the graphing TI 84 calculator contrast :
1.To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark.
2. To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light.
Apr 04, 2012 | Texas Instruments TI-83 Plus Calculator
My sony tv wont turn on and the red light blinks...
In the absence of sound and video, it is likely a failure of the main power supply. This may be a separate board that, if connected with the typical plugin connectors, may be user replaceable.
Look for a smaller board with larger components; some will be block-like (transformers and chokes) others will be cylindrical and mounted at 90 degrees to the board.
If you can locate this, look for part numbers on the board (often on a label). Call the service center nearest you and inquire about the cost of a new replacement board or repair on yours; using this number for reference is better than your model number alone since these are often purchased from other suppliers and may not be the same from one unit to the next. There may not be much price difference.
Apr 14, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I have a KitchenAid side by side and my icemaker is not working
Check the black 2" fill hose going from the top of the freezer to the ice maker fill cup , to see if it's frozen up . Also check the optics system for proper operation . Open the freezer door and the laser should flash 2 times , pause , flash2 times , pause etc. Close the flap on the left side and the laser should go off . If the laser does not come on when the door is opened , then the ice maker is in the harvest ( dump ) mode . If it stays this way , then ice maker is bad .
Sep 12, 2009 | KitchenAid KSRG25FK Side by Side...
High pitch noise, no POST
it sounds like it has died and blown up (last time that happened to me it smelled bad too.)
Jul 14, 2009 | Computers & Internet
System will not connect
check the comm cable between the computer and the device make sure that all settings are correct like address, baud rate, comm port connection, and their may be a setting that controls how long the device will attempt to connect this needs to be disabled.
Jun 06, 2009 | Lorex 4 Channel Business & Home Security...
Dell inspiron 1150 screen goes black after standby
Let me help you regarding this, As your notebook is not having low room to handel the standby applications, i suggest you to change the power options in the control pannel. There you find POWER OPTIONS icon click on it and go to advance tab, there u find the option called WHEN YOU CLOSE THE LID, put it to DO NOTHING. So that nothing happens when you close the lid. I hope this helps you. BYE
Nov 14, 2008 | Computers & Internet
Sharp pgm20x switches off immeately after switching on
It turns out that i fixed this issue, I opened up my projector and took a look at the board to make sure that there is nothing wrong. It turns out that the projector needed a good cleaning. Just use caned air to clean out the projector make sure that all the vents are clear and not blocked. (note: do not spray the caned air while the bulb is hot, if you do this the bulb can cause the pressurized air to temporary flame up, Please make sure the projector has had at least 30 minutes to cool off) While the board is off press the power button and the projector should power up. Replace the covering, and this projector will work.
Jul 10, 2008 | Sharp Notevision PG-M20X Multimedia...
Wahl 9765-301
if you put oil on the blades does it help if you remove the blade you should see the pivot what make the blades moves hair preventthe blades from moving freely after if it still weak motor is weak not mush to do with that pricewise better by andnother one cheers
Jan 30, 2008 | Wahl 9765-301
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
